Coefficient of kinetic friction of a sliding crate
The problem involves calculating the coefficient of kinetic friction for a 100 kg crate sliding down a 30-degree incline, initially moving at 2.0 m/s and stopping after 1.5 m. The equations of motion and forces acting on the crate are applied, leading to an acceleration of -1.3 m/s². The normal force is calculated to be 848.7 N, and the frictional force equation is set up to solve for the coefficient of friction (μ). The final calculation yields a coefficient of friction of 0.73, confirming the solution's accuracy despite a minor typographical error in the acceleration formula. The discussion emphasizes the importance of clear notation in physics problems.
ally1h
Ugonna stands at the top of an incline and pushes a 100 kg crate to get it started sliding down the incline. The crate slows to a halt after traveling 1.5m along the incline. The initial speed is 2.0 m/s and the angle of incline is 30 degrees. What is the coefficient of sliding friction?
ΣF=ma
ƒ = μN
aΔx = ½(vf2 – vi2)
I have my midterm on Tuesday and am working on problems at the end of the chapters. I am hoping that someone can confirm my work, to make sure everything is okay, or help me through it if anything is wrong. This is what I have.
ΣFx = mgsinθ - ƒ
ΣFy = mgcosθ +N = 0
a = [(1/2)(0-2.0)2] / 1.5 m
a = -1.3 m/s2
Fy = mgcosθ +N = 0
N = (100 kg)(9.8m/s2)cos(30)
N = 848.7 N
ΣFx = mgsinθ - ƒ
Fx = (100 kg)(9.8m/s2)sin(30) - μN
= (100 kg)(9.8m/s2)sin(30) - μ(848.7N)
= 490 - μ(848.7N)
ΣF = ma
490 - μ(848.7N) = (100 kg)(-1.3 m/s2)
- μ(848.7N) = -620
μ = .73
Seems okay to me!
Awesome! Thank you!
There is one thing; it looks just like a typo though:
This:
should be written like this:
a = [(1/2)((0 m/s)^2-(2.0 m/s)^2)]/1.5 m
The answer isn't changed, though.
Ahh yes, definitely a typo; thanks
