Collision question involving velocity, Kinetic energy and conservation
The discussion centers on a physics problem involving a collision between a steel ball and a ceramic ball, focusing on calculating the velocity of the steel ball after the collision and the total kinetic energy before and after the event. The initial momentum of the system is calculated as 100 kg·m/s, leading to a final velocity of the steel ball being determined as 1 m/s. The initial kinetic energy is computed as 100 joules, while the final kinetic energy requires careful attention to unit conversion from grams to kilograms. Participants emphasize the importance of maintaining standard units in calculations to ensure accuracy. The conversation highlights the necessity of understanding momentum conservation and energy transformations in collision scenarios.
selsunblue
A 50 gram steel ball moving on a frictionless horizontal surface at 2.0m.s^-1 hits a stationary 20 gram ceramic ball. After the collision the ceramic ball moves off at a velocity of 2.5m.s^-1.
(i) Calculate the velocity of the steel ball after the collision.
(ii) Calculate the total kinetic energy of the balls before the collision and again after the collision.
(iii) From your results in part (ii) has the kinetic energy been conserved? If not, where has this energy gone?
initial momentum = final momentum
For the first sub-question I got initial momentum=50*2=100 and final momentum i got 50v+2.5(20)
equating these I got 100=50v+50 => v=1ms^-1
Would the 20 be correct in that calculation of final momentum?
initial KE = ½ * 50 * 2^2 = 100
Final KE = ½ * 50 * v^2 + ½ * m * 2.5^2
Where does "20" come from? It was not specified in the statement of the problem.
Oh It's the mass of the stationary ceramic ball, sorry about that, forgot to write it in I guess. Would it be 50 or 20 in this case?
Then your solution for the steel's ball velocity after the collision is correct.
Yes but it should be remembered that the units are not in standard units (joules) since you didn't make the conversion from grams to kilograms. The answers would have to be divided by 1000 to be in joules (it's a good habit to pay attention to units).
Likes 1 person
  • · Replies 22 ·
