Colorimeter transmittance and reflectance questions
  • Thread starter Thread starter xp2334
    Reflectance
In reflectance mode, accurate measurements depend on the amount of light reflected from the sample's surface, necessitating a suitable backing material for clear or translucent fluids to avoid compromised results. For transmittance mode, the cuvette's width affects the light path length, influencing the absorption measurements. Ambient light can interfere with readings for translucent samples, while opaque samples primarily absorb light without reflection. A white background can mix reflected and transmitted light, complicating the interpretation of results. Proper setup is essential for reliable colorimeter readings in both modes.
xp2334
1) What considerations should be taken when interpreting the results of color measured by transmission and reflectance mood for clear/translucent fluids?
2) What possible effects the room lighting has on the results obtained for transparent/translucent/opaque samples measured in reflectance mode?
no calculations involved
qns 1 attempt:
In reflectance mode, measurements are taken based on the amount of light reflected from the surface of the sample. Therefore, in clear/translucent fluids, it is critical to have appropriate backing material behind the sample, such as a white and matte piece of paper or cardboard, or else the results may be compromised.
For transmittance mode, the width of the cuvette used will impact the path length of light which impacts the amount of light absorbed. Thus, the type of cell used during the experiment should be taken into consideration when interpreting the results measured.
qns 2 attempt:
For translucent/clear samples, ambient light is reflected and may therefore impact the readings whereas, for opaque samples, the light gets absorbed and therefore isn't reflected.
if you have a white background some of the light you are observing has come through the fluid, so you are mixing reflected light with transmitted.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
