james fairclear
- 41
- TL;DR Summary
- Comparing Tick rates of clocks across Frames
Clock A and Clock B and clock C are stationary with each other in the same location and synchronised.
Clock A is accelerated and its tick rate is found to have changed from what it was prior to acceleration.
We might then enquire: Measured by whom? Some frames will say it has increased, others will say it has decreased. It depends whether the clock's speed decreased or increased in the frame of interest.
The tick rate of a clock is a relative quantity.
We judge the relative tick rate of clock A by comparing the amount of time it has recorded with the amount of time recorded by other clocks B and C with which it was previously synchronised.
The indicated time on each of the respective clocks is continuously broadcast by radio waves for observation during the experiment and also recorded electronically for observation at the end of the experiment. A sample of the continuous recordings might for example be as follows:
In this example we see that clock A starts to progressively record less time than it did prior to the acceleration. The reverse can also be the case but it must be one or the other.
The pattern of readings from an accelerated clock indicates whether the tick rate increases or decreases subsequent to the acceleration and on inspection of the recorded data this pattern must de facto be agreed upon by all non-accelerating observers.
Indicated time on Clocks | ||
A | B | C |
0 | 0 | 0 |
15 | 15 | 15 |
30 | 30 | 30 |
45 | 45 | 45 |
60 | 60 | 60 |
Clock A Accelerated | ||
70 | 75 | 75 |
78 | 90 | 90 |
84 | 105 | 105 |
88 | 120 | 120 |
90 | 135 | 135 |
