ikihi
- 81
- 2
So when volume decreases, pressure increases according to Boyle's Gas Law and the ideal Gas Law. In other words, compressing gas into a smaller volume increases the vapor pressure. And also, According to Gay-Lussac's Law and ideal Gas Law, when pressure increases on a gas, temperature also increases.
So am I correct in thinking that when a piston compresses gas ,the volume decreases; which increases pressure. Then this same higher pressure should make the temperature increase?
What are all of the sources behind higher pressure equaling higher temperature?
If temperature is proportional to the average kinetic energy of gas molecules then would just the fact of having more molecules in a smaller space increase the temperature due more kinetic collisions between the molecules and closer walls? Does it depend on how fast the volume is reduced by compression?
When you reduce a container volume by rapid compression, the temperature increases due to work on on the gas? This work transfers kinetic energy to gas molecules and extra energy should increase the temperature?
