(Confused) RF circuit concepts- Voltage division?
The discussion centers on calculating the input voltage at an input impedance from a voltage source using the voltage division law. The initial formula presented, Vs * Zin/(Zin+Zs), is questioned due to the need to consider additional resistances from the transmission line and load impedance. It is clarified that the input impedance can be modeled as a resistor, and the effects of all reactances should be included in the calculations, especially when measuring voltage across the terminals of a black box. The importance of considering the output load and its impact on the input impedance is emphasized, particularly in avoiding reflections in transmission lines. Ultimately, the participants reach a better understanding of how to approach these calculations in RF circuits.
nomisme
how could you calculate the input voltage at an input impedance from a voltage source?
I saw they use voltage division law to find the voltage at the input impedance(Zin) from a voltage source(Vs).
They do it like Vs * Zin/(Zin+Zs).
The problem came... We all know that we can determine the voltage only after considering all resistances in a circuit. They still have the transmission line and load impedance. If I denote them as Zt and Zl, wouldn't the voltage to the input impedance be Vs * Zin/(Zin+Zs+Zt+Zl) instead?
Because if you simply consider Vs * Zin/(Zin+Zs), the voltage wave will be zero after going through the input impedance before even entering the transmission line connected with a load on the other end. This doesn't make any sense.
Help.. If you don't understand what I am saying, please let me know.
The input impedence to what?
The usual situation is that you have a black box with some sort of network inside and two terminals sticking out of it. You have no access to the internals of the box. All is not lost: this can be modeled as an ideal voltage source in series with a reactance. The Thevinin equivalent.
You get the value of the ideal voltage source by measuring the open-circuit voltage between the terminals.
The internal reactance (input impedance - whatever) you can find by putting a load between the terminals, measuring the new voltage across the terminals, and doing a bit of math.
You'll notice that this approach combines the effects of all the reactances except for the load, and includes them as part of the "internal reactance" of the black box. If you happened to have a very long coil of wire between the external load and the black box, then that will throw the calculation off - unless you treat that as part of the load. It's outside the box so you can, in principle, measure it.
If you want to use a different model, then the calculation is going to be different.
I think you need to provide a specific example - a link to a circuit of the kind you have in mind for instance.
Hi Simon,
Thanks for your explanation in advance.
The input impedance I mentioned refers to an input resistance to a transmission line on the left. (The load is on the far right and the voltage source is on the far left and the transmission line is in the middle.)
The voltage from the source will experience an input impedance before entering the transmission line. We want to first find out its voltage at the input impedance.
The problem is that if we model the input impedance as a resistor, wouldn't the voltage wave becomes zero after passing through it? Because according to the voltage division rule provided above, it only considers Rs and Rin so the others resistances in the system are ignored. So after passing the voltage through both Rs and Rin, the voltage should be zero.If this is the case, there should be no wave going through the transmission line and load. This is a very fundamental concept that I don't understand. How could you determine the voltage at the input without considering the resistance of the transmission and the load.
I am really confused..
A transmission line has an input impedance. For example a 50 ohm line appears initially as 50 ohms, but if there is no load at the other end it eventually becomes an open circuit. This load is effectively across the transmission line input terminals.
You will connect an output load. If you connect 50 ohms to the output, then the 50 ohm input load will remain 50 ohms because there are no reflections.
You will drive with a source that has an output impedance. The output impedance is in series with the 50 ohms input impedance. This causes a voltage drop when you drive the transmission line.
The input impedance of the transmission line can be modeled as a resistor across the transmission line. So if the source is 50 ohms and the line is 50 ohms, then Vs/2 initially appears across the transmission line.
Thank you both of you.
I think I ve got it now.
Great - well done.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
