- #36
Baluncore
2023 Award
- 14,999
- 8,859
Sorry @Tom.G, I rationalised and completely turned the circuit around. I think you missed the point that the AD629 isolation amplifier is now being used to sense the DAC voltage and zero reference across the isolation barrier. Power derived from the load supply is then used to run everything needed to regulate the load current.
The DAC (that was once a pot) is not connected directly to the floating load ground, it is powered and driven by the processor or whatever controls it, only it's output voltage is exposed as a floating voltage source to the inputs of the AD629.
The 50V, 50Hz AC supply is there to demonstrate, or test, the common mode rejection of the floating grounds when using the AD629.
For my simulation I define the LTspice simulation ground for the floating load circuit because simulation becomes very slow when there are high resistance ties across the simulation matrix.
Here is a revised schematic with very minor changes. Still no symbol for the AD629.
