I Conventionality of the One-Way Speed of Light
  • I
  • Thread starter Thread starter MrRobotoToo
MrRobotoToo
TL;DR Summary
I provide an argument for why the conventionality of the one-way speed of light doesn't undermine special relativity
I recently watched this video by Veritasium on the Einstein synchronization convention and its implication for the one-way speed of light and it got me wondering if it in any way undermines the results of special relativity. I think the following argument shows that it doesn't, but any constructive criticism is welcome.
Let’s begin by considering two inertial observers O and O′ that may or may not be in relative motion. They both carry clocks with them and are able to send and receive light signals. If O sends out a light pulse at τ₁ and it bounces off an object and comes back to her at τ₂, she’ll label the ‘bounce event’ with the coordinates t and x, where⁣
t = ɑ(τ₂ + τ₁) ⁣
x = β(τ₂ - τ₁)⁣
She’s free to choose ɑ and β–for example, if she believes that the speed of light for each leg of the round trip has the same constant value, then ɑ = β = ½…but any other values will do. Now, with respect to the object, at the exact moment that the O pulse bounces off, another pulse also bounces off that had initially been sent by O′ at τ′₁ (as measured by his clock), and which he’ll receive at τ′₂. He labels the bounce with his coordinates t′ and x′:⁣
t′ = ɑ′(τ′₂ + τ′₁) ⁣
x′ = β′(τ′₂ - τ′₁)⁣
Again, O′ is free to choose ɑ′ and β′.⁣
If O and O′ are at rest with respect to each other, they can synchronize their clocks in the usual way: O sends out a light pulse and it bounces off O′ and returns to O. Their clocks are synchronized so long as t = t′ for the bounce. For O′, this event will clearly have τ′₂ = τ′₁. Keeping this in mind and setting the equations for the time coordinates equal to each other will yield (after a bit of algebra):⁣
τ′₁ = ½(ɑ/ɑ′)(τ₂ + τ₁)⁣
The Einstein synchronization convention results when ɑ = ɑ′.⁣
Now that we have the two coordinate systems (t, x) and (t′, x′), we can relate them to each other using Pelissetto and Testa’s postulates, for instance. In the case where the two systems are related by the Lorentz transformations, the constant speed that appears in the equations isn’t 𝘯𝘦𝘤𝘦𝘴𝘴𝘢𝘳𝘪𝘭𝘺 the speed of light. Unusual choices of the alphas and betas above will imply that the speed of light is anisotropic, which would be the case if light is a wave in some material medium and the two observers are moving with respect to it. This doesn’t conflict with SR since it merely implies that light is demoted to an unremarkable phenomenon akin to sound traveling through air. Their postulates also allow for the systems to be related by Galilean transformations, which simply the limiting case when the constant speed that appears in the equations goes to infinity.⁣
The conventionality of the one way speed of light (OWSOL) was recognized from the very beginning. In the seminal paper On the Electrodynamics of Moving Bodies Einstein said «we establish by definition that the “time” required by light to travel from A to B equals the “time” it requires to travel from B to A» (emphasis in the original).
So you are completely correct that it does not undermine SR in any way. It is part of the theory known from the beginning. The OWSOL is a definition.
Likes dextercioby, PeroK and MrRobotoToo
It's not necessarily the one-way speed, but it is necessarily the two-way speed of light.
What your maths tells you, in short, is that freedom to choose the one-way speed of light corresponds to freedom to choose whether your coordinate system has its planes of constant time orthogonal to its lines of constant position. Since there's no actual coordinate system in real spacetime this should be a personal choice, so it should be free of physical consequences (how messy the maths gets is a different thing) - as indeed it is.
  • Agree
Likes cianfa72 and PeroK
MrRobotoToo said:
TL;DR Summary: I provide an argument for why the conventionality of the one-way speed of light doesn't undermine special relativity
t = ɑ(τ₂ + τ₁) ⁣
x = β(τ₂ - τ₁)⁣
x′ = β′(τ′₂ - τ′₁)⁣
𝐀𝐝𝐝𝐞𝐧𝐝𝐮𝐦: Further restrictions have to be placed on the alphas and betas in order for them to correctly describe any anisotropies in the speed of light that may be due to the motion of O and O′ through some medium, namely:
0 < ɑ(û) < 1, where ɑ(-û) = 1 - ɑ(û)
and
β(û) > 0, where β(-û) = β(û).
Here û is a unit vector that points in the direction that the light signal is being sent. Similar relations hold for the primed alphas and betas. If the two observers are at rest with respect to each other, then ɑ′(û) = ɑ(û) and β′(û) = β(û).
The Einstein synchronization convention is just that - a convention. Physics does not depend on conventions. Various synchronization conventions in special relativity are just various definitions of the time coordinate, which, in turn, are just a special case of various choices of spacetime coordinates related by general coordinate transformations. That's why in modern formulation of relativity, especially general relativity, one rarely talks about synchronization conventions, because it is already implicitly included in the concept of general coordinate transformations.
Likes PeterDonis and PeroK
t = ɑ(τ₂ + τ₁) ⁣
x = β(τ₂ - τ₁)⁣
x′ = β′(τ′₂ - τ′₁)⁣
In the above, I believe the only sensibile way to check/ensure what I highlighted in bold, is to use light beams sent forth and back from O to O' and the other way around measuring that the round-trip travel time stays constant (as measured by the same clock).
A cautionary note is needed here I think. High school and introductory physics has been known to be formulated and taught in such a manner that certain conventions NEED to be followed for the results to be valid. For instance, Newtonian physics as taught in an introductory level only works in an inertial frames. Physicists strive to eliminate the need for conventions, and I think to a large extend they have succeeded. It's unclear to me how much of the motivation to eliminate the need for conventions was philosophical, for instance Lagrangian physics is one of the usual first steps in an introduction to a formulation of physics that allows more freedom in the choice of coordinate conventions, but I really don't know what motivated him.
I can't recall the examples anymore, but in past discussions I believe the topic has come up about physical insights initially being developed in coordinate-dependent formulations that required certain conventions to be followed, and later to be reformulated in coordinate free formalisms.
Likes Ibix and Nugatory
