Conversion using factor label method
  • Thread starter Thread starter rose ah
    Method
The discussion centers on the factor label method, which is a technique used for unit conversion in calculations. Participants emphasize the importance of demonstrating understanding by explaining the method in one's own words before seeking help. A specific example involves calculating charges between companies while considering units. Additionally, there is a cautionary note about consulting experts for real-life applications, particularly regarding medication dosages, as mathematics alone may not suffice. The conversation highlights that the query is related to a homework problem rather than a practical scenario.
rose ah
1 .You want to have a 30 m2 room in your house retiled. A company called Wasta Tiles will do it for $50
per m2
. Another company, Zaki Floors, will do it for $4 per ft2
. Which company has the lower price?
Justify your answer using the factor label method. 1 m2 = 10.8 ft2
2. A patient needs 0.50 mg of a certain drug per 10.0 pounds of body weight. Each pill contains 4.00 mg of
the drug. If the patient weighs 73.0 kg, how many pills should the patient be given? (1 kg weighs 2.2
pounds). Use the factor label method
1 kg weighs 2.2 pounds
Kindly help me out
rose ah said:
Kindly help me out
You need to show some work first. For instance, please tell us in your own words, what is the "factor label method".
For 1: Money charged by one company is already given. Calculating the charges by the other company (while keeping the unit in mind) will solve the problem.
For 2: Consult an expert! Only Mathematics is not sufficient to know the correct dosage of a medicine!
This is a homework problem, not a real-life case.
Likes topsquark and rose ah
