Cooling/heating temperature rate change
Cooling and heating rates of different materials at the same temperature depend on their heat capacity and thermal conductivity. More viscous liquids may not cool at the same rate as less viscous ones due to these properties. Heat capacity is influenced by the molecular structure and degrees of freedom of the material. Thermal conductivity, while more complex, also plays a significant role in how quickly a substance can transfer heat. Overall, understanding these factors is essential for predicting temperature changes in various materials.
Ihaveaquestion
Ok, so I could do an experiment on this first, but I decided to see if anyone knew beforehand. So basically my question is will different properties of the same temperature, exposed to the same temperature, cool/heat at the same rate? For example would a more viscous liquid cool as fast as less viscous liquid of the same temperature undergoing the same cooling? I could use other examples but I think you get the gist. Also, I would appreciate explanations instead of just "yes" or "no". I know my question is very broad, but I appreciate any replies. Thanks.
Science news on Phys.org
Drakkith said:
That all depends on the heat capacity and the thermal conductivity of the material. In general, the more degrees of freedom the molecules making up the substance have, the greater the heat capacity. See here for more info: https://en.wikipedia.org/wiki/Heat_capacity#Factors_that_affect_specific_heat_capacity
Thermal conductivity is much harder to explain. At least for me. Try this article: https://en.wikipedia.org/wiki/Thermal_conductivity#Influencing_factors
I am still confused :/ I should mention that I have no knowledge in physics and very minimal in math. I am not super smart or anything either, just a very curious person lol.
Unfortunately I don't think I'll be able to explain any better that those links. Perhaps someone else here can.
All good. I appreciate you trying to explain to me.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
