Correct Derivation of the Adiabatic Condition? (PV Diagram)
The discussion focuses on deriving the adiabatic condition using the First Law of Thermodynamics and the Equipartition Theorem, leading to the relationship between pressure and volume in an adiabatic process. It establishes that adiabatic processes can be represented by the equation PV^(5/3) = constant, contrasting with isothermal processes represented by PV = constant. The participants debate the steepness of adiabatic curves compared to isotherms, suggesting that adiabatic processes involve temperature changes that necessitate steeper paths on a PV diagram. They acknowledge that while the constants in the equations are dimensionally different, the comparison of steepness is valid when considering logarithmic representations. The conversation concludes with a suggestion to analyze the derivatives of the equations for a more rigorous understanding of the relationship between pressure and volume in both processes.
PhDeezNutz
Derive the condition the Adiabatic Condition ##PV^{\gamma} = \text{constant}## for a monatomic ideal gas. I believe ##\gamma = \frac{5}{3}##.
Equipartition Theorem:
##E = \frac{3}{2} NkT \Rightarrow \Delta E = \frac{3}{2} Nk \Delta T##
Ideal Gas Law:
## PV = NkT \Rightarrow P \Delta V + V \Delta P = Nk \Delta T ##
First Law:
##\Delta E = Q - W ##
Adiabatic:
##Q = 0##
By the First Law, Definition of an Adiabatic Process, and Definition of Work:
##\Delta E = Q - W = - W = - P \Delta V ## (because ##Q = 0##) (Equation 1)
By the Equipartition Theorem:
##\Delta E = \frac{3}{2} Nk \Delta T ## (Equation 2)
By Setting Equation 1 equal to Equation 2
## \Delta T = - \frac{2P}{3Nk} \Delta V## (Equation 3)
Differential Form of Ideal Gas Law:
##P \Delta V + V \Delta P = Nk \Delta T## (Equation 4)
Plug Equation 3 into Equation 4
## P \Delta V + V \Delta P = Nk \Delta T = - \frac{2P}{3} dV## (Equation 5)
So getting rid of the middle man
## P \Delta V + V \Delta P = - \frac{2P}{3} dV## (Equation 6)
Moving the LHS over to the RHS we have
##\frac{5}{3} P \Delta V + V \Delta P = 0## (Equation 7)
This can be stated another way
## \frac{\Delta P}{\Delta V} + \frac{5}{3} \left( \frac{1}{V} \right) P = 0## (Equation 8)
Equation 8 can be re-written in a calculus friendly way and we can use some basic methods of Differential Equations to solve for ##P## as a function of ##V## or just stop a step before doing that and establish ##PV^{\gamma} = \text{constant}##
## \frac{ dP}{dV} + \frac{5}{3} \left( \frac{1}{V} \right) P = 0## (Equation 8)
multiply through by integrating factor ##\mu = e^{\int \frac{5}{3V} \,dV} = e^{ln v^{\frac{5}{3}}} = v^{\frac{5}{3}}##
## v^{\frac{5}{3}} \frac{ dP}{dV} + \frac{5}{3} \left(v^{\frac{2}{3}} \right) P = 0## (Equation 8)
We recognize the LHS as the derivative of ##PV^{\frac{5}{3}}## So
##\frac{d}{dV} \left( PV^{\frac{5}{3}}\right) = 0## (Equation 9)
So
##PV^{\frac{5}{3}} = \text{constant}## (Equation 10)
of course if we really wanted to we could say
##P = \frac{\text{constant}}{V^{\frac{5}{3}}}##
Hopefully I didn't play too fast and loose with derivatives ##d## and full changes ##\Delta##, thanks in advance for any help/guidance.
If the above work is correct, how can we establish that "Adiabatic process on the PV diagram are steeper than those of isotherms".............after all we don't necessarily know what each "constant" is in
##PV = \text{constant}_1 ## (Isotherm)
##PV^{\frac{5}{3}} = \text{constant}_2## (Adiabat)
Are ##\text{constant}_1## and ##\text{constant}_2## the same?
Maybe this is too simplistic but maybe it will get some ideas rolling
if we have two parallel isotherms (they have to be parallel at least locally for a given ##V##) to get from one to the other ##T## has to change. The only way to get from one ##T## to another ##T## (i.e. from one isotherm to another) is to follow a path that connects the two isotherms which is necessarily steeper than either isotherm.
It is meaningless to ask if they have the same value since they are dimensionally different.
The claim that one is steeper then the other would make sense on a log-log chart.
Fair but what about my reasoning in post 2?:
If isotherms are parallel and in adiabatic processes ##T## changes then adiabats must "travel between" isotherms making them necessarily steeper?
I will ponder your log-log argument and respond.
That's probably valid, but you can also get there by writing down the equations for how P depends on V in the two cases, taking the derivatives, evaluating at ##(P_0, V_0)##and taking the ratio.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 27 ·
