Dampening force - find decrease in amplitude
The discussion revolves around calculating the damping force and its effect on amplitude in a damped harmonic oscillator. The user initially calculates the damping coefficient 'b' as 0.129378 using a specific equation. However, when applying this value to a different mass of 17.7 kg, the resulting amplitude is 50%, which is inconsistent with the expected 59.6%. The user highlights that the amplitude decreases to 45.4% of its initial value, indicating a discrepancy in the calculations. The conversation emphasizes the importance of correctly applying the damping formula to achieve accurate results.
JoeyBob
see attached
w=sqrt((k/m)-(b/(2m))^2)
Amplitude = (Amax)e^((-b/(2m)t)
So first I tried to find b.
0.454=(0.6)e^((-b/(2*11.6)*50)
Anyways with some natural log algebra etc. I get b = 0.129378
But when I plug this into the same equation only changing mass to 17.7 kg I get 0.4998 or 50% when the answer should be 59.6%?
The amplitude decreases to 45.4% of its initial value. So, the final amplitude is not .454
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
