Dark matter interactions other than gravity
In summary: Chemistry and "ordinary" matter here on Earth are well understood. You cannot invoke a dark matter halo around the chemical elements without completely undermining chemistry. Terrestrial chemistry is not the puzzle where experiment does not reflect the theory.2) The motion of galaxies is a puzzle - leading to the hypothesis that there might be dark matter (as well as what we have on Earth). Because, without it, galaxy dynamics do not match the theory.3) If dark matter were here on Earth (in significant quantities) then everything would weigh more than it should. Copper sulphate, for example, would not weigh what it is supposed to weigh by adding... copper sulphate.
jake jot
302
https://phys.org/news/2018-04-dark-interactive.html
"Observations using the Hubble Space Telescope appeared to show that a galaxy in the Abell 3827 cluster - approximately 1.3 billion light years from Earth - had become separated from the dark matter surrounding it.
Such an offset is predicted during collisions if dark matter interacts with forces other than gravity, potentially providing clues about what the substance might be."
If dark matter interacts with forces other than gravity, why is the galaxy expected to be separated from the dark matter surrounding it?
If a baryonic atom indeed has some interaction with dark matter. Are there no tests that can disprove the theory? or our particle detectors not yet sensitive to detect them like the inability to detect gravitons?
Likes Abhishek11235 and STEM_nerd
Space news on Phys.org
My understanding is that the "offset" as you call it, is predicted if dark matter does NOT interact other than gravitationally. Google "Bullet Cluster"
"However, the same group of astronomers now say that new data from more recent observations shows that dark matter in the Abell 3827 cluster has not separated from its galaxy after all. The measurement is consistent with dark matter feeling only the force of gravity. "
If dark matter feel other forces, why would the cluster separate from its galaxy? I don't understand even after reading about bullet cluster.
Asked and answered.
phinds said:
Asked and answered.
You answer was simply "bullet cluster".
Now let's zoom in from macro to micro. Perhaps others who know the answer can chime in.
If dark matter had interaction (theoretically) with baryonic matter, does it mean my bed has dark matter attached to it? Or a single hydrogen atom has an attached atom of dark matter? This aspect is still open and no observations or data in particle physics has falsified it?
The mass of a hydrogen atom is known to a high degree of precision.
I haven't read much more than the introduction to the original 2015 paper, but it actually appears to be talking about self interacting dark matter, not interaction between normal and dark matter.
If I understand correctly, the principle is that when galaxies collide the stars don't slow each other down because they're pretty close to point-like and they just fly past each other. Gas clouds, however, are large and diffuse and experience drag so would lag behind the stars after a collision. Non-interacting dark matter would not experience drag and would keep up with the stars; weakly interacting dark matter would have a bit of drag and would lag a bit behind the stars but not as much as the gas.
The 2015 paper linked above had some evidence for a galaxy's dark matter being off-center, hence implying dark-matter-dark-matter interaction. The update being discussed in the article linked in the OP suggests that the apparent offset was a measurement artifact and hence that dark matter does not interact even with itself.
If there was a dark matter attached to the hydrogen atom, it would weight differently?
But in superstrings theory like E8xE8, there was shadow matter attached to matter. So why did they not use the argument the hydrogen atom was known to a high degree of precision hence shadow matter couldn't exist?
No, my answer was in the sentence before "bullet cluster". The BC was just offered as an example of my answer.
Of course it would, we'd notice if hydrogen was attached to other stuff that had mass. Here's the thing:
1) Chemistry and "ordinary" matter here on Earth are well understood. You cannot invoke a dark matter halo around the chemical elements without completely undermining chemistry. Terrestrial chemistry is not the puzzle where experiment does not reflect the theory.
3) If dark matter were here on Earth (in significant quantities) then everything would weigh more than it should. Copper sulphate, for example, would not weigh what it is supposed to weigh by adding up the copper, sulphur and oxygen. It would have the additional mass of all the dark matter as well.
Why can't mirror matter, if it existed, produced the above effects on chemistry too?
https://en.m.wikipedia.org/wiki/Mirror_matter
"However, parity symmetry can be restored as a fundamental symmetry of nature if the particle content is enlarged so that every particle has a mirror partner. The theory in its modern form was described in 1991,[6] although the basic idea dates back further.[2][7][8] Mirror particles interact amongst themselves in the same way as ordinary particles, except where ordinary particles have left-handed interactions, mirror particles have right-handed interactions. In this way, it turns out that mirror reflection symmetry can exist as an exact symmetry of nature, provided that a "mirror" particle exists for every ordinary particle. Parity can also be spontaneously broken depending on the Higgs potential.[9][10] While in the case of unbroken parity symmetry the masses of particles are the same as their mirror partners, in case of broken parity symmetry the mirror partners are lighter or heavier.
Mirror matter, if it exists, would need to use the weak force to interact with ordinary matter. This is because the forces between mirror particles are mediated by mirror bosons. With the exception of the graviton, none of the known bosons can be identical to their mirror partners. The only way mirror matter can interact with ordinary matter via forces other than gravity is via https://en.m.wikipedia.org/w/index.php?title=Kinetic_mixing&action=edit&redlink=1 of mirror bosons with ordinary bosons or via the exchange of https://en.m.wikipedia.org/w/index.php?title=Holdom_particle&action=edit&redlink=1.[11] These interactions can only be very weak. Mirror particles have therefore been suggested as candidates for the inferred dark matter in the universe.[12][13][14][15][16]"
As you can see in the above article on mirror matter which they proposed can be dark matter. It means ordinary matter can have a mirror matter (or dark matter) halo around the chemical elements.
So when you stated it couldn't happen. Is your context got to it dependent on say electromagnetic field that bind baryonic chemical elements to the dark matter?
In the quote below
"With the exception of the graviton, none of the known bosons can be identical to their mirror partners. The only way mirror matter can interact with ordinary matter via forces other than gravity is via https://en.m.wikipedia.org/w/index.php?title=Kinetic_mixing&action=edit&redlink=1 of mirror bosons with ordinary bosons or via the exchange of https://en.m.wikipedia.org/w/index.php?title=Holdom_particle&action=edit&redlink=1.[11] "
Why does kinetic mixing or exchange of Holdom particles not cause any undermining of chemistry?
Thread closed for moderation.
FAQ: Dark matter interactions other than gravity
1. What is dark matter and how does it interact with other forces besides gravity?
Dark matter is a hypothetical form of matter that is thought to make up approximately 85% of the total matter in the universe. It does not interact with light, which is why it is invisible and difficult to detect. While gravity is the primary force that dark matter interacts with, there have been theories and studies that suggest it may also interact with other forces such as the weak nuclear force and the electromagnetic force.
2. How do scientists study dark matter interactions other than gravity?
One way scientists study dark matter interactions is through astronomical observations of galaxies and their movements. By studying the rotation curves of galaxies, scientists can infer the presence of dark matter and its effect on the gravitational pull of the galaxy. Other methods include particle accelerators and underground detectors that search for evidence of dark matter particles interacting with normal matter particles.
3. What are the potential implications of dark matter interactions beyond gravity?
If dark matter is found to interact with other forces besides gravity, it could provide important insights into the nature of this mysterious substance. It could also help explain some of the discrepancies between observations and predictions made by the current understanding of dark matter. Additionally, understanding dark matter interactions could have implications for our understanding of the fundamental laws of physics.
4. Are there any experiments currently underway to study dark matter interactions?
Yes, there are several experiments and projects currently underway to study dark matter interactions. These include the Large Hadron Collider, the Dark Energy Survey, and the Large Synoptic Survey Telescope. These experiments use a variety of methods to search for evidence of dark matter interactions, such as colliding particles, observing galaxy clusters, and mapping the distribution of dark matter in the universe.
5. Could dark matter interactions other than gravity be the key to unlocking the mysteries of the universe?
It is possible that understanding dark matter interactions beyond gravity could provide important insights into the mysteries of the universe. However, it is just one piece of the puzzle and there are likely many other factors and forces at play. Further research and experiments are needed to fully understand the role of dark matter in the universe and its potential interactions with other forces.
