Dawn dead in Ceres orbit, ran out of fuel Oct 2018
  • I
  • Thread starter marcus
  • Tags
    Fuel Orbit
In summary, the Dawn spacecraft observed Ceres for an hour on Jan. 13, from a distance of 238,000 miles (383,000 kilometres). A little more than half of its surface was observed at a resolution of 27 pixels. This video shows bright and dark features.
  • #281
marcus said:
At our distance from sun (AU) without atmosphere greenhouse etc. I think the equilibrium temp is about 255, I could be wrong. So roughly, 60% of that is 153 K. around 168 K. Sort of what one would expect. Maybe the fact that it is a bit warmer has to do with the difference in albedo. Ceres absorbs over 90% of the incident sunlight.
I see.
Maybe it's chock full of water, so it holds a lot of heat?
Astronomy news on Phys.org
  • #282
mfb said:
I did that about a month ago and attached the excel file in my post back then. Thrust and motion are not well aligned right now - they still have to change the orbital plane a bit (and the detour allowed to do so very well as Dawn is so slow). Starting April 4th according to the numbers, thrust will get more and more against the flight direction, one week later its acceleration is well aligned with the flight course (in opposite direction of course).
Distance 71010km, speed 52 mph (84km/h, 23m/s) in three hours.
I've a Mac, and am curious if your Excel spreadsheet had more than one "tabelle".
I only got one tabelle, and the plot for the x velocity was very dirty.
The curve fit though, which I derived from the data from tab 1, shows an x direction switch on April 6th, which closely matches your April 4th remark, and Marcus's observation from the latest video.
  • #283
The velocity values are from leptrich.
What is special about the x direction?
  • #284
I think I chose the x direction, because I assumed it had the least amount of error.
Also, I'd like to convert all of the coordinates to polar notation, and rotate the entire system, as it looks as though Dawn will enter the orbital plane around April 2nd.
Which makes me very suspect of the "what a waste of xenon!" z thrust velocity graph:
Day zero = Feb 20_____________________________________________ Day 60 = April 20
The smoothed line crosses the y zero on ≈February 27th and ≈April 12th.I suppose the evil Dr. Rayman planned this from the very beginning, as he somehow knows I haven't translated a 3D coordinate system in my life, and it's about time I learned how.
His "Dawn Journals" are also currently offline. He posted several new comments on March 26th. One of which was an explanation of why they were powering in, rather than just coasting.
I check his journal daily.
[edit - 18 minutes later] His journal is back up. I told you he was evil...
  • #285
The comment I was referring to:
Tim G says:
March 26, 2015 at 6:36 am
Marc, the MYSTIC simulator indicates that Dawn’s
specific orbital energy, v^2/2 -GM/r, has been creeping up.
I noticed that it dipped below zero on March 6th when the mission
planners celebrated Dawn’s capture.
Is this related to saving time because saving xenon propellant isn’t the only issue?
Marc Rayman says:
March 26, 2015 at 11:46 am
Hi Tim,
...Rest assured, however, that Dawn is securely in orbit and is not going to leave. (So its orbital energy will remain negative.)
You are quite right that the energy is increasing... To summarize, Dawn would naturally fall toward Ceres after reaching the high point of its elliptical orbit ..., but we use the ion engine to accelerate toward Ceres even faster. We have plenty of xenon and there is no need to conserve it this late in the mission. So we reduce the time it takes to travel to lower altitude (which is part of what we have to do to reshape the orbit into RC3) by propelling the spacecraft toward it. You can also see this in the animation above of the approach trajectory. Note how the thrust does not reverse quite when Dawn reaches that maximum orbital altitude. Rather, the ion beam is still directed away from Ceres, meaning the ship is still pushing itself toward Ceres. Only after it has accelerated its descent does it thrust in the reverse direction to brake smoothly into its low, circular orbit.
Edited for brevity, and bolding for cheer factor. :smile:
  • #286
As to OmCheeto's noisy graph, that's a problem with calculating numerical derivatives. Doing so magnifies errors. That's why I used a filter function that uses 4 neighbors instead of 2 neighbors. Another way of reducing noise is to fit the numbers to some curve, like a cubic spline, and then take derivatives of that curve.
  • #287
I have no idea what you just said.
But, I kind of enjoy the "schmootzig" data.
Looking at a spreadsheet of numbers doesn't really do much for me, so I convert everything into graphs, and try and figure out what the "further" smoothed graph numbers mean.
For instance, I've been plotting Dawn's speed in relation to Ceres since March 9th. The graph is very linear.
About all this tells me though, is that the acceleration of Dawn, directly towards Ceres, has been virtually constant.
Boring! (Ok. Only after I thought about it for a few hours.)
So I plotted the y intercept numbers since March 20th. There was a notable change in slope on March 24th.
I have no idea how to interpret this, other than; "Om. It's time, once again, to engage your brain".
  • #288
OmCheeto said:
And I've heard that interstellar space has a temperature equivalent to that of the sun.
didn't believe it when I saw it. (It was here at PF)
I googled it.
It's true.
I found that surprising so I googled it too. Weird as it sounds, according to https://en.wikipedia.org/wiki/Interstellar_medium it's true - within the Milky Way most of the interstellar medium is at >6000K, and about half is coronal gas at >106K. Clearly not at equilibrium with the CMB...
Now within the solar system in our neighborhood I suppose this translates to :
- an extremely dilute coronal gas at >106K
- a gas of photons flowing out of the sun, at ~250K
And the effective temperature from averaging both would be ~250K
Is that right?
Still sounds weird that in the ISM the coronal gas would win over the photons. I suspect that the ISM temperature reported is just its matter temperature, and its average effective temperature is actually close to 3K.
  • #289
I hope this doesn't come off as too off topic. I have been enjoying thinking about Dawn all week, just picturing that machine out there. And I for one have been mulling over the temperature problem. I'm hung up on the idea that they could possibly find liquid water and life friendly chemistry if not even life itself on an... asteroid. I hate to get excited about aliens, but my first thought was, "I hope they find an old freaking fort"
But more seriously, it's exasperating because there is my intuition, which I trust not one bit, or maybe one bit, but not enough, and I'm trying to study other topics, and realize I don't even understand... Temperature in outer space. And for me learning is about answering questions, when they occur.
So thermal energy in "space" (not including the Unruh effect etc) is driven by EM radiation from any EM sources visible. Plus if there is a gas or plasma, like the "solar wind" or the Interstellar Medium add that? BTW, I thought the Interstellar Medium didn't come into the picture until well past Pluto, at the "heliopause"? Is that wrong? So then the object's temp is a function of its reflectivity/absorptivity at the the EMR wavelength, then some degree of thermal conductivity or kinetic heat transfer efficiency at the interface to the passing warm mass (gas/plasma) and the surface area, but then also it's "specific heat" at equilibrium, which is going to correlate with density and mass to some degree, material composition, then also (and this is where I really don't trust my setup) there is the objects own "Black Body" emissivity or power. But what is the primary variable in final equilibrium? Is it only the uneven-ness of exposure to the sources (daylight/night, kinetic flux windward/leeward) or is it just going to match the sources eventually, carrying some bit of constant thermal mass. Is there a strong way to estimate final equilibrium temp?
There is that one innocuous sentence in the wiki about it being "relatively warm", but to a real planetary scientist, is Ceres Temperature interesting from the physics? Or as Marcus says, it's around expectation. Are other potential sources, like geologic activity (in an asteroid?) or some exothermic chemistry ruled out? Could the somewhat rare latent heat carrying cap of liquid water explain higher equilibrium or lower day/night cycle variance? I know that cryo-volcanism is a thing with comets, but is it common in objects with relatively stable orbits, without geologic activity. I guess I don't even know if Ceres orbit is that round.
Sorry that's a lot o questions. Just wanted to share...
  • #290
Is that right?
This might be a counterexample to sophiecentaur's quote; "The enemy of understanding is classification."
Temperature in the ISM may need a different classification.
I learned long ago that temperature was defined as; "The average internal translational kinetic energy", or something like that.
For solids, liquids, and gasses, this kind of makes sense to me.
It's the average jigglinesss.
But in both the interstellar, and intergalactic mediums, it makes less sense to me, as it strikes me more as particles moving at ungodly speeds.
And it appears we are getting a bit off topic. I would imagine @marcus could direct us to the appropriate thread for such a discussion.
[edit]I found one. D H's comment kind of looks like what I was trying to say.
I'm currently interested in learning more about the surface temperature variations on Ceres, and if my theory* holds up.
*I haven't posted it, as it's pure speculation. It's more based on my observations, and head scratching, regarding comet 67P. But it may be relevant to Ceres.
  • #291
I think your image shows yet another kind of temperature, related to vibrations within a molecule. ISM temp is probably just ordinary gas temperature, related to the kinetic energy of the gas molecules (or atoms, or ions).
As to Ceres, is its temperature different from the one quoted by Marcus from equilibrium with solar light?
  • #292
Not sure if you noticed that I added an edit to my above post. Very interesting thread.
Marcus at one point shoved 400,000,000 photons into a box, and said that was a temperature also.
I think.
marcus said:
...To recap what was said earlier in the thread, space has about 400 million CMB photons per cubic meter. And those photons have a near-perfect thermal distribution, with a temperature of 2.728 kelvin.
As to your question, I'll have to look at that later. Chat trivia is starting in about 11 minutes.
  • #293
According to current status (fullview2) Dawn is already beginning to flip around. Fullview shows it's ionized tail pointing more down today (down meaning Ceres south, i.e. solar system orbit plane south.)
After a few days of more "upwards" thrust then according to Om's timeline trajectory, and the somewhat impressionistic animated movie we saw, it will turn some more and have the thruster tail pointed more sunward and towards Ceres, to slow its fall.
Current status says distance is now 62 kkm and speed about 2.8 kkm per day.
Angular size must be getting close to one degree (if I remember right that occurs at 54 kkm.)
  • #294
Marc Rayman has a new Dawn Journal
http://dawnblog.jpl.nasa.gov/?p=2437
dated 31 March 2015
In it he gives distance to Ceres as 57 kkm, this is closer than the estimate we got from the current status simulated views. He also notes that distance peaked out (apoapsis) at around 75 kkm on 18 March, which is also nearer Ceres than what we were seeing (which was around 78 kkm).
So we might want to mentally deduct some 3 kkm from the current status figure for a while.
An interesting note on the first circular orbit (called "RC3", after that come "survey" "HAMO" and "LAMO" successively closer in). The altitude of RC3, 13,500 km, was chosen because at that height Ceres will just fill the camera's field of view.
From the nearer orbits, Dawn's camera will not see the full disk, but only limited patches at higher resolution.
BTW RC stands for "rotation characterization". By photographing the full disk over an extended period of a few hours they can determine Ceres rotation axis. The intent is to have Dawn orbiting right over the poles.
And also to have its orbit plane veered a few degrees off the sunwards direction (clockwise seen from above north pole.) The clockwise skew is to make sure that Dawn never passes through Ceres shadow because then it would lose electric power.
The simulated views already show Dawn has stopped thrusting *towards* Ceres and is beginning to adjust orbit plane, preparing for eventual circular polar orbit, angled slightly off the sun. It is thrusting "north" and slightly aft. Sort of in an 11 o'clock direction in the simulated view frames.
http://neo.jpl.nasa.gov/orbits/fullview1.jpg
http://neo.jpl.nasa.gov/orbits/fullview2.jpg
If Ceres were added to the Sun view frame (fullview1) it would be about where the letter "a" is in "relative to Sun" at the bottom edge.
Only a sliver of the upper rim of Ceres is illuminated, from Dawn's perspective. The sun is behind and a few degrees (about 20 degrees) above Ceres.
Likes OmCheeto
  • #295
dated 31 March 2015
It's the first thing I check for, every morning. :smile:
A couple of things I did after reading it, was go back to my spreadsheet and add the orbital revolution times for the 4 upcoming orbits, and double check if I was using "center of mass" vs "surface" for my distances for the orbits.
I immediately noticed that my HAMO numbers were off from those in today's journal.
Since January, it looks as though we've had the altitude listed as 1740 km, and it should be 1470.
Not that big a deal, as it will be the end of July before Dawn gets to that orbit.
And I'm not sure if the following differences in numbers are a change of plans, or just non-nerd PR.
April 30, 2014 Journal
Dawn will follow a tighter spiral down to the (misleadingly named) high altitude mapping orbit (HAMO) at 910 miles (1,470 kilometers).
In todays journal, it is listed at 900 miles (1,450 km)​
  • #296
I have an overwhelming urge to send Dr. Rayman a bunch of questions.
But he seems to be a bit busy, and want to pick the best one.
What does everyone think?
1. Apodemeter
I don't mean to sound like Sgt. Friday, but why was Dawn communicating with the DSN between the hours of approximately:
Mar 17, 2015, 06:25 UTC: Start
Mar 18, 2015, 11: 00 UTC: Stop​
28.5 hours!
Parallax?
Doppler shift in carrier signal?​
2. HAMO altitude changed from 1470 to 1450 km in this blog.
Is this a change of plans, or just non-nerd number smoothing?​
3. Orbital plane.
When is Dawn predicted to enter it?​
4. Ice Carrots.
Is there a possibility that the headlights are "Ice Carrots"?
(Yes, we've all googled "complex impact crater morphology", but Easter is coming up!)​
  • #297
OmCheeto said:
... want to pick the best one.
3. Orbital plane.
I'd be most interested in knowing more about the time-table and manner of Dawn getting into the right orbit plane. the plane can't be be exactly in line with the sun direction (else Dawn would fall in shadow during orbit). It has to be turned "clockwise" (looking down on Ceres north pole) by some 5 to 7 degrees. It looks to me like this will involve a complicated maneuver---a slightly "S-shaped" approach.
As it stands, if the probe comes straight in, without that kind of weaving or zig-zag maneuver, it would get into an orbit plane that was actually turned slightly COUNTER-clockwise relative to sun direction, seen looking down along Ceres rotation axis.
BTW I see that current status (fullview2) shows the probe in communication mode this morning with thruster turned off. But when I checked DSN I did not see any antenna talking with Dawn at that time.
You mentioned doppler measurement of the carrier wave. I think that is what Rayman means by "radio-navigation". It's remarkable that they can derive useful info about where the probe is and where it's going by keeping track of radial velocity relative to Earth stations, by doppler.
Loathe to seem nitpicky about spelling but we shouldn't offend adherents of Greek&Roman pagan religion by misspelling the goddess Demeter's name. Better edit and change "dometer" to "demeter" lest you incur the wrath of the goddess.
(Yes, we've all googled "complex impact crater morphology", ...)
Nice link. The Wippykidia referenced a book
http://www.lpi.usra.edu/publications/books/CB-954/CB-954.intro.html
and I found interesting diagrams and discussion of the central uplift formation in large craters---chapter 3 page 26
http://www.lpi.usra.edu/publications/books/CB-954/chapter3.pdf
  • #298
I see from current status that distance is 54 kkm which corresponds to angualar size of 1 degree.
  • #299
Along with capturing distance, speed, thrust status, and communication status, two to three times a day, I've also been capturing the images.
Using lpetrich's digitizer, I should be able to determine when Dawn enters the orbital plane, if it hasn't already.
As of this moment, 16:11 UTC (19:11 PDT), Canberra #34 and Goldstone #15 indicate carrier signal. When I checked about an hour ago, 15:03 UTC, Canberra #34 was in standby.
I'd like to see an article on "radio-navigation". Perhaps I'll google that later.
Unfortunately, my timeframe for editing has expired. I wonder, if I'm very polite, and offer them cookies, that one of the mentors would edit my post:
1. Apodometer ( <-- -1sp. Bad Om!) Apodemeter
I looked at a few "complex crater" references, but chose the wippykidia link as general reference.
I think I steered away from the others, as I think the craters on Ceres will need to have a new book written about them. To my knowledge, nobody has seen "headlights" before.
How does the central peak in moon craters form? (re: Tycho Crater on Earth's moon)
Kepler Crater - Central Peak (NASA, Earth's moon)
Complex craters occur above a certain diameter crater, the cutoff diameter is dependent on gravity, so it varies from planet to planet (or moon to moon).
Despite the label "central peak," a central peak is not always exactly in the center of a crater, nor is it always symmetrically shaped; Kepler crater is an example. Instead of having a nice central peak, Kepler crater has an irregular off-center peak. This form is most likely due to the crater being close to the boundary diameter between a simple and complex crater. Larger craters, such as King crater, can also display oddly shaped central peaks that are likely the result of an oblique impact.
Update! 16:47 UTC
Canberra #34 and Dawn are now in two way communication mode.
Goldstone #15 is in Dawn standby.
[update edit] 16:52 UTC
Goldstone #15 is no longer assigned to Dawn[/edit]
[update edit] 17:12 UTC
Just checked my spreadsheet from the last time I did "OmNav" triangulation calculations, and saw this note:
"forget it. this is impossibly hard."
I interpret this as; "Don't hold your collective breathes, for me to figure out the entry time into orbital plane." [/edit]
[update edit] 20:32 UTC
Canberra #34 and Dawn are still in two way communication mode.
Und, viele dank, mfb. :bow:
Mein schwester wurd in Deutschland in sechs wochen. She will gladly give the cookies, for which, I will pay her for, on Dienstag.
[/edit]
Likes marcus
  • #300
Cookies!
210% size of moon now (full moon in 15 hours, and the moon is close to apogee).
Likes marcus and OmCheeto
  • #301
From my calculations, it occurred at around 6 am this morning, PST.
4/4/2015 13:00:00 UTC.
But, as everyone knows, my math sucks.
ps. I was going to submit the question to Dr. Rayman, but the dawnblog is down, again...
Stinkin' Californians. How dare they, take weekends and holidays off. Pfft! :oldgrumpy:
  • #302
The current view:
Slightly askew, but close enough for me.
Directly below Ceres, in the above image, is Sirius.
Here's a digitization I did over the weekend:
I don't know the names of the stars, but they are in some obscure constellation called Monoceros.
Likes marcus
  • #303
44.32 Mm at 21:17 UTC (101 mph) - probably less as we know the web interface is not accurate.
That is close to the previous closest approach at ~38 Mm.
The next picture is scheduled for April 10 at ~33 Mm - just a crescent, but closer than ever before.
Likes OmCheeto and marcus
  • #304
Thanks for the update, Mfb. I'll bring forward Om's timeline trajectory to have it handy for reference. The diagram gives two different views of the same trajectory, from different angles. In each case the sun is way off to the left, in the upper picture Ceres' orbit motion is INTO the page, in the lower picture we are looking down on Ceres' orbit plane and Ceres' motion is upwards on the page.
If you are just joining us, the red dots on the timeline are where photos of Ceres are taken and transmitted back to Earth. So in the upper picture you can find the red dot that comes three day-circles after 7 April, and is labeled 33 thousand km, or 33 kkm.
The picture will be taken from the dark side of Ceres, so it may not show very much. Main interest might be simply for navigation purposes, because it will show the stars in the background and help the navigators figure out where the spacecraft is in relation to Ceres.
  • #305
Dawn now sees Ceres right beside the star Sirius. Recall just a short while ago it saw Ceres in the belt of Orion? It has changed the angle of view quite a bit. (As I understand it, getting ahead of in Ceres orbit direction)
I can't believe that Dawn is in the final orbit plane yet.
The sliver of sunlit edge on Ceres is up and increasingly the right, like in the ONE o'clock position.
As I understand it, when Dawn finally gets in the correct orbit plane, and is approaching from outwards (anti-sun direction) then the sun must be on the Dawn's left, 5 degrees to the left of Ceres. The crescent sliver will then be more in the ELEVEN o'clock position, not the one o'clock. To me the position of the sunlit sector of the rim is a sign that she is not yet in the proper plane
the simulated view is looking good. Ceres is bigger.
Om, notice that in simulated view http://neo.jpl.nasa.gov/orbits/fullview2.jpg the blue green ion tail looks much SHORTER now. This is due to foreshortening because it is pointed much more at Ceres now. Dawn is trying to slow down so as not to arrive too fast to slip into orbit.
The tail is also a little down and to the right.
To the right because Dawn wants to get over to the left so that it will see the Sun 5 degrees to the left of Ceres. Only then will it be in the proper orbit plane.
  • #306
According to my last PM from Dr. Rayman, it appears you are correct:
Sent to his blog:
Hi Marc,
Do you happen to know when Dawn entered the orbital plane?
Thanks!
Om
His last response (he's apparently forgotten that I warned him no to correspond with me, as I can be a bit of a pest):
Hi Om,
I prefer not to take the time to explain your question to readers of the blog, so with your permission, I'll simply give you a quick response here. Dawn's ion thrusting to RC3 changes the plane along with the radius right to the very end of thrusting. So, Dawn reaches the RC3 orbital plane when it reaches the RC3 orbital radius.
Is that what you are asking?
Marc
Then I yelled at him; "No!"
Probably not a good idea.
Orbital mechanics is probably over my head.
As I explained to Dr. Rayman, all I wanted to know when Dawn reached the "red dot".
Sirius and Saiph have been tracking linearly since around April 3rd.
How much more planer(?) 2 dimensional can this get?
  • #307
Om,
have an appointment and must go out momentarily---just saw your post. Can't answer but will give my own impressions:
distance is now 35 kkm something, under 36.
Dawn is retrothrusting, you almost cannot see the ionized tail because it is pointing nearly at Ceres.
Ceres is to the LEFT of Sirius for the first time today (if I remember correctly). Remember it used to be way over to the right in Orion belt?
Ceres still moving left against background means Dawn is still drifting RIGHT, which means it is still getting ahead in Ceres orbit direction. This has to stop. To be in the correct orbit plane it has to come in slightly from behind (by about 5 degrees).
So at sometime in next 10 days Dawn will have to start drifting left, in the picture, which will make Ceres drift right against the starry background.
But for now the main job is retrothrusting, to slow the fall towards the mini-planet.
  • #308
Can Dawn by imaged at all by Hubble, perhaps with the ion thruster on? Resolution is nowhere close (the moon is 43 meters/pixel HST), but I can't lay hands on the information to determine the ion luminosity could light up a pixel.
  • #309
Ceres emits some tens of terawatts of light power and still is at best at magnitude 6.6.
I guess the "most" visible would be the few kW of thermal power emitted by the probe itself, making Dawn a magnitude ~30 (?) object but in infrared only. Hmm, not so far away from the visibility limit, but Ceres is probably way too bright compared to Dawn nearby.
The emitted xenon is too thin to be relevant (Dawn has ~1kW of power and most of it is used for thrust, not for heating the exhaust).
We reached 300% moon size by the way.
Likes mheslep
  • #310
Mfb, thanks for the update!
I see they have Goldstone antenna #25 talking with Dawn now:
https://eyes.nasa.gov/dsn/dsn.html
and Canberra #45 is standing by for Dawn later today.
The simulated "fullview2" shows the spacecraft with thruster off, oriented in that characteristic way associated with picture-taking and communication.
  • #311
Same situation when I checked 3 hours ago, except that Canberra was not standing by. It is now receiving.
Doh!
Goldstone just shut off.
Canberra is now in two way communication.
I'm going to have to start time stamping my posts when I start them.
Things happen rather quickly around shift change. :smile:
  • #312
They do that! I just checked fullview2 and it shows Dawn back in normal orientation. Picture shoot done. It has probably resumed thrust but we can't see the ion tail in the simulated view because it would be aimed almost directly at Ceres, and thus hidden by the spacecraft itself. Ceres sure looks big for a change! Even see some known surface details.
  • #313
You can see the tail in the http://neo.jpl.nasa.gov/orbits/fullview1.jpg .
I guess the bright greenish thing in the Ceres view is supposed to be the tail, too.
11:17 UTC: 31450km, 117mph (~340% moon)
  • #314
It's also visible in the Earth view.
I was thinking about mheslep's question yesterday, as I knew I'd asked a similar question before.
It turned out to be from January 27th! I can't believe I've been watching this for almost 3 months.
OmCheeto said:
...my question as to why Hubble took such a crumby picture of Ceres...
So I did the maths for Dawn:
Code:
____________________________________________size relative to Ceres
Object________pixels_________degrees________when viewed with Hubble
Andromeda_____284151_________3.16___________15,400
Moon___________46602_________0.52____________2,520
Ceres_____________18_________0.00021_____________1
Crab Nebula_____8727_________0.097_____________472
Dawn_______________0.00038___0.0000000026________0.000021
I'm not sure why my pixel numbers are off by a factor of two.
Somewhere they compared the resolution of Dawn to Hubble, and Hubble came out to 33 pixels for Ceres.
I've seen proclaimed resolutions for Hubble from 0.1 to 0.04 arcseconds.Anyways, I'm getting very excited. Less than two weeks!
Dr. Rayman in his latest blog said:
There will be work to do before photography begins however. The first order of business after concluding ion thrusting will be for the flight team to perform a quick navigational update (this time, using only the radio signal) and transmit any refinements (if necessary) in Dawn’s orbital parameters, so it always has an accurate knowledge of where it is. (These will not be adjustments to the orbit but rather a precise mathematical description of the orbit it achieved.) Controllers will also reconfigure the spacecraft for its intensive observations, which will commence on April 24 as it passes over the south pole and to the night side again.
  • #315
Two new (old but different) images were posted today on NASA's Photojournal.
These images, from Dawn's visible and infrared mapping spectrometer (VIR), highlight two regions on Ceres containing bright spots.
The top images show a region scientists have labeled "1" and the bottom images show the region labeled "5."
Region 5 contains the brightest spots on Ceres.
VIR has been examining the relative temperatures of features on Ceres' surface.
Preliminary examination suggests that region 1 is cooler than the rest of Ceres' surface, but region 5 appears to be located in a region that is similar in temperature to its surroundings.
Images taken using blue (440 nanometers), green (550 nanometers) and infrared (920 nanometers) spectral filters were combined to create the map.
The filters were assigned to color channels in reverse order, compared to natural color; in other words, the short-wavelength blue images were assigned to the red color channel and the long-wavelength infrared images are assigned to the blue color channel.
I have no idea what any of this means.
