- #841
rcgldr
- 8,875
- 638
Probably an efficiency issue. The propeller has to draw air from somewhere to accelerate the air behind the prop. In order to draw air the propeller has to reduce pressure. If the source of the air came from a diverted flow perpendicular to the prop, the net thrust would be less even though the pressure differential at the prop would be the same, because there'd be a second intake diverting surface in front of the prop with low pressure on the prop side and ambient pressure on the forward side, opposing the thrust. Ultimately the thrust is related to the acceleration of air affected by a prop times the mass of the affected air (the intergral sum of the component parts). The Newton 3rd law pair here is the force exerted by the prop onto the air and the coexistant force exerted by the air onto the prop.A.T. said:I do not understand why zoobyshoe thinks that DDWFTTW could only work if pressure fore of the propeller is reduced.
