- #36
alexepascual
- 371
- 1
DrChinese said:I define realism per Einstein's definition of elements of reality: "A sufficient condition for the
reality of a physical quantity is the possibility of predicting it with certainty, without disturbing the system. In quantum mechanics in the case of two physical quantities described by non-commuting operators, the knowledge of one precludes the knowledge of the other." Or as he also said: "I think that a particle must have a separate reality independent of the measurements. That is: an electron has spin, location and so forth even when it is not being measured."
That, as he points out, is contradicted by the Heisenberg Uncertainty Principle at the micro (quantum) level. So anywhere in which h is relevant, you are talking about that level and I would not expect to see realism. That is because I believe that there is no more "complete" description possible.
But I am not sure how I would translate that into macroscopic realism, except to say that I know it when I see it.
I think the problem is when we try to make a general definition of realism and expect it to work in all circumstances. If you make a separation between the microscopic and the macroscopic, then there isn't so much of a problem. Realism is a concept that was formed before we even knew anything about QM. And eventhough it was disputed by some philosofers, it worked quite well and it was consistent with classical physics and even the theory of relativity. Now, Einstein took it to an extreme and wanted it to also work for QM.
I think our friend Caroline Thompson also did. Too sad we can't argue with her anymore.
Any way, it is obvious that we still have a problem in explaining the transition form quantum to classical behavior, but that does not imply that we can't assume realism at the macroscopic level. At least we can postulate (based on our experience), define precisely what we mean by it, and see if we can find some experiment that will be inconsistent with it. If we can't find any inconsistencies, then we'll eventually have to find out exactly how we transition from the quantum realm, where realism does not work, to the macroscopic, where apparently it does.
