Debugging a Backprop Neural Network: Issues & Solutions
The discussion revolves around the challenges of training a multi-layer backpropagation neural network to solve the XOR problem. The user reports that the network consistently outputs 0.48 for all inputs instead of the expected binary outputs (0 or 1). Key points include the importance of the network's ability to learn non-linear relationships, as XOR is a non-linear function. It is suggested that the training data may not be adequately diverse, particularly around the critical value of 0.5, which is essential for the network to learn the XOR function effectively. The user is encouraged to examine the learning rate and consider increasing the number of training epochs beyond 1,000, as training for XOR can require a significant amount of time before the loss stabilizes and begins to decrease. Additionally, plotting the mean loss over a larger number of epochs could provide insights into the training process and help identify issues.
Superposed_Cat
I am trying for the first time in 5 years, to make a n- layer, m-width backprop neural network from scratch, My issue is, I've tried training it on XOR, where it returns 0.48 for any of the inputs instead of 1 for half of them and 0 for the other half, if you give it a dataset where the outputs range from 0.6 to 0.99 with the average being 0.7, it will return 0.7 for all, I feel like my loop structure and math is correct, I'm failing to see my problem, any help appreciated.
full code: https://www.mediafire.com/file/f58ia4kj4hmhz99/ConsoleApp3.rar/file
output:
enter image description here
backprop:
C#:
public void bp(double[] x)
            for (int i = 0; i < outputs.Length; i++)
                outputs[i].e = -(outputs[i].a - x[i]) *
                    sig_dx(outputs[i].a);
                for (int j = 0; j < width; j++)
                    outputs[i].w[j] += outputs[i].e * n[n.GetLength(0) - 1, j].a;
                double sum = 0;
                for (int k = 0; k < outputs.Length; k++)
                    sum += outputs[k].e * sig_dx(n[n.GetLength(0)-1,j].a) *
                        outputs[k].w[j];
                n[n.GetLength(0)-1, j].e = sum;
            /*for (int i = layers - 1; i > 0; i--)
                    for (int k = 0; k < width; k++)
                        n[i, j].w[k] += n[i, j].e //* sig_dx(n[i, j].a)
                            * n[i - 1, k].a;
            for (int i = layers - 2; i >= 0; i--)
                    double sum = 0;
                        sum += n[i + 1, k].e * sig_dx(n[i, j].a) *
                            n[i + 1, k].w[j];
                    n[i, j].e = sum;
                double sum = 0;
                    sum += n[1, k].e * sig_dx(n[0, j].a) *
                        n[1, k].w[j];
                n[0, j].e = sum;
                for (int k = 0; k < inputs.Length; k++)
                    n[0, j].w[k] += n[0, j].e //* sig_dx(n[i, j].a)
                        * inputs[k];
feedforward:
C#:
public void ff(double[] x)
            inputs = x;
                double sum = 0;
                for (int k = 0; k < x.Length; k++)
                    sum += n[0, j].w[k] * x[k];
                n[0, j].a = sig(sum);
            for (int i = 1; i < layers; i++)
                for(int j = 0; j < width; j++)
                    double sum = 0;
                    for(int k = 0; k < width; k++)
                        sum += n[i, j].w[k] * n[i - 1, k].a;
                    n[i, j].a = sig(sum);
            for (int j = 0; j < outputs.Length; j++)
                double sum = 0;
                    sum += n[n.GetLength(0)-1, k].a * outputs[j].w[k];
                outputs[j].a = sig(sum);
training:
C#:
var data2 =
                new double[][][] {
                new double[][]{new double[] { 0, 0 }, new double[] { 0 } },
            new double[][]{new double[] { 1, 0 }, new double[] { 1 } },
            new double[][]{new double[] { 0, 1 }, new double[] { 1 } },
            new double[][]{new double[] { 1, 1 }, new double[] { 0 } }
            net n = new net(2, 1, 4, 3);
            for (int t = 0; t < 1000; t++)
                for (int i = 0; i < data2.Length; i++)
                    n.ff(data2[i][0]);
                    n.bp(data2[i][1]);
            Console.WriteLine("done");
                n.ff(data2[i][0]);//new double[] { d,1 });
                Console.WriteLine(n.outputs[0].a);
initialization:
C#:
public class node
        public double a;
        public double e;
        public double[] w;
        Random r = new Random();
        public node(int pl)
            a = 0;
            e = 10;
            w = new double[pl];
            for(int i = 0; i < pl; i++)
                w[i] = r.NextDouble();
    public class net
        public node[,] n;
        public node[] outputs;
        double[] inputs;
        int layers;
        int width;
        public net(int inp,int outp,int layers,int width)
            this.width = width;
            this.layers= layers;
            outputs = new node[outp];
            for(int i = 0; i < outp; i++)
                outputs[i] = new node(width);
            n = new node[layers,width];
                n[0, j] = new node(inp);
                    n[i, j] = new node(width);
        double sig(double x)
            return 1.0 / (1.0 + Math.Exp(-x));
        double sig_dx(double x)
            return x * (1.0 - x);
Any help appreciated.
Technology news on Phys.org
I see you haven't had a response yet on this. Rather than just posting your code to be debugged, try walking us through your procedure of how each section of code is supposed to do, and you may get more responses.
Superposed_Cat said:
My issue is, I've tried training it on XOR, where it returns 0.48 for any of the inputs instead of 1 for half of them and 0 for the other half, ...
For an XOR gate, where the independent input probabilities are a and b ;
the output probability will be; P = a*(1-b) + b*(1-a) ;
Can your network learn to evaluate that equation?
Probabilities of 0 and 1 are the only certainties.
Any input approaching 0.5 will generate an output closer to 0.5 .
I believe you must train an XOR gate with inputs between 0 and 1, and in the vicinity of 0.5 ; Maybe you are starving it of information. It will not learn the non-linear function on only one side of the range, as it will settle to a linear relationship, but the actual XOR relationship is non-linear and symmetrical about 0.5 .
I haven't looked at the code in detail, but it looks like you are training with 1,000 epochs? I can't pick oout what learning rate factor you are using (some comments in the code would help).
Anayway if I remember rightly, training for XOR takes a surprising number of epochs: the mean loss remains high and stable for a long time, then begins to fall slowly at first before settling to perfection. Have you tried plotting the mean loss over, say, 5,000 epochs?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
