Deceleration. My answer is different from the books and it's driving me crazy
The discussion focuses on a physics problem involving a pickup truck decelerating from 100 km/h to a lower speed over a distance of 20 meters. A key error identified is the incorrect conversion of speed from kilometers per hour to meters per second, which should be approximately 27.78 m/s instead of 277.7 m/s. Participants suggest using the correct equations of motion to solve for the final speed and time elapsed, emphasizing the importance of accurate unit conversion. The correct answers from the textbook are 81.4 km/h for the final speed and 0.794 seconds for the time elapsed. The conversation highlights common pitfalls in physics calculations, particularly in unit conversions.
laxboi33
The driver of a pickup truck going 100 km/h applies the brakes, giving the truck a uniform deceleration of 6.50 m/s^2 while it travels 20.0 m.
a) what is the speed of the truck in kilometers per hour at the end of this distance?
b) How much time has elapsed?
The first thing I did was convert 100 km/h into m/s and got 277.7 m/s.
After converting I tried using V^2= V(initial)^2 x 2(a)x, where a = acceleration and x = horizontal distance.
I got
V^2 = (277.7 m/s)^2 + 2 (-6.50 m/s^2) (20.0-0)
V^2 = 77117.29 + (-260)
V^2 = 76857.29
V= 277.23 m/s which equates to 99.8 km/hr which makes no sense.
I then tried x = x(initial) + 1/2 at^2 to try and acquire time first.
I ended up getting 83 seconds. Which is way off. So I checked the answers in the back of the book and it read:
for part a) 81.4 km/h
b) .794 s
can someone please tell me what I'm doing wrong? I'm obviously not asking for the answer since I've got the book.
You have an error in your conversion in m/s. It's more like 27 m/s.
Just divide 100 km/h by 3.6.
I think that you're off by a decimal place.
x = x(initial) + v(initial)(t) + 1/2at^2...correct?
I got
V^2 = 76857.29
b) .794 s
Sorry your very first step of converting kmph to mps is wrong. A small mistake in decimal point .
1km= 1000m
1 hr= 3600s
100kmph= (100*1000)/3600 = 1000/36
=27.777m/s
Sorry your very first step of converting kmph to mps is wrong. A small mistake in decimal point.
1km= 1000m
1 hr= 3600s
=27.777m/s
http://arasaraja.blogspot.com/"
You need to use the equation d = Vot + at^2/2 (with d = 20), you know Vo and a so if you solve it you'll receive 2 solutions for t, only one is valid
36K
