- #36
stevmg
- 696
- 3
yuiop,
In post 28 (cited below) you point out that you derived in post 8.
[tex]v = \frac{a't}{\sqrt{1+(a't/c)^2}}[/tex]
[tex]a'[/tex] is the acceleration in S'.
But you actually derived [itex]a[/itex] in that post (the acceleration in S, not S') I have included that post 8 below this post 28 below
Now, based on the original [itex]a[/itex] and final [itex]t[/itex], what did you do?
I am lost.
Post 28, yiuop
Post 8, yiuop
I am lost.
Post 28, yiuop
yuiop said:In post #8 I derived:
Substitute this for the v in [tex]\gamma = 1/\sqrt{1-v^2/c^2} [/tex] and you eventually get after some algebraic manipulation:
[tex]\gamma = \sqrt{1 + (a't/c)^2} [/tex]
I see you have already done the numerical example for t=10 and v=0.99875c in S and a proper acceleration of 2c per second in your edit. Just for clarity, here is another example for the event t=1 in S. At this event the velocity is:
[tex]v = \frac{a't}{\sqrt{1+(a't/c)^2}} = \frac{2}{\sqrt{1+(2)^2}} = 0.8944c [/tex]
The gamma factor at time t=1 and v = 0.8944c in S is:
[tex]\gamma = \sqrt{1 + (a't/c)^2} = \sqrt{1+2^2} = 2.2361 [/tex]
or
[tex]\gamma = \frac{1}{\sqrt{1 - v^2/c^2}} = \frac{1}{\sqrt{1-0.8944^2}} =2.2361 [/tex]
Well done. You have found another typo.It should have been:
[tex]v = \frac{a't}{\sqrt{1+(a't/c)^2}} = \frac{a't}{\gamma} = \frac{2*10}{20.025} = 0.99875c [/tex]
where a'=2 and t=10 as given in S and the gamma factor of 20.025 was calculated earlier.
Yes, as in the title of the paragraph.
Sorry about the typos in the equations. I know the numbers are right because I did them in a spreadsheet, but the hassles of entering and previewing TEX equations means some errors sometimes creep in during the translation. At least this this is a two way medium and we can get right between us.![]()
Post 8, yiuop
yuiop said:As I mentioned in post #2, the coordinate acceleration is a factor of gamma cubed smaller than the proper acceleration. In the last two equations above, capital T is the coordinate time and small t is the proper time, but to avoid further confusion I will use the symbols recommended by Passionflower, so that:
[tex]a = \frac{dv}{dt} = \alpha \gamma^{-3} = \alpha (1-v^2/c^2)^{3/2} [/tex]
This can be rearranged to:
[tex]\frac{dt}{dv} = \frac{1}{\alpha(1-v^2/c^2)^{3/2}} [/tex]
Integrating both sides with respect to v gives:
[tex]t= \int \left( \frac{1}{\alpha(1-v^2/c^2)^{3/2}} \right) dv = \frac{v}{\alpha \sqrt{1-v^2/c^2}}[/tex]
When rearranged:
[tex]v= \alpha t \sqrt{1-v^2/c^2} [/tex]
[tex]\rightarrow v^2 = (\alpha t)^2 - (\alpha t v/c)^2[/tex]
[tex]\rightarrow v^2 (1+ (\alpha t /c)^2) = (\alpha t)^2 [/tex]
[tex]\rightarrow v = \frac{\alpha t}{\sqrt{1+(\alpha t/c)^2}} [/tex]
which is the last equation you asked about in your post.
