Derive Gravitational Force and Field between two identical rods
The discussion explores the derivation of gravitational force and field between two identical rods by treating them as a collection of small elemental masses. Participants suggest integrating the forces exerted by these elemental masses to calculate the overall gravitational interaction. The approach emphasizes the importance of considering the distribution of mass along the rods for accurate results. This method could provide a clearer understanding of the gravitational effects in such configurations. Overall, the integration of elemental masses is seen as a viable strategy for this problem.
RIJU101
What is the Gravitational force and field between two identical rods(radius of cross-section is R) of uniform density, which are placed parallel to each other? Derive the formula for two cases:
1.When two rods are finite in length
2.When two rods are of infinite length
Gravitational Force: F=GMm/r^2
Gravitational Field: I=GM/r^2
Maybe it can be done by considering both rods as many small elemental masses then deriving the force we can integrate it
So try that and post your attempt.
Likes Vanadium 50 and PhDeezNutz
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
