Deriving Equations for Light Sphere in Collinear Motion - O and O' Observers
In summary, when considering a stationary observer and a moving observer in collinear relative motion, the light pulse emitted by the moving observer can be described by two equations: x'^2 + y^2 + z^2= (ct')^2 and t' = ( t - vx/c^2 )λ. However, these equations only work if there is no relative motion between the two observers. Additionally, in order to find the x and t coordinates in the stationary observer's frame, we can use the transformation equations or the fact that the speed of light is constant in all frames. It is important to note that simultaneity is relative and cannot be attached to any absolute meaning.
  • #526
DaleSpam said:
The MMX shows that the speed of light is isotropic.
Yes, the spacetime diagram shows everything about the LT in one space and one time dimension.
Here are some past discussions you had on this subject.
The equation of the sphere of light in the stationary frame is:
c²t² = x² + y² + z²
Transforming to the moving frame is:
(ct'γ-vx'γ/c)² = γ²(x'-vt')² + y'² + z'²
Which simplifies to:
c²t'² = x'² + y'² + z'²
https://www.physicsforums.com/showpost.php?p=2142933&postcount=7
Re: moving light bulb sphere of photons
Originally Posted by Dreads
Rotate this malformed wagon wheel thru 360 degrees around the x axs and it is not a sphere
Yes it is a sphere; I derived it above.
Since your conclusion is demonstrably wrong, why don't you go back and see if you can spot the mistake.
https://www.physicsforums.com/showpost.php?p=2144836&postcount=17
  • #527
cfrogue said:
There is a light sphere in O and one in O'.
Yes. For t > 0, and x=±r, where r > 0, there is one light sphere in O at t=r/c. For t' > 0, and x'=±r, where r > 0, there is one light sphere in O' at t'=r/c. In DaleSpam's diagram, c=1 and r=1, so the light sphere of O are the green dots at (x=-1, t=1) and (x=1,t=1), and the light sphere of O' are the red dots at (x'=-1, t'=1) and (x'=1,t'=1)
cfrogue said:
LT says, for two times in O, the condition ct' = ±r is true.
Also, LT says there are two different times in O' in which ct' = ±r is true based on the emerging light sphere in O.
That seems to mean there are two in O'.
If r > 0, since c > 0 then some of the times t or t' you are talking about are negative. These are not from the LT. I believe you are referring to the past light sphere of O', which is not shown on the diagram. I haven't been very careful about t>0 and t'>0 in my previous discussion, so maybe this was what was confusing you. Yes, there are two light cones - one future and one past. So far I thought we've been only discussing the future light cone, but I think you are inferring a past light cone from the negative t in the condition x2=t2.
Rachmaninov - Prelude in D major, opus 23 no. 4
  • #528
cfrogue said:
If you believe in the isotropic argument, why did you mention red/blue frequency then?
Therefore, you are separating light speed and frequency with this logic.
I don't understand this comment at all. Do you believe that the Doppler effect is somehow inconsistent with the isotropy of the speed of light? It is not; in fact, the Doppler effect can be derived from the isotropy of the speed of light.
cfrogue said:
MMX does not decide a constant speed of light and therefore, when talking about the speed of light, frequency based experiments should never be brought up.
I would say that the MMX is a wavelength based experiment. If the speed of light were not isotropic then the number of wavelengths in the different arms would be different and an interference pattern would emerge. However, I don't see how any of this discussion of the MMX is relevant to your ongoing light cone questions.
cfrogue said:
Can you please show me on the diagram the 2 different times in O where O' sees simultaneity?
We proved this together with LT.
Certainly, as we have discussed several times already that is represented by the red dots. The red dots are simultaneous in O' (both occur at t'=1 as you can see by the white lines), but they occur at different times in O (t=0.5 and t=2.0 as you can see by the black lines).
  • #529
DaleSpam said:
I don't understand this comment at all. Do you believe that the Doppler effect is somehow inconsistent with the isotropy of the speed of light? It is not; in fact, the Doppler effect can be derived from the isotropy of the speed of light.I would say that the MMX is a wavelength based experiment. If the speed of light were not isotropic then the number of wavelengths in the different arms would be different and an interference pattern would emerge. However, I don't see how any of this discussion of the MMX is relevant to your ongoing light cone questions.
I believe the doppler effect is consistent with a constant speed of light.
I only mentioned MMX because you brought the red blue argument.
I am OK with dropping this part. Thanks.
I agree that there does not exist a time in O such that the points are struck simultaneously in O' while using LT.
However, x' is also the x-radius of the expanding light sphere as calculated by O and (ct')^2 = x'^2.
It is true at two different times in O where (ct')^2 = r^2. Is this correct?
Finally, if O called O' on a light phone and asked the time it took for the simultaneity, then O' would answer t' = r/c because of the constant speed of light. Then O would use time dilation and convert this time as (r/c)λ.
Now, the reason I wrote this is because Einstein said in chapter 4, Physical Meaning of the Equations Obtained in Respect to Moving Rigid Bodies and Moving Clocks
Between the quantities x, t, and τ, which refer to the position of the clock, we have, evidently, x=vt and
τ = ( t - vx/c^2 )λ.
τ = ( t - (tv^2)/c^2 )λ.
τ = t( 1 - (v^2)/c^2 )λ.
τ = t/λ.
It is the case that x=vt at any time t for the moving frame.
I am not sure how all this works together.
1) There is LT which shows there is no time t for which O can declare simultaneity in O'.
2) There are two times in t where the light sphere satisfies (ct')^2 = x'^2.
3) Since O' is moving relative to O, it would seem time dilation also applies such that simultaneity occurs in O' at (r/c)λ in the time of O.
  • #530
DaleSpam and cfrogue, please ignore me if this is irrelevant, since I think you guys are getting somewhere. But is cfrogue's concern here with the formal solution t'=±r/c, for r > 0, ie. the past light cone?
The light sphere loci are given by x'2=ct'2. For fixed r > 0 and t' > 0 then there are two x' values sharing one t' value on the light sphere (x'=±r, t'=r/c). For fixed r > 0 and t' < 0, there are also two x' values sharing one t' value (x'=±r, t'=-r/c). So considering past and future light cones there are two t' values for fixed r. (Not sure if I got the equations all right, but am wondering something along those lines.)
  • #531
Excellent.
Remember, the light sphere in O', when transformed into the coordinates of O is a non-simultaneous ellipsoid. I don't know how it would even be possible to define its radius. So without a crystal clear definition of the radius of a non-simultaneous ellipsoid I can't make any conclusions about this.
Yes, again see the red dots.
τ = t/λ.
We have already discussed this extensively. The time dilation formula only applies when the two events are co-local in one of the frames (Δx=0). You are using it where it doesn't apply. Suppose I were to try and use the compound interest formula A = P (1+r/n)^(nt). It is also a correct formula for t, but it simply doesn't apply.
Again, the time dilation formula only applies if Δx=0 (co-local events), which is not the case here, the ends of the rods are at different positions from the flash in all coordinate systems.
  • #532
Yes, I have decided it is meaningless also from the position of O since the each side of the sphere has a different event timing associated with it due to R of S.
I do not agree with this since Einstein derived it not by using x = 0 but by using x = vt.
However, the light sphere with LT already has it built into so it does not apply a second time.
However, I am not sure how you can justify not using it. And I am not using it to look at the end points of the rods.
I used to to determine when in O' it sees the simultaneity. Since its time is ct = r when the strikes occur, its seems natural to apply time dilation.
  • #533
DaleSpam said:
Excellent.
BTW, you do good work, thanks.
  • #534
Here is what I was trying to achieve.
Assume a rigid body sphere is moving in relative motion.
I can map this into the corrds of O from O' and it looks like an ellipsoid.
It is centered at vt with a x-radius of r/λ and y, z radii of r in O.
Yet, I cannot map the expanding light sphere using just LT. I am probably going to have to adjust the light sphere someone to make it work.
Do you have any ideas as to why I can map this O' rigid body sphere into O but cannot map the light sphere expanding in it?
I suppose I need to back out the simultaneity right and left issues somehow.
As we have seen, (c't)^ = x'^2 is not working because we get two of them.
  • #535
Do the Lorentz transform of x=vt into the primed coordinates:
1) x = γ (x' + v t')
2) t = γ (t' + v x'/c²)
Then by substitution into x = v t
3) γ (x' + v t') = v γ (t' + v x'/c²)
Which simplifies to
4) x' = 0
Not only does that require that all events share the same x' coordinate (co-local in the primed frame with Δx'=0), but it requires that those events lie exclusively on the x'=0 line. So the condition x=vt that Einstein uses here is actually more restrictive than the co-local condition. It is not necessary to use Einstein's more restrictive condition, although he does not show it in his seminal paper it is shown elsewhere.
However, again, the time dilation formula does not apply for this measurement. The events are not co-local in any frame, and they are certainly not co-local with the origin in any frame.
  • #536
If you look at section 4 of the 1905 paper he specifically assumes a clock which is at rest in the inertial frame k, and which elapses a time of tau in that frame. So, we are considering two events on the clock's worldline which have a coordinate separation of 0 in the k frame (and earlier he referred to the first position coordinate of this frame with the greek letter xi, not the roman letter x), and a time separation of tau in that frame, and then figuring how this relates to the time separation t between the same pair of events in a different frame. x=vt is an equation of motion for the clock that's supposed to apply in the separate "stationary" frame K; you can tell it's a different frame because it uses t instead of tau for the time coordinate.
The point is, you can only use the time dilation equation when you are considering to events that have a spatial separation of zero in one of the two frames you're considering; if the first spatial coordinate of the two frames are referred to as xi and x, then it can be either x=0 or xi=0, it doesn't matter (likewise if the coordinates are x and x', then it can be either x'=0 or x=0). Whichever frame is the one where the two events are co-local, the time dilation equation always takes the form:
tnoncolocal = tcolocal/sqrt(1 - v^2/c^2)
or equivalently:
tcolocal = tnoncolocal*sqrt(1 - v^2/c^2)
The second form of the equation is the one that appears in section 4 of Einstein's 1905 paper, with tau as the time separation in the frame where the events are colocal and t as the time separation in the frame where they aren't.
  • #537
Thanks!
When we say "looks like an ellipsoid" that usually means that it has the equation of an ellipsoid at a given (simultaneous) instant in time, so it would be difficult to relate that to a non-simultaneous ellipsoid. I am sure that it could be done, but it just wouldn't be very natural.
Another way to see the difficulty is to think in terms of 4D geometry (or at least 3D geometry, one time and two space). The light cone is, obviously, a cone in 4D, but a rigid spherical body would be a cylinder in 4D. What you are essentially trying to do is to take the cone, slice it diagonally to get an ellipsoidal cross section, then take a cylinder, tilt it in 4D so that it intersects the cone along that ellipsoid, then somehow find the radius of that cylinder, not in the tilted direction, but in some original non-diagonal plane.
It could probably be done, but it would be a lot of work and a rather weird result.
  • #538
DaleSpam said:
Thanks!When we say "looks like an ellipsoid" that usually means that it has the equation of an ellipsoid at a given (simultaneous) instant in time, so it would be difficult to relate that to a non-simultaneous ellipsoid. I am sure that it could be done, but it just wouldn't be very natural.
It wouldn't be physically very natural, but you could just take the equation of a light sphere in O', then figure out the position coordinates in O of all the events that make up this sphere using the Lorentz transformation, ignoring the time coordinate...in terms of the position coordinates of O the result should be an ellipsoid. In a spacetime diagram this is would just look like the "shadow" of of a light sphere in O' when cast down vertically onto a plane of simultaneity in O.
  • #539
or equivalently:
Let me ask this.
Assume I have twin1 at rest and twin2 moving in collinear relative motion.
Does time dilation exist?
  • #540
This I want to try to do.
I am thinking just put a rigid body sphere in relative motion at radius r.
Then, match the light sphere to that one for all r.
  • #541
Which simplifies to
4) x' = 0
Regarding the worldline diagram, I think I understand the two different paths we have been on.
You were talking about R of S, which I agree exists and I was thinking about the light sphere.
In section 3, Einstein said the following.
At the time t = τ = 0, when the origin of the co-ordinates is common to the two systems, let a spherical wave be emitted therefrom, and be propagated with the velocity c in system K. If (x, y, z) be a point just attained by this wave, then
x²+y²+z²=c²t².
Transforming this equation with the aid of our equations of transformation we obtain after a simple calculation
x'² + y'² + z'² = τ²c²
The wave under consideration is therefore no less a spherical wave with velocity of propagation c when viewed in the moving system. This shows that our two fundamental principles are compatible.5
http://www.fourmilab.ch/etexts/einstein/specrel/www/
Now, I assumed I could follow this argument above and look at the light sphere in O'.
Well, I could not as we showed. It depends on whether we use the left ray in O or the right ray in O.
  • #542
cfrogue said:
Let me ask this.
If you pick two events on the worldline of twin1, the time dilation equation tells you how the time between these events in twin2's frame is greater than the time between them in twin1's frame; likewise, if you pick two events on the worldline of twin2, the time dilation equation tells you how the time between these events in twin1's frame is greater than the time between them in twin2's frame. In each twin's own rest frame it is the other twin's clock that's running slow by the amount predicted by the time dilation equation, but of course since all inertial motion is relative, there is no objective truth about whose clock is "really" running slow.
  • #543
I am saying this.
Twin1 is stationary.
We are viewing this from twin1.
Is the clock for twin2 beating slower?
  • #544
cfrogue said:
I am saying this.
In twin1's frame, twin2's clock is beating slower, yes.
  • #545
Now, say twin2 is sitting in a rigid body sphere and everything else is the same.
Is there time dilation for twin2 as calculated by twin1.
  • #546
Yes, time dilation is just a feature of the two events used, the surroundings don't make a difference.
  • #547
Now say twin2 is dancing with a flashlight.
Twin2 is flashing that light every which away.
If the elapsed time in twin2 is t', will it be t'λ in the frame of twin1 from the POV of twin1?
  • #548
The elapsed time of what specifically in twin2's frame?
  • #549
Oh, when O and O' are coincident, t = t' = 0.
Why does an event matter?
They start at the same time and for any time t', t' = t/λ.
I looked at Einstein's chapter 4 and I am not seeing that a specific end is needed.
It just writes about A and B in general.
I am not doing acceleration and integration.
  • #550
The time interval for a single event is 0 so, 0 = γ 0
I showed this earlier today. Einstein also required that the time be measured at a single location in the primed frame. I am asking you to specify what elapsed time you are referring to because it makes a difference. If you are referring to the elapsed time between two events on twin2's worldline (like turning on and turning off the flashlight) then those events are co-located (Δx=0) and the time dilation formula applies. If you are referring to the elapsed time between two events that are not both on twin2's worldline (like turning on the flashlight and the light hitting the end of a rod) then the events are not co-located and the time dilation formula does not apply.
  • #551
Obviously, there must be some specific end for two time points in a frame, but the equation is a general one.
  • #552
No, it is not general, it is specific to the time between two events which are co-located in one frame. I showed that explicitly previously in this thread and Einstein assumed a stronger condition in his derivation.
  • #553
I gave a silly answer.
I will call the end of the event in O' when O' sees the simultaneous strike.
  • #554
Then the two events are not co-located and the time dilation formula does not apply.
Whenever you encounter a new formula in physics, the number one most important thing to learn about that formula is not the details of the equation itself, nor even the details of the derivation of the formula. Rather the single most important thing to learn is the circumstances to which the formula applies and those to which it doesn't apply.
  • #555
Whenever you encounter a new formula in physics, the number one most important thing to learn about that formula is not the details of the equation itself. Rather the single most important thing to learn is the circumstances to which the formula applies and those to which it doesn't apply.
OK, I have a start to the time in O', and I have an end.
This implies I can never use time dilation.
Dont forget, I am not calculating anything in O. x = 0.
So, can you show some end times that are legal.
  • #556
How about this.
Can you tell me in the time of O when O' sees the simultaneous strikes?
  • #557
Sure. Pick one single x' line (e.g. x'=1) and choose any two events on that line.
  • #558
Oh, so distance is the key to picking this?
OK, so I see the distance, what is the time dilation?
  • #559
We have gone over, and over, and over this again and again already. The left one is at t=0.5 and the right one is at t=2 (for v=0.6, c=1, and r=1).
  • #560
I am not saying when O sees the strikes. I am not saying that. O is not watching.
O calls O' on a light phone, what is the answer?
