Deriving Equations for Light Sphere in Collinear Motion - O and O' Observers
In summary, when considering a stationary observer and a moving observer in collinear relative motion, the light pulse emitted by the moving observer can be described by two equations: x'^2 + y^2 + z^2= (ct')^2 and t' = ( t - vx/c^2 )λ. However, these equations only work if there is no relative motion between the two observers. Additionally, in order to find the x and t coordinates in the stationary observer's frame, we can use the transformation equations or the fact that the speed of light is constant in all frames. It is important to note that simultaneity is relative and cannot be attached to any absolute meaning.
  • #246
I do not understand, why is this not solved?
I have a light timer on the left end of a rod of length r and a light source in the center of the rod. A light timer records the time when light strikes it. This will be the moving frame at v.
Now, when the center of the rod is at the origin of O, all clocks are synchronized to 0 in each frame.
Now, light will strike the left point of the rod at t = r/(λ(c+v)) in O.
What will the light timer in O' read, t' = t*λ, for time dilation?
Reference
http://en.wikipedia.org/wiki/Time_dilation
  • #247
cfrogue said:
Yea, so let's see
t' = t*λ
where t = r/(λ*(c+v))
Thus,
t' = r/(c+v)
Is this false?
If t' is supposed to represent the time on the clock when the light reaches it, then yes, your logic is false. You are making the trivial mistake of ignoring the difference between time intervals on a clock (which is what the time dilation equation deals with) and time readings. If a clock moves at 0.6c for 10 minutes between t=0 and t=10 in my frame, then the time interval that elapses on the clock should be 8 minutes according to the time dilation equation. But does that mean I should expect the time reading at the end to be t'=8 minutes? No, because the clock may not have started off showing a time of 0 minutes at t=0. If it started off showing a reading of t'=12 minutes at t=0, for example, then the time dilation equation predicts that at t=10 it'll read t'=12+8=20 minutes.
Similarly, although the rod clock shows a time interval of t/gamma (not t*gamma, you are also making the mistake of running the time dilation equation backwards) in frame O between t=0 when the light was emitted and the time the light reaches the rod clock, that does not mean it shows a time reading of t/gamma when the light reaches it, because at t=0 in frame O it was already showing a time reading of rv/c^2 due to the relativity of simultaneity, so its reading when the light reaches it will be rv/c^2 + t/gamma = r/c.
  • #248
Yea, I was very careful to to sync te clocks in their own frames.
Note Einstein did this also.
We now imagine space to be measured from the stationary system K by means of the stationary measuring-rod, and also from the moving system k by means of the measuring-rod moving with it; and that we thus obtain the co-ordinates x, y, z, and , , respectively. Further, let the time t of the stationary system be determined for all points thereof at which there are clocks by means of light signals in the manner indicated in § 1; similarly let the time of the moving system be determined for all points of the moving system at which there are clocks at rest relatively to that system by applying the method, given in § 1, of light signals between the points at which the latter clocks are located.
http://www.fourmilab.ch/etexts/einstein/specrel/www/
  • #249
But you apparently don't understand the most basic concept of the relativity of simultaneity, namely that if clocks are synched in one frame they are out-of-sync in another frame in motion relative to the first. So if the rod clock is synched so that it reads 0 at the moment the light was emitted according to the definition of simultaneity in the rod's rest frame, that means it will read some time other than 0 at the moment the light was emitted according to the definition of simultaneity in frame O (specifically, it will read rv/c^2 at the moment the light was emitted).
  • #250
cfrogue said:
Maybe so, but the fact is if you are in a frame and light emits from a light source, light moves spherically from the light source with the light source as the center.
So, this is what to expect in the moving O' or we are ignoring a fact.
Yes, it is a fact, and we are not ignoring it. The only difference is I'm saying it's not a problem, whereas you are saying it is?
  • #251
Yea I have this part figured out.
But, time dilation may be a problem for this concept.
Did we figure out the time dilation yet?
  • #252
show me the math of one light sphere performing these gymnastics.
  • #253
cfrogue said:
so is
t' = t*λ
No, you had the correct expression way back in post 5:
t' = ( t - vx/c^2 )γ
Are we moving off of the center topic and onto some different topic now?
  • #254
Wiki has the following
t' = tλ
Is this wrong?
Yes, I am going to bring it all together.
I think some have noticed what I am doing.
  • #255
Didn't you say there are multiple centres?
  • #256
It seems folks want to abandon time dilation. I refuse to.
Reference
  • #257
yes...
  • #258
Yes, time dilation says the time interval elapsed on the clock at the end of the rod should be t/gamma in frame O, and if you look at the math I presented, it is. But the time reading when the light hits it is not t/gamma, because in frame O it didn't start out reading zero at the moment the flash was set off. What is your issue here?
  • #259
Yes, I did the normal sync of SR.
If you refuse my thing then you must refuse Einstein's.
I thought I showed you this.
  • #260
I did show you this.
  • #261
cfrogue said:
yes...
So your problem is you believe there are multiple centres, but one light sphere?
  • #262
Yes...
  • #264
The "normal sync of SR" is exactly why the rod clock doesn't read zero in frame O at the moment the light flash is set off, because it was synched to read zero when the light flash was set off according to the rod frame's definition of simultaneity.
Do you understand that according to the relativity of simultaneity, clocks which are synchronized in one frame are out-of-sync in another? Answer yes/no
Einstein talked a lot about the relativity of simultaneity, see here for example. I can't help it if you lack the intellectual humility to consider that there might be giant gaps in your understanding, and therefore ignorantly tell people that they are "refusing Einstein" or "abandoning time dilation" when they try to explain the basics of how SR works.
  • #265
There are just two events (which you specified). In both frames the emission event is at coordinates (0,0).
In O', the reception event coordinates are given by you (geometric units, c=1)
[tex]x'=-r[/tex]
[tex]t' = r[/tex]
In O, the reception event coordinates can be found by using the LTs.
[tex]
x = \gamma(x'+vt') = \gamma(-r+vr)
[/tex]
[tex]
t = \gamma(t' +vx') = \gamma(r-vr)
[/tex]
If you use a different method, numerically, your answers must be the same as given by the LTs.
It is much easier using a Minkowski diagram! ;)
  • #266
t' = tλ
Nobody is "abandoning" time dilation, you are just accidentally misapplying it. That is not exactly what Wikipedia has. Wikipedia has
Δt' = γ Δt
and Wikipedia also points out that the Δt is the time between two co-local events. This is an important distinction. Time dilation is part of the Lorentz transform, but not the whole thing. Let me show you how the time dilation formula is derived from the Lorentz transform:
Given the Lorentz transform of some arbitrary initial and final event
[tex]t'_i = \gamma (t_i - v x_i/c^2)[/tex]
[tex]t'_f = \gamma (t_i - v x_f/c^2)[/tex]
and given
[tex]\Delta t' = t'_f - t'_i[/tex]
[tex]\Delta t = t_f - t_i[/tex]
[tex]\Delta x = x_f - x_i[/tex]
We obtain
[tex]\Delta t' = \gamma (\Delta t - v \Delta x /c^2)[/tex]
This reduces to the time dilation formula only in the special case where [itex]\Delta x = 0[/itex] (the events are co-local in the unprimed frame), which is not the case here.
By the way, you can clearly see time dilation in the https://www.physicsforums.com/showpost.php?p=2464800&postcount=88". Note, as you follow the line x'=0 away from the origin you cross the line t=1 before you cross the line t'=1, so the primed clock is slow in the unprimed frame. Similarly, as you follow the line x=0 away from the origin you cross the line t'=1 before you cross the line t=1, so the unprimed clock is slow in the primed frame. Not only does the diagram correctly include time dilation, it let's you see how it is reciprocal for each frame and it let's you understand graphically that the time dilation formula only applies as written when [itex]\Delta x = 0[/itex].
  • #267
I covered this in post 233 already. The relativity of simultaneity prevents this.
  • #268
Yes.
But, that has nothing to do with what I was talking about. I did not claim to synchronize between frames.
Let's say we have a proper time interval in a stationary frame of t for an object to move from x1 to x2.
What is the elapsed proper time in the time of the moving object?
  • #269
Δt' = γ Δt
and given
We obtain
Nice lex.
What is the formula for time dilation for a frame moving v.
you had Δt' = λΔt.
Therefore, when O elapses Δt, then O' elapses λΔt.
Is this correct?
  • #270
Yes.
"Proper time interval in a stationary frame" does not make sense as a phrase, "proper time" always refers to the time between events on a specific worldline as measured by a clock moving along that worldline, so it's a frame-invariant quantity. Do you mean there is a coordinate time of t in the stationary frame for an object to move from x1 to x2? In this case, in the object's own rest frame, the coordinate time between the object passing markers at these two points would be t/gamma (since the object is at rest in this frame, this would also be the unique proper time along the object's worldline between these two passing-events). I don't really see what this has to do with the example of the clock at the end of the rod though, since we weren't talking about the time for that clock to move between two positions, we were talking about the time that would be displayed on that clock when the light from the flash reached it. Do you agree that if the clock was synchronized so that it read a time of zero simultaneously with the flash in its own rest frame, then it would read a time of r/c when the light reached it?
  • #271
[tex]x'=-r[/tex]
[tex]t' = r[/tex]
[tex]
[/tex]
[tex]
[/tex]
Could you calculate the time dialation?
Is there not time dilation for a rest frame and a moving frame?
So, given an elapsed time in O, what is the elapsed time in O' with relative motion v?
  • #272
I think I need to take this slowly.
Time dilation if O is synched at 0 is t' = λt for the moving frame O'.
Is this correct?
  • #273
Is this correct?
The question is too vague. What do t' and t refer to? If they're time-intervals, you need to pick specific events you're measuring the time intervals between in each frame. For example, if we have Event 1A = the light flash, and Event 2 = the light reaching the clock, then no, your equation is not correct, in this case t would be r/(gamma*(c+v)) while t' would be r/c. On the other hand, if we have Event 1B = the event on the clock's worldline that is simultaneous with the light flash in frame O, and the same choice of Event 2, then t' = t/gamma.
  • #274
OK, I am simply talking about a general Δt in O.
What is the elapsed time in O'?
In the special theory of relativity, a moving clock is found to be ticking slowly with respect to the observer's clock.
Can you confirm or deny this logic?
Further, do you have the equation for this time dilation?
  • #275
Sorry but this is meaningless. There is no "general Δt", in SR it only makes time to talk about a time interval between a specific pair of events.
Yes, of course I confirm it, but you have to understand what types of events it applies to. The time dilation equation says that if you have two events 1 and 2 which happen at the same position in frame A (like two readings on a clock that is at rest in that frame), and the time between these events in frame A is tA, then if you look at the time between the same pair of events in a different frame B moving at speed v relative to A, and if the time interval between them in B is tB, the two times will be related by tB = tA*gamma.
So if you want to apply the time dilation equation, you have to pick a specific pair of events which are colocated (happen at the same position coordinate) in one of the two frames, otherwise you're misusing the equation. For example, I mentioned the option of picking the following two events:
Since both these events happen along the clock's worldline, obviously they are colocated in frame O' where the clock is at rest. So, plugging in t' for tA in my above notation, we have t = gamma*t', or equivalently t' = t/gamma, which is exactly what I said would be true for this pair of events at the end of my last post.
  • #276
JesseM said:
Sorry but this is meaningless. There is no "general Δt", it only makes time to talk about a time interval between a specific pair of events.
Well, since I said Δt, that means I have selected two timing events in O. That means I have a general start point and a general endpoint. How I pick these may be important later.
But, for the general equation they are not.
So, according to wiki we have,
t' = t*λ
You said t = gamma*t', why is that?
  • #277
cfrogue said:
you had Δt' = γ Δt.
Therefore, when O elapses Δt, then O' elapses γ Δt.
Is this correct?
If Δx=0 then yes.
  • #278
DaleSpam said:
If ?x=0 then yes.
what do you mean?
what is the time dilation equation for what I gave?
  • #279
The general equation is given by the Lorentz transform
[tex]\Delta t' = \gamma ( \Delta t - \frac {v}{c^2} \Delta x ) [/tex]​
The time dilation formula
[tex]\Delta t' = \gamma \Delta t [/tex]​
applies only in the special case when [itex]\Delta x = 0[/itex], which is what the Wikipedia article says: "[itex]\Delta t[/itex] is the time interval between two co-local events (i.e. happening at the same place)"
  • #280
Do you mean we can no longer apply time dilation between frames?
