Determining the sound level of a leaf blower
  • Thread starter Thread starter barryj
    distance Sound
The sound level of a leaf blower rated at 75dB is typically measured at a distance of 50 feet, as indicated by a manufacturer's lobbyist. Sound intensity increases as one gets closer to the source, with a doubling of distance resulting in a decrease of approximately 6 dB. This means that at closer ranges, the perceived noise level can be significantly higher. The discussion highlights the importance of understanding measurement distances when evaluating noise levels. Accurate sound level assessments are crucial for compliance with noise regulations and for user comfort.
barryj
How does one determine the dB of a leaf blower.
db = 10log(p1/p2)
I have a leaf blower that states the sound level is 75dB. My question is, at what distance is this measured. It seems that as you get closer to the source, the dB number will increase drastically. If I double the distance from the source, then the power should go down by a factor of four or 6 db. Is this correct?
You are correct. Can you post a link for the product?
If not stated, I would take it as the expected distance from the device to the operator's ears.
Update: found this
https://www.nonoise.org/quietnet/cqs/leafblow.htm
"The average blower measures 70-75 dB at 50 feet according to a manufacturer's lobbyist"
So maybe 50 feet is standard.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
