- #71
- 7,480
- 3,236
I'm almost ready to get to Clausius. But in order to do that, I need to write Carnot's results in a more analytical form. Rather than copy down Clapeyron's attempt, I'll do it more literally; that is, a literal 'translation' of Carnot's statements into a mathematically consistent form. Because the LaTex editor is limited (for example, I can't put explicit limits on integrals), I'll use text to explain any missing information. I'll also use different letters than the usual to emphasize this.
First, the work 'L' done in a process:
[tex]L = L(P) = \int p(t) \dot{V}dt = \int p((V(t),T(t)) \dot{V}dt = \int p(V,T) dV[/tex]
Where the second integral uses an equation of state and selects as state variable the volume V and temperature T. Getting to the last integral is straightforward, but now instead of a process occurring over a time interval, it occurs over a *path* in the V-T 'state space'.
Similarly, the heat added C is defined as:
[tex] C = C(P) = \int Q(t) dt = \int [\Lambda (V, T) dV + K(V,T) dT][/tex]
This also uses an equation of state. The second integral expresses the heating Q(t) as a function of the latent heat [itex]\Lambda[/itex] and specific heat K (these are at constant volume- I omitted the subscript 'V'). Specifically,
[tex] Q = \Lambda (V,T) \dot{V} + K (V,T) \dot{T} [/tex]
Here's an important point- because Q is continuous, the latent heat and specific heat can also be written as
[tex]\Lambda = \frac{\partial H}{\partial V}, K = \frac{\partial H}{\partial T}[/tex]
Where H is an unknown function (call it the 'heat function') H(T,V).
Ok, so now Carnot's axiom/claim can be written down:
1) the work extracted from a Carnot cycle depends on the temperatures of the hot and cold reserviors, and the heat added:
[tex] L(P_{c}) = G(T^{+}, T^{-}, C(P_{c})) [/tex]
furthermore, the function G is seperable:
[tex]G(T^{+}, T^{-}, C(P_{c})) = F(T^{+}, T^{-})C(P_{c})[/tex]
Carnot goes further, and unnecessarily restricts F. However, we do not require such a strong restriction. Instead, all we require is F(T+, T-) > 0 if T+ > T- > 0, and F(T,T) = 0
We now derive what is known as the Carnot-Clapeyron theorem:
Begin with L for a Carnot *cycle*- a closed loop in p- V (or V-T) space, consisting of 2 isotherms and 2 adiabats:
[tex] L(P_{c}) = \int dpdV = \int\frac{\partial p(V,T)}{\partial T} dVdT [/tex]
Also, using the defintion of Q,
[tex] C (P_{c}) = \int \Lambda (V,T) dV [/tex]
And so, Carnot's axiom (1) takes the form:
[tex] \int dpdV = \int\frac{\partial p(V,T)}{\partial T} dVdT = F(T^{+},T^{-})\int \Lambda (V,T^{+}) dV [/tex]
Now I do some hand-waving. A critical point is that the function F is *not* a state function- it is independent of both material and process: that's the reason it's not in the integral. Historically, instead of F, people used [itex]\mu[/itex], and future researchers (Joule, Clausius, etc) called [itex]\mu (T)[/itex] 'Carnot's function'. Carnot's function can be written as dF/dT, but the way it was done back then, F(T+,T-) was assumed to be of the form F(T+) - F(T-). For infinitesimal changes in temperature, there is no conflict. For finite differences in temperature, it's a little more complex and the two results do not agree. So in the interest of not having a googleplex of different symbols, I'll just switch to Carnot's function and not worry what the specific form of it is in terms of F.
Just remember that from Carnot until the Joule-Thompson papers in 1852 and 1853 establishing the absolute temperature scale, people tried to measure the function [itex]\mu[/itex].
Converting F(T+,T-) to Carnot's function [itex]\mu(T)[/itex], we get the heat added for a Carnot cycle is:
[tex] C(P_{c}) = \frac{1}{\mu(T)}\int\frac{\partial p(V,T)}{\partial T} dV[/tex]
This is the Carnot-Clapeyron theorem. For an infinitesimal process,[itex]\mu\Lambda = \partial p/ \partial T[/itex].
One final note (for now): putting the above special case of an ideal gas equation of state p/T = R/V into the expression for the heat:
[tex] C(P_{c}) = \frac{R}{\mu(T)}\int \frac{dV}{V} = \frac{R}{\mu(T)} log \frac{dV}{V}[/tex]
And finally, on dimensional grounds, since L/C is a constant bearing the units of work/heat, that constant (called J, since Joule measured it) and Carnot's function [itex]\mu[/itex] are related by:
[tex] \mu =\frac{J}{T}[/tex]
This may give you some insight as to what the heat function H and Carnot function 'really' are.
Now, we are ready for Clausius. For, after Clapeyron (1834) came Duhamel (1837,1838), Mayer (1842)- who is oddly credited with discovering the first law- and a preliminary experimental work by Joule (1845) that everyone panned. None of these had sufficient mathematical skill to properly translate Carnot's work (the stuff above is a correct 'translation', which came from Truesdell). Kelvin, in an early paper (1849) coined the term 'thermodynamics' but that's about it. Clausius wrote his first paper in 1850.
Some of it is here:
http://www.humanthermodynamics.com/Clausius.html#anchor_116
but I couldn't find a free on-line version of the whole thing. EDIT: that URL points to Clausus's later papers in 1854. We aren't there, yet!
EDIT 2: I did find an online version of all six papers: http://books.google.com/books?id=8LIEAAAAYAAJ
Some of it is here:
