Did Lorentz or Einstein theoretically derive special relativity?
In summary, Einstein and Lorentz both made significant contributions to the development of special relativity, with Einstein's theory applying to a wider range of phenomena and rejecting the idea of the aether. While Lorentz used his transformation to model the contraction of electrons at high speeds and save the aether theory, Einstein's approach was simpler and more coherent. The math behind special relativity is actually quite simple, despite the misconception that only a few people can understand it.
  • #36
harrylin said:
Indeed it was not you but me who suggested that your example is a paradox (=apparent contradiction): I actually understood that according to you, "the observer at rest in the aether frame would predict" that "the balance beam would tip", while according to "observers at rest with the balance" "the balance beam would not tilt". Sorry that I misunderstood you.
No problem. I thank you for doubling back for reread.
harrylin said:
As I already mentioned, according to Einstein a new theory emerged with the writings of Lorentz in 1904 and his own in 1905; I agree with that. However there is a subtle difference between the two interpretations of the theory:
whereas Lorentz found it useful to distinguish between what appears to happen and what "really" happens from an unknown perspective that cannot be detected, Einstein found it better to only discuss the phenomena (=appearances, not what "truly" happens!).
Well, sounds about right. Now please understand that I am not just trying to argue here, but two points that I feel are debatable ...
(1) as to whether Lorentz and Einstein have 2 interpretations of a same theory. I've always considered the theories to differ, so 2 differing theories that happen to possesses the same solutions.
(2) as to whether Einstein's comments as-to-what "appears to be" means "possibly untrue". From my studies of OEMB, my impression is that Einstein discusses what is measurable/recordable by observers using light itself as part of the measuring apparatus. In Einstein's theory, an extension of rigid coordinate system axes would be consistent with relativistic measurements using light signals. In this sense, what is measured matches what is real, per any inertial measurer. The fact that OEMB requires a moving observer contract and his moving clock slow down, while yet said moving-observer never measures/discerns any change in his own length or clock rate, does not necessarily lead that Einstein assumed relativistic effects are "not true".​
I'm just trying to get to the core of "the differences in meaning" between SR and LET, and as to whether the PoR is upheld (for the all of physics) in LET as well as it is upheld in SR. I've never fully understood the full meaning of LET, mainly because "folks who understand LET well" often tend to make differing statements about its deeper meaning. By "deeper meaning", I refer to those concepts upon which the theory is constructed, and as to how they impact the meaning of the final LT solns (the LTs being the same in both theories).
Just a couple related points on this, per http://en.wikipedia.org/wiki/Lorentz_ether_theory" ...
In 1904 he (Poincare) illustrated the same procedure in the following way: A sends a signal at the time 0 to B, which arrives at the time t. B also sends a signal at the time 0 to A, which arrives at the time t. If in both cases t has the same value the clocks are synchronous, but only in the system in which the clocks are at rest in the ether. So according to Darrigol Poincaré understood local time as a physical effect just like length contraction - in contrast to Lorentz, who used the same interpretation not before 1906. However, contrary to Einstein, who later used a similar synchronisation procedure which was called Einstein synchronisation, he still was the opinion that only clocks resting in the ether are showing the "true" time.
In 1907 Einstein criticized the "ad hoc" character of Lorentz's contraction hypothesis in his theory of electrons, because according to him it was only invented to rescue the hypothesis of an immobile ether. Einstein thought it necessary to replace Lorentz's theory of electrons by assuming that Lorentz's "local time" can simply be called "time", and he stated that the immobile ether as the theoretical fundament of electrodynamics was unsatisfactory.​
So Einstein saw Lorentz's "local time" as "time", which suggests to me "true time". This is no different from saying that the readout of a distant moving clock is the true time of said moving clock, per the observer. IOWs, it's not some kind of luminal effect that produces a moving time readout that is less-than-real.
GrayGhost
  • #37
GrayGhost said:
[..]two points that I feel are debatable ...
(1) as to whether Lorentz and Einstein have 2 interpretations of a same theory. I've always considered the theories to differ, so 2 differing theories that happen to possesses the same solutions.​
As I and Pallen discussed early in this thread, it's a bit funny that people treat such questions regarding QM differently. I still don't fully understand why. Would you argue that there are different theories* of QM? Or is this all just word games perhaps? :rolleyes:
I don't know what you mean with "OEMB", but it sounds as if you mean with "real" something else than what for example Newton meant with "real" or "true". In any case, you can easily verify that Einstein's 1905 paper avoids those words altogether; and I am sure that was on purpose. Definitely such non-measurables are not part of SR.
The funny thing is that Lorentz himself probably did not know about this "LET" that you discuss here; a long time ago when I tried to find its origin, I found that it almost certainly originated from a confusion by Minkowski - a confusion that has lived on until today, as so often happens.
By "deeper meaning", I refer to those concepts upon which the theory is constructed, and as to how they impact the meaning of the final LT solns (the LTs being the same in both theories). [..Wikipedia..]
Let's not discuss the mix of accuracies and inaccuracies of Wikipedia on this forum; please stick with the original (mostly peer-reviewed) papers!
GrayGhost
I'm sorry but I can't make sense of what you mean with "true": you appear to have no problem with contradictory truth, so that your definition of "true" is close to my definition of "untrue"; and I think that we had that same problem in an earlier thread, and that we could not solve it. So I won't try again. In any case, "true" is not defined in SR. SR is about predictions and observations.
* See: https://www.physicsforums.com/showthread.php?t=489958&highlight=poll
Regards,
Harald
  • #38
Appears that as Lorentz was striving to present his 'electrical theory of matter'. He developed
his transform: x' = x - [ vt/SquareRoot( 1 - (v^2/c^2))], c the velocity of light. ----- Because of the enigma of 'length contraction' and the Michelson-Morley 'failure' (no aether detected).
Lorentz suggested, regarding relative motion; that if you 'hold' c as the/a constant and arbitrarily make space and time variables; his equation accounts for 'length contraction'.
  • #39
Well, I would say that there is one QM theory, but that there exists various interpretations of the theory. The varying interpretations come from trying to explain the meaning of things such as (say) the wave function collapse.
Here though, we've been talking about 2 different theories, LET and SR, which just happens to have the same LT solns. Their foundations differ.
I suppose it best to replace "real" with the word "measured/measurable", for otherwise folks often tend to use that to send the discussion off track and out into left field. In LET though, it's not so easy. We have (in LET) the issue of a moving contracted ruler not able to measure itself as contracted because it too length-contracts by the same amount, which seems a "less than real" measurement. It's contracted, but it cannot tell. In SR, inertial rulers cannot measure themselves contracted because they aren't, because no contractions exist when stationary, and so different story altogether.
harrylin said:
The funny thing is that Lorentz himself probably did not know about this "LET" that you discuss here; a long time ago when I tried to find its origin, I found that it almost certainly originated from a confusion by Minkowski - a confusion that has lived on until today, as so often happens. Let's not discuss the mix of accuracies and inaccuracies of Wikipedia on this forum; please stick with the original (mostly peer-reviewed) papers!
Well, maybe so. I am not sure as yet, myself. I now see your position on this matter, but I've read much over the years that contends otherwise. I'll have to look online for some verification. It reminds me of the democrat who says FOX news has unreputable sources, and the republican who says CNN has unreputable sources :) I'd like to see some statements made by Lorentz himself, between 1904 and (say) 1908, and after.
In the context of SR, my definition of true is "measured". I'm not so sure that this definition apply as well to LET though, as I stated prior here.
GrayGhost
  • #40
Histspec said:
So, in summary: I think it's always possible to modify "LET" so that it is experimentally equivalent to SR. However, the increasing number of effects that must be explained, decreases the probability of such a theory. Regards,
Sounds rather reasonable to me. However the fact that these "increased number of effects" need be explained in LET, suggests to me that the meaning of the LTs likely differs for SR vs LET ... even though the solns are the same. no?
GrayGhost
  • #41
The Wikipedia article is correct. It was Lorentz himself, who used the word "true time" to distinguish his own views from that of Einstein and Minkowski (and Poincaré). For example in 1914: http://en.wikisource.org/wiki/Two_Papers_of_Henri_Poincar%C3%A9_on_Mathematical_Physics, p. 252, emphasis by me:
Lorentz1914 said:
The formulas (4) and (7) are not in my memoir of 1904. Because I had not thought of the direct way which led there, and because I had the idea that there is an essential difference between systems x, y, z, t and x',y',z',t'. In one we use - such was my thought - coordinate axes which have a fixed position in the aether and which we can call "true" time; in the other system, on the contrary, we would deal with simple auxiliary quantities whose introduction is only a mathematical artifice. In particular, the variable t' could not be called "time" in the same way as the variable t....Poincaré, on the contrary, obtained a perfect invariance of the equations of electrodynamics, and he formulated the "postulate of relativity".
So Lorentz clearly wrote, that the shortcomings of his 1904-paper are the consequence of his distinction between "true" time in the aether; and "local" time which is only a "mathematical artifice".
Or in 1910: http://de.wikisource.org/wiki/Das_Relativitätsprinzip_und_seine_Anwendung, p. 75, (translation and emphasis by me):
Lorentz1910 said:
Provided that there would exist an aether: then one of all systems x, y, z, t, would be preferred by the fact that the coordinate axes as well as the clocks are resting in the aether. If one connects with this the idea (which I only reluctantly would abandon) that space and time be completely different things, and that there be a "true time" (simultaneity thus would be existing independently, corresponding to the fact, that it is possible for us to imagine infinitely great speeds), then one can easily see, the this true time shall be indicated by clocks at rest in the aether. Now, if the relativity principle had general validity in nature, however, one would consequently be unable to find out whether the reference system momentarily employed is that preferred one. Thus one arrives at the same results, as when one denies the existence of the aether and of true time, and to view all reference systems as equally valid, following Einstein and Minkowski. To which of both ways of thinking one adheres to, we can leave to the judgment of each individual.
So on one hand, we have Lorentz's view that there is a "preferred frame", "absolute simultaneity" and "true time", but all of them are unobservable. And we have Einstein and Minkowski, according to which all of those concepts are meaningless.
And the same in 1913: http://de.wikisource.org/wiki/Das_Relativitätsprinzip_(Lorentz)), p. 23, (translation and emphasis by me):
Lorentz1913 said:
If the observers would like to view the concept of time as something primary, something completely separated from the concept of space, then they would surely recognize, that absolute simultaneity exists; however, they would leave it undecided again, whether this simultaneity is indicated by equal values of t, or by equal values of t', or maybe neither by one nor the other.
Einstein says in short, that all questions mentioned before, have no meaning. Thus he arrives at the abolishment of the aether. The latter is, by the way, to some extent a quarrel about words: it makes no great difference, whether one speaks of vacuum or aether. Anyway, according to Einstein it has no meaning to speak about a motion relative to the aether. He also denies the existence of absolute simultaneity.
It is certainly remarkable, that those relativity concepts, even with respect to time, have been adopted so fast.
The evaluations of those concepts mostly belong to epistemology, and one can leave it to its judgment, trusting that it considers the questions discussed with the thoroughness required. However, it is for sure, that for a large part it will depend on the way of thinking to which one is accustomed, whether one is mostly attracted to one or the other view. Regarding the lecturer himself, he finds a certain satisfaction in the elder views, that the aether at least possesses some substance, that space and time can sharply be separated, and that one can speak of simultaneity without closer specification. Regarding the latter, one can maybe rely on our ability, to (at least) imagine arbitrary great speeds. By that, one comes very near to the concept of absolute simultaneity.
Regards,
  • #42
QM had multiple philosophical foundations relating to differing philosophies as locality, no locality, particles, waves and wave-particles; differing interpretations have been there right from the beginning. The "solution" of modern theories of physics such as SR and QM is to formulate them in such a way that they discuss only observables.
I refer you again to Einstein's overview of 1907 of what he later named SR: its foundation is the construction of a theory in which Maxwell's equations are invariant for a change of inertial reference system, so that the PoR is valid for all laws of physics. The unification of Lorentz's Theory of Electrons with the principle of relativity was the common basis for Lorentz-1904 and Einstein-1905.
[..] In SR, inertial rulers cannot measure themselves contracted because they aren't, because no contractions exist when stationary [..]
Those rulers are contracted according to any observer who is moving wrt to them while you say that "they arent"... if you want to suggest with that that the POV of that observer is "wrong" - that is at odds with the PoR. The whole point of the PoR is that such claims can not be made. But I'm sure that we have been here before, it's perhaps a difference of how are brains are wired. :wink:
Mere statements won't suffice as they should be understood in context; a whole section is more reliable than a sound bite. You can find increasingly more original papers of that time in Wikisources to which I already gave links:
http://en.wikisource.org/wiki/Portal:Relativity
GrayGhost
Certainly Lorentz meant with "true" not what is measured but invisible reality, like Newton.
  • #43
GrayGhost
It depends on what you mean with "LET", and with "the LTs". They don't exist in that form in the 1904 paper by Lorentz, and he had not thought enough about the meaning in practice of his "local time". However, in the 1905 paper by Poincare the meaning of the equations is the same as it is today.
  • #44
Histspec said:
The Wikipedia article is correct. [..]
Nothing is perfect and certainly not Wikipedia! I referred to suggestions of that article (not related to your citations) that were cited here.
Anyway, thanks for the many citations. :smile:
I note that you forgot to include citations of Einstein's 1918 and 1920 replies in which he abandoned his earlier interpretation; but all that has little to do with the topic.
Regards,
Harald
  • #45
OK harrylin. So Lorentz derived the correct LT solns first in 1904, although he did not understand the meaning of time t', ie time dilation. Poincare made a correction to the 2004 LET in 2005 (wrt electric charge), and also re-interpreted Lorentz's LET in a way that allowed it finally become Lorentz covariant ... whereby Lorent'z provided a physical meaning for Lorentz's "local time", versus some mathematical artifact during derivation. So in the same year, 2005, we have Poincare's re-interpretation of LET and Einstein's OEMB published. Lorentz finally began accepting Poincare's re-interpretation in 2006. Einstein's theory was accepted over LET because of simplicity, the result of an invariant light speed ... ie, a choice of convention that makes everything more convenient. Sound about right?
I must say, it remains strange to me that we have one theory that begins from a preferred aether frame, and another theory that assumes no preferred frame exists, and the solns are identical with both supporting the PoR. If so, would this not be true ... Wouldn't any arbitrary inertial frame be able to be defined as the preferred aether frame, and if so, would not the very same LTs arise during the same Lorentz derivation? I mean if no experiment can determine the aether frame (or distinguish LET from SR), then I suppose it matters not which frame you begin with "as the aether frame". Yes? I mean the end results are the very same. And if it doesn't matter, then one has to wonder whether there really is an aether frame at all (even if an aether exists). So I still seem to be missing something about LET here, but I don't yet know what it is :)
GrayGhost
  • #46
That sounds almost right to me. :smile:
However:
- You placed the events it in the wrong century. :wink:
- Poincare as well as Langevin were not mistaken or cheating when they claimed that Lorentz managed to create what you here call a "Lorentz covariant" theory: the Lorentz transformations follow directly from Lorentz's 1904 paper without any correction and with the modern operational meaning.
- Lorentz had already mentioned the physical meaning of time dilation in an earlier paper and he certainly understood the fact that the PoR of classical mechanics implies that the corresponding transformations hold just as well between moving systems; thus there was no need for him to "begin accepting" Poincare's interpretation. It was simply that by 1904, in his head "all the pennies had not yet dropped". :smile:
Note that the phrase "they form a group" is very mathematical and Poincare was also a mathematician. However it was not a common thing to say for physicists at that time. I think that Lorentz did not use that expression. Consequently the fact that Einstein put that phrase in his paper has been advanced as evidence for the hypothesis that he had seen Poincare's paper. However, that's irrelevant for the priority of the 1904 and 1905 papers of Lorentz and Poincare.
Ehm, not exactly. It's similar to classical mechanics vs. Newton's mechanics. Both Lorentz-1904 and Einstein-1905 begin from the PoR, which implies that no frame is preferred for the phenomena. Lorentz's derivation starts from a "true" (or "absolute") rest frame which cannot be determined, while Einstein's derivation omits that assumption because it is "superfluous" for the derivations: it plays no role in the predictions that are based on the postulates. However, the light postulate corresponds to the Maxwell-Lorentz wave theory of light, as opposed to ballistic light theories (see further).
GrayGhost
Exactly - such a "frame" is not "preferred" in that sense.
What you may have missed, is the wish of many physicists to come up with a physical model of light propagation (even if just a sketchy concept like the atom for the ancient Greeks), so as to be able to ascribe a physical cause for such things as a limit speed, electromagnetic fields, etc*. It's similar to Einstein's later wish for a "local-realistic" physical explanation of the apparent "spooky action at a distance" of QM.
*Einstein motivated the light postulate as follows in 1907:
[this] "principle of the constancy of the velocity of light," is at least for a coordinate system in a certain state of motion [..] made plausible by the confirmation through experiment of the Lorentz theory [of 1895], which is based on the assumption of an ether that is absolutely at rest.
- German original: http://www.soso.ch/wissen/hist/SRT/E-1907.pdf
Regards,
Harald
  • #47
Unfortunately, Lorentz himself said that he didn't arrive at a fully Lorentz covariant theory, due to his assumption, that there is a fundamental difference between "true" and "local" time. (see his Poincaré-paper above). So it's quite clear that Langevin and Poincaré were very generous in his assessment. See also Lorentz's remark: http://en.wikisource.org/wiki/Two_Papers_of_Henri_Poincar%C3%A9_on_Mathematical_Physics
Lorentz1914 said:
Poincaré, on the contrary, obtained a perfect invariance of the equations of electrodynamics, and he formulated the "postulate of relativity", terms which he was the first to employ. Indeed, stating from the point of view that I had missed, he found the formulas (4) and (7). Let us add that by correcting the imperfections of my work he never reproached me for them.
Here is another statement of Lorentz from 1928, p. 350: http://adsabs.harvard.edu/abs/1928ApJ%E2%80%A6.68..341M
Lorentz1928 said:
A transformation of time was also necessary. So I introduced the conception of a local time which is different for different systems of reference which are in motion relative to each other. But I never thought that this had anything to do with the real time. This real time for me was still represented by the old classical motion of an absolute time, which is independently of any reference to special frames of co-ordinates. There existed for me only this one true time. I considered my time transformation only as a heuristic working hypothesis. So the theory of relativity is really solely Einstein's work. And there can be no doubt that he would have conceived it even if the work of all his predecessors in the theory of this field had not been done at all. His work is in this respect independent of the previous theories.
However, one may wonder that in one text he referred to Einstein, and in another to Poincaré...
Not according to Lorentz's own opinion. He had the local time formula in 1892, and the time-dilation formula in 1899, but as he himself noticed, this was only a "mathematical artifice" (see his Poincaré-paper or the quote given above). It was not before 1906, when he first spoke about a physical interpretation of both "local time" and "time dilation" by using clocks.
In fact, the light-signal interpretation of local time was first given by Poincaré in 1900, and the transported-clock interpretation of time-dilation was first given by Larmor and Cohn in 1904.
Yes, Lorentz's aether theory influenced Einstein's thinking on the light postulate – but he didn't used the aether concept itself. See p. 413. (translation and emphasis by me)
Einstein1907 said:
However, it was demonstrated surprisingly, that it was only necessary to define the concept of time sufficiently precise, to overcome the difficulty discussed before. Only the idea was necessary, that an auxiliary quantity introduced by H. A. Lorentz, which was denoted by him as "local time", can be defined as "time" per se. If one continues to adhere to the sketched definition of time, then the fundamental equations of Lorentz's theory correspond to the relativity principle, when one replaces the transformation equations above, by such ones corresponding to the new concept of time. The hypothesis of H. A. Lorentz and Fitzgerald then appears to be as a necessary consequence of the theory. Only the idea of a luminiferous aether as the carrier of electric and magnetic forces does not fit into the theory laid out here; namely, electromagnetic fields doesn't appear here as states of some sort of matter, but as independently existing things, that are equally valid to ponderable matter and share with it the property of inertia.
Regards,
  • #48
Histspec,
Well, you do seem to have your sources. Thanx for the references.
My understanding was that Einstein continued working as a patent clerk from 1904 thru 1908, so for 4 more years, before being approached by colleagues of Max Planck. I'm just curious, at what year did Lorentz (and/or Poincare) first become aware of Einstein's 1905 paper? Any idea?
GrayGhost
  • #49
Generous perhaps, but basically correct since the Lorentz transformations follow directly from Lorentz-1904. It appears that people who more openly proclaim their mistakes and weaknesses are punished for their honesty. Due to lack of rigour (instead of "proceeding more systematically") Lorentz's electromagnetic formulas "remained encumbered with certain terms which should have disappeared".
Note that similarly, there's an error in the transverse mass equation of Einstein-1904: a square root is lacking there (http://www.fourmilab.ch/etexts/einstein/specrel/www/, it's the same in the German original; for a discussion see E. Cullwick, The British Journal for the Philosophy of Science Vol. 32, No. 2, Jun., 1981, http://www.jstor.org/stable/687198?seq=6).
Usually one does not trash a theory because of a few glitches in the original papers; but of course that's a matter of opinion. :smile:
Indeed - although by then "theory of relativity" commonly referred to GR, it appears that with "theory of relativity" he there referred to special relativity, in which case his accreditation was simply faulty. It could be amnesia due to old age (it was shortly before his death and these are conversation notes); or perhaps it was due to an editing error. Although Lorentz supposedly reviewed those shorthand notes, he may have overlooked the error.
harrylin wrote: "Lorentz had already mentioned the physical meaning of time dilation in an earlier paper and he certainly understood the fact that the PoR of classical mechanics implies that the corresponding transformations hold just as well between moving systems; thus there was no need for him to "begin accepting" Poincare's interpretation. It was simply that by 1904, in his head "all the pennies had not yet dropped"."
Not according to Lorentz's own opinion. [...]
Lorentz never stated that he did not understand that the Galilean transformations conform to the classical PoR so that they are valid between inertially moving systems; indeed that would be rather incredible. :wink:
And with the "physical meaning" of time dilation I had his 1899 paper in mind:
Michelson's experiment should always give a negative result, whatever transparent media wore placed on the path of the rays of light, [..] provided however that in S the time of vibration be kε times as great as in S0.
- http://en.wikisource.org/wiki/Simpl...rical_and_Optical_Phenomena_in_Moving_Systems
A mere calculation aid cannot affect such a physical vibration time. :-p
Regards,
Yes, and I wondered what he meant with "an ether as carrier of electric and magnetic forces does not fit in that model"; but happily in 1920 Einstein clarified his 1907 claim as follows:
H. A. Lorentz [..] brought theory into harmony with experience by means of a wonderful simplification of theoretical principles. He achieved this [..] by taking from ether its mechanical [..] qualities. [...] According to Lorentz the elementary particles of matter alone are capable of carrying out movements; their electromagnetic activity is entirely confined to the carrying of electric charges.
Note: I'm afraid that this discussion has drifted rather far from the topic; and I think that the questions of the OP have been more than sufficiently answered. Thus I'll abstain from further commenting on aspects that are not perfectly on topic.
Regards,
Harald
PS more references for the question "who first derived SR" can be found here:
http://en.wikipedia.org/wiki/Relativity_priority_dispute
  • #50
harrylin,
Indeed, it helps to get the century right :) Thanx for the correction.
It seems clear as to why SR was accepted over LET. LET assumes an immovable aether that can never be found, a preferred frame, a non-invariant light speed that cannot be recorded, and physically contracted rulers that can never measure their own contraction. SR has none of these issues. Yet, I suppose there is always the possibility that an aether frame does exist, as assumed per the LET model. It seems more intuitive to me that if an aether frame does exist, it be an unpreferred inertial frame of Einstein's model as opposed to Lorentz's undeterminable preferred one. BTW, would not the determination of the 1-way speed of light reveal which theory is the correct one?
GrayGhost
  • #51
harrylin said:
...there's an error in the transverse mass equation of Einstein-1904: a square root is lacking there...
No, that's a misconception. There's no "error" in Einstein's transverse mass equation in the 1905 paper. See, for example, this discussion of that issue:
http://www.mathpages.com/home/kmath674/kmath674.htm
  • #52
GrayGhost said:
harrylin,
[...] It seems more intuitive to me that if an aether frame does exist, it be an unpreferred inertial frame of Einstein's model as opposed to Lorentz's undeterminable preferred one. BTW, would not the determination of the 1-way speed of light reveal which theory is the correct one?
GrayGhost
There must be a misunderstanding here: Lorentz's ether corresponds to an unpreferred inertial frame. I did elaborate on that issue (and I won't again, as it's not the topic).
About the 1-way speed of light: the answer is no that makes in principle no difference with the two-way speed of light. That was even understood well before SR; for example discussed in the paper by Poincare that I referred you to in post no. #29
  • #53
Interesting, he disagrees with Cullwick (+reviewers). I'm afraid that mathpages is not reviewed (and thus in principle illegal here), but usually they are of high quality. I'll read it with interest. :smile:
  • #54
Well, there seems to be differing versions of Lorentz's beliefs. I'll dig further into both camps, see what evolves in that respect.
Yes, but I was not talking the 2-way speed of light. If in fact the 1-way speed of light were accurately measurable, that should tell the story as to whether the aether obeys Einstein's model vs Lorentz's. Why would a detection of the 1-way speed of light not be useful in distinguishing which theory possesses the correct foundation?
GrayGhost
  • #55
GrayGhost said:
Histspec,
GrayGhost
I've also read that Einstein learned of the Michaelson-Morley experiment long after he published his SR paper.
Can someone explain to me why that would be important to Einstein? Wouldn't he consider the Earth to be one big inertia frame of reference and expect the speed of light to be the same in both directions for that reason alone?
I've never quite understood why that experiment would have anything to do with SR. (I got my MS at CWRU and have seen their experimental setup - fascinating stuff).
Didn't the fact that the speed of light as measured from occluded light sources far out in space all came to the same speed have much more relevance? Did Einstein know about those measurements?
  • #56
Indeed, that's reportedly what Einstein stated himself over his lifetime.
Well, I'd imagine that would have been important to him had he known about it. I mean it is a test of light speed invariance even though it was not intended as such, invariance being a cornerstone of Einstein's belief at the time and a postulate of his OEMB. My understanding is that Einstein believed light's speed invariant at c based off Maxwell's theory alone. There had been other tests of light speed prior to MMX, but I don't think the test setup apparatus' were sensitive enough to obtain the accuracy needed to see an aether drift. The MMX experiment was the first to attain the accuracy necessary.
The MMX experiment was setup to detect the Earth's motion wrt the aether. The null result suggested there was no aether wind. Fitzgerald later realized that an invariant light speed would lead to length contraction of an interferometer arm(s) wrt the axis of motion. This could then explain why no fringe effect was noted in the MMX. So a relation between MMX and SR (or LET) is an invariant 2-way light speed ... an interpretation of no aether drift in the MMX, determined by LET, and postulated in SR.
Not sure. However, you're talking about light's 1-way speed over long cosmic distances here. I'm not aware of any valid 1-way light speed test to date myself, but I think DaleSpam mentioned one to me recently. There was Romer's test using Jupiter's moon back in the 1600s, but not accurate by today's standards of course. If there are such tests, it would seem that the clock synchronisation convention selected would dictate the speed of light determined. Einstein indeed (in 1905) assumed a 1-way speed of light at invariant c, so he would have assumed all light to approach from distant sources at c, because he'd have used his own convention.
GrayGhost
  • #57
GrayGhost
Those points are considered exactly in the article "Light Signals Sent Around a Closed Path", Journal of the Optical Society of America, April 16, 1938 by Herbert Ives. He analyzes what we now call ring laser experiments where 2 different signals are sent in opposite directions around a closed path and meet at a common point where the emitter-detector lies. The detector is an interferometer recording a difference in phase that occurs when the emitter-detector is set in motion along the same path as one of the signals.
The difference in phase depends on the velocity of the emitter-detector and on the area of the loop. The experiment usually involves rotation but rotation can be eliminated by placing the apparatus on a conveyor belt, for instance as Ives wrote. It is effectively 2 one way signals that are being compared. The circuit is often circular but Ives shows that the circuit and travel of the emitter-detector can consist of 4 straight segments with 4 mirrors.
The results clearly indicate that light travels through space at velocity c in a manner where space is resting with regard to the motion of the emitter and detector in the case where the path of light is not linear between the emitter and detector. I don't see how it is possible to resolve the difference in the apparent or measured speed of light with the fact that the relative velocity between the emitter and detector is zero unless some type of absolute reference system is established.
  • #58
I'm quite sure, that Lorentz knew of Einstein's paper at the beginning of 1906. Because around that time, Kaufmann published the results of the http://en.wikipedia.org/wiki/Kaufmann%E2%80%93Bucherer%E2%80%93Neumann_experiments" .
http://en.wikisource.org/wiki/On_the_Constitution_of_the_Electron_(1905)
http://en.wikisource.org/wiki/On_the_Constitution_of_the_Electron_(1906)
Now, in these papers, Einstein is mentioned for the first time. Not only this: The latter paper also contains a comparison between the theories of Lorentz and Einstein. Kaufmann wrote:
Kaufmann said:
It is now very remarkable, that, starting from quite different assumptions, Einstein recently arrived at results, which are in agreement with those of Lorentz concerning the consequences accessible to observation, though in which the previously mentioned difficulties of epistemological kind have been avoided. Einstein introduced the principle of relative motion, at least as regards translations, as a postulate. He thus places the theorem at the top, that physical phenomena observable in any rigid system, must be independent from whether the system (together with the observer) is moving relatively to any other system.
Since we know, that Lorentz was well acquainted with Kaufmann's papers, it's clear that he was therefore also aware of Einstein's theory in 1906.
As regards Poincaré: I don't know whether he ever read Einstein's paper. In fact, he never cited Einstein in connection with relativity (also Einstein ignored Poincaré's relativity contributions)... More on that topic is written by Darrigol:
http://www.journals.uchicago.edu/doi/full/10.1086/430652
Regards,
  • #59
GrayGhost said:
[..]Why would a detection of the 1-way speed of light not be useful in distinguishing which theory possesses the correct foundation?
GrayGhost
Perhaps my reply was ambiguous... it's really explained (to first order) in the paper that I referred to, at the place that I referred to. Here it is again:
http://en.wikisource.org/wiki/The_Measure_of_Time - especially in XII and XIII.
Harald
  • #60
Of course it's the topic. Lorentz himself used (for good reasons) the expression "preferred", in so far as clocks at rest in this aether indicate the "true" time and an "absolute" simultaneity (see the numerous quotes above, where Lorentz used exactly this terminology). Here is another quote by Lorentz (from 1909), where he also elaborated on the conceptual differences between LET and SR: pp. 229-230, http://www.archive.org/details/electronstheory00lorerich
Lorentz1909 said:
I cannot speak here of the many highly interesting applications which Einstein has made of this principle. His results concerning electromagnetic and optical phenomena [..] agree in the main with those which we have obtained in the preceding pages, the chief difference being that Einstein simply postulates what we have deduced, with some difficulty and not altogether satisfactorily, from the fundamental equations of the electromagnetic field. By doing so, he may certainly take credit for making us see in the negative result of experiments like those of Michelson, Rayleigh and Brace, not a fortuitous compensation of opposing effects, but the manifestation of a general and fundamental principle.
Yet, I think, something may also be claimed in favour of the form in which I have presented the theory. I cannot but regard the ether, which can be the seat of an electromagnetic field with its energy and its vibrations, as endowed with a certain degree of substantiality, however different it may be from all ordinary matter. In this line of thought, it seems natural not to assume at starting that it can never make any difference whether a body moves through the ether or not, and to measure distances and lengths of time by means of rods and clocks having a fixed position relatively to the ether.
It would be unjust not to add that, besides the fascinating boldness of its starting point, Einstein's theory has another marked advantage over mine. Whereas I have not been able to obtain for the equations referred to moving axes exactly the same form as for those which apply to a stationary system, Einstein has accomplished this by means of a system of new variables slightly different from those which I have introduced. I have not availed myself of his substitutions, only because the formulae are rather complicated and look somewhat artificial, unless one deduces them from the principle of relativity itself.
You also write:
Lorentz clearly said, that "true" and "local time" are not equally valid. And this was one of the reasons that he didn't "proceed more systematically". So it's not simply an "error" - it's a conceptual issue that hindered Lorentz to achieve complete Lorentz covariance. Here again the quote: http://en.wikisource.org/wiki/Two_Papers_of_Henri_Poincar%C3%A9_on_Mathematical_Physics
Do you still (like the generous Poincaré) want to downplay this issue?
According to this argument, Joseph Larmor would be the inventor of SR, who already in 1897 and 1900 had the complete transformation. Now, the reason why neither Larmor nor Lorentz is credited with relativity, simply lies in the fact, that they didn't possesses the correct interpretation and thus were unable to derive all possible consequences. For example, Larmor only restricted the application of the transformation to second order effects, neglecting all others. And for Lorentz, t and t' were "essentially different", which (as explained by himself) hindered him to achieve full Lorentz covariance.
You have to explain this to Lorentz, not to me. :wink: Look, the problem is that we have to be careful, when we speak about "physical" time when referring to Lorentz's application of this time variable, since Lorentz himself said in 1909, 1913, 1914, 1927 etc.., that time t' was only a mathematical artifice, which includes also the "modified" local time (including time dilation) from 1899 and 1904...
The topic's title is "Did Lorentz or Einstein theoretically derive special relativity?". All of the quotes I brought show, that Lorentz did not regard himself as having derived SR. And this is in agreement with the modern interpretation by most reputable Historians of Science (Holton, Pais, Miller, Stachel, Janssen, etc.) Off-topic are your references to Einstein's non-technical aether papers and lectures, which were ignored in any physics-textbooks in the last 70 years, while his initial judgments from 1905-1909 are still valid and accepted.
Regards,
  • #61
Dear Zentralls, Einstein closely followed the writings of Poincare who discussed that issue in, again:
http://en.wikisource.org/wiki/The_Measure_of_Time (especially section XII)
Enjoy :smile:
  • #62
Histspec said:
Of course it's the topic. Lorentz himself used (for good reasons) the expression "preferred", in so far as clocks at rest in this aether indicate the "true" time and an "absolute" simultaneity [..].
Your comment ignores the context of my reply to GreyGhost. "Preferred" was used at that time to designate a frame that is preferred for the description of physical phenomena. I explained that according to the PoR no inertial frame can be preferred in that sense; and consistent with that Lorentz did not (as far as I know, and apparently also as far as you know!) use the expression "preferred" for a PoR-compatible ether. If he did, that would have created a lot of confusion.
Similarly, do you still (like the generous Lorentz) want to blow that issue out of proportion? This is not a place for dog fights and the question of the OP has been sufficiently answered.
That would certainly be the case if Larmor's transformations were intended to show the complete impossibility of detecting absolute inertial motion; but I doubt that.
[..] You have to explain this to Lorentz, not to me. :wink:
Lorentz explained it to you and Einstein. :wink:
As I showed, Lorentz described the physical slowdown due to motion in 1899; the logical connection between his time dilation and his t' is what I meant with "the penny had not yet dropped". That was a problem for him then but not for Poincare and Langevin in 1904, nor for us now.
Regards,
I showed similarly that SR includes Lorentz's work of 1904, as it was Einstein who later named the theory that according to him in 1907 followed from both papers, "SR". Modern interpretation is increasingly aware of the full history of which even Lorentz was only partially aware, as more old documents are made easily available to all.
Thanks to that nowadays Poincare is acknowledged for his contributions to SR, while in the past he was often completely overlooked.
And references to papers that clarify and balance some of your citations that you seemed to misunderstand are certainly appropriate; only a desire to obscure such clarifications can explain an allergic reaction to them.
Regards,
Harald
  • #63
Perhaps it's useful to present a little timeline for the OP and other onlookers who may have lost track.
A number of people worked in the 19th century on trying to fit theory to experiment, but all or most of them were just adapting after-the-fact; although they made contributions to the development, I will omit them here.
- In 1904 and at the request of Poincare, Lorentz published a new theory that was intended to perfectly comply with the PoR. The Lorentz transformations follow directly from this paper. However he was confused about the meaning of "time" t' and he made a few small errors in the equations for current and charge. As a result it was just not perfect.
- In June 1905 Poincare published a commentary on Lorentz's paper in which he presented the Lorentz transformations in the symmetrical form as we know them today, in order to emphasise the group property. With that he established the perfect invariance of the electromagnetic equations and he corrected some errors of Lorentz's paper which he deemed to be minor.
- In September 1905 Einstein published a paper with a similar title as the former and also with the purpose to obtain a theory that obeys the PoR. He also established the Lorentz transformations and the full invariance of the electromagnetic equations. On top of that he discussed such topics as time dilation and Doppler effect.
Poincare gave the honour to Lorentz (without mention of Einstein), Einstein gave the honour to Lorentz and himself, and Lorentz gave the honour to Poincare and Einstein.
Many more papers were published on the topic, see the list here:
And an overview of the related priority debate with many sources can be found here:
PS. With that I un-subscribe of thread which isn't really about physics :-p
  • #64
For the mainstream view (based on Janssen, Stachel, Darrigol, Pais, Holton, Miller etc.), some readers might also be interested in
http://en.wikipedia.org/wiki/History_of_special_relativity"
Anyway, it is interesting, that even with so many direct quotations as given in this thread, no agreement could be achieved. It's quite clear to me (and to most mainstream historians of science as well), that the theory Lorentz created between 1892-1904 is not special relativity (as Lorentz himself clearly said). Of course, this should not be understood as a criticism of Lorentz. He was one of the greatest physicists of all times, and without him, modern physics would probably look very different today.
Thanks for the interesting discussion.
Regards,
  • #65
There were many experiments that were important for the development of the Lorentz transformation.
*The aberration of light, which showed that the aether is not completely dragged by matter. This also refutes the idea, that Earth is "one big inertia frame of reference".
*The http://en.wikipedia.org/wiki/Fizeau_experiment" , which gave more details on "aether entrainment". However, it was shown by Lorentz, that no aether entrainment is necessary at all to explain the result.
*The negative aether drift experiments, most importantly Michelson-Morley.
*The http://en.wikipedia.org/wiki/Moving_magnet_and_conductor_problem" , showing that em-processes are only depending on relative motion.
*The success of Lorentz's stationary aether theory (light speed is independent of the source speed).
You will find, that it is hardly possible to explain all of those things without inventing the Lorentz transformation (as it was done by Voigt, Lorentz, Larmor, Poincaré, Einstein).
To which experiments are you referring to?
For example, the http://en.wikipedia.org/wiki/De_Sitter_double_star_experiment" was not done before 1913.
Regards,
  • #66
Histspec,
I thank you for your references you provided. I've been trying to blend the fine references from both you and Harrylinn, in search of a single consistent synopsis.
Harrylinn suggests that Poincare's 1905 re-interpretation of Lorentz's 1904 paper made the spacetime transformations equivalent to Einstein's 1905 work (ie SR), except that their foundations differ of course. However Harrylinn also makes the assumption that Lorentz understood time dilation prior to 1904 based on other historical documents. Yet, it would seem by Lorentz's own statements thereafter, that he either did not, or that he disbelieved it even if he was aware. In either case, Poincare should get the credit for the icing on the cake for his 1905 modifications.
If I may ask you, and even considering Lorentz's modifications, do you assume that the transformations "mean the same thing" in SR and LET? Here's the reason I ask ...
Wrt LET, my understanding is that true simultaneity is defined only by those at rest with the aether frame. If this is true, should not the meaning of t' in LET theory have to differ from the meaning of t' per SR, for the LT solns to be mathematically the same? It has always seemed to me that if each theory considers time dilation something "a little different", then the LTs cannot mean the very same thing, even though they are mathematically the same. This is why I've always questioned whether LET supports the PoR wrt force, as opposed to kinematics alone. Scenario ...
If 2 identical falling weights strike the 2 trays of a balanced scale "simultaneously", with trays-centerline colinear with propagational path, then they should not tilt. However, LET requires that synchronised clocks (per the balance) attached to the each scale pad are not simultaneous per the aether frame. Hence, the scale should tip per LET if the weights strike the pads when they display identical clock readouts.​
Is there a flaw in my reasoning here? Please realize that I understand how SR handles this, and that I am asking only in regards to LET here. Or, is my understanding of LET mistaken maybe?
thanx,
GrayGhost
  • #67
Histspec,
Harrylinn suggests that Poincare's 1905 re-interpretation of Lorentz's 1904 paper made the spacetime transformations equivalent to Einstein's 1905 work (ie SR), except that their foundations differ of course. However Harrylinn also makes the assumption that Lorentz understood time dilation prior to 1904 based on other historical documents. Yet, it would seem by Lorentz's own statements thereafter, that he either did not, or that he disbelieved it even if he was aware. In either case, Poincare should get the credit for the icing on the LET cake for his 1905 modifications. Yet, Einstein's 1905 OEMB became the accepted theory.
thanx,
GrayGhost
  • #68
Wrt LET, my understanding is that true simultaneity is defined only by those at rest with the aether frame. [..] is my understanding of LET mistaken maybe?
thanx,
GrayGhost
Hi GreyGhost I could not resist another look at this thread; evidently I did not give you a satisfying answer, perhaps because I was not inclined to solve again another paradox now.
There is however also a generic answer from a modern perspective; I don't know if that will answer your question, or if it will be helpful. However it may also clarify my earlier remarks about being consistent with how the words "theory" and "interpretation" are used nowadays. So here we go:
In the QM forum we're discussing Bell's Theorem about the question if there can be "hidden variables" that explain the correlation between distant entangled particles. This theorem led to the concept that the "collapse of the wave function" implies "spooky action at a distance" at infinite speed. There are other interpretations, but this is one of the main interpretations (note: I'm still not convinced). See Bell's explanation here (near the end, third option):
http://cdsweb.cern.ch/record/142461?ln=en
As a consequence of this popular interpretation, there would be a "true" inertial frame of reference for this action, relative to which such hidden influence occurs simultaneously at distant places; the simultaneity of frames that are in motion relative to it is then only apparent (although it works just as well for a description of the phenomena).
Such an interpretation of SR sounds very much like "LET", but with a new and unheard of property that allows for influences much faster than light. Some people even call it a "preferred" frame for reasons that escape me, for no deviation of SR is implied at all.
And as I tried to make clear before, it's irrelevant for the description of the phenomena and their prediction if we assume them to be caused by an unobservable hidden reality or not. But it is relevant for the question of this thread if "special relativity" is regarded as a theory in the sense that Newton and Lorentz used that word (incl. what some call "metaphysics"), or in the operational sense in which Einstein and many people nowadays use that word.
For more on this, see Tim Maudlin's book "Quantum Non-Locality and Relativity: Metaphysical Intimations of Modern Physics".
You can browse through it here:
https://www.amazon.com/dp/0631232214/?tag=pfamazon01-20Harald
PS if you like to discuss the puzzle that you presented here: please start it as a new topic so that others who are not interested in history will notice hat topic.
  • #69
GrayGhost said:
Hence, the scale should tip per LET if the weights strike the pads when they display identical clock readouts... is my understanding of LET mistaken maybe?
Yes, your understanding of LET is mistaken. The balance beam doesn't rotate (at the fulcrum) according to either SR or [the final version of] LET, because they are empirically equivalent, both kinematically and in terms of forces and dynamics.
True, but SR likewise entails that the clocks are not synchronized per the frame that you are calling the aether frame. Nevertheless, the beam doesn't rotate at the fulcrum. You said you understand how SR handles this, so you must also understand how LET handles it, because they handle it the same way. The only difference is purely a metaphysical one.
GrayGhost said:
...do you assume that the transformations "mean the same thing" in SR and LET?
It isn't an assumption, they mean the same thing, physically, by definition. Take special relativity, and declare that one of the infinitely many systems of inertial coordinates is named "Fred", although you are unable to say which one it is, and you are unable to identify any physical consequences of being named "Fred". This is LET (if you replace the word "Fred" with the word "True").
By the way, be wary of anyone trying to tell you that this has something to do with quantum entanglement and/or hidden variables. It doesn't. Relativistic quantum mechanics is, well, relativistic. Some people focus on the early non-relativistic version of quantum mechanics, and they point out that it is (gasp) non-relativistic. Needless to say, that kind of "reasoning" is misguided. Also, be wary of anyone trying to tell you that the difference between SR and (the final version of) LET is something other than metaphysical, even though they concede that the two are empirically indistinguishable.
  • #70
Let's not overlook the fundamental mathematical difference between SR and LET. I believe someone might have already posted Einstein's derivation of the Lorentz transformation. Lorentz wrote a detailed description of it himself in a later edition of his monograph.
The essentials of the Lorentz derivation are very different (https://www.physicsforums.com/showpost.php?p=3328134&postcount=6) Lorentz made no assumptions or postulates. He merely used (already by then) previously used techniques for solving differential equations to arrive at new coordinates that could simplify the analysis of EM and optical problems. Only the transformation of variables is the same between SR and LET. Lorentz employed the transformed differential equations, including those for media, to arrive at optical and other solutions.
Einstein and Minkowski used tensor equations very different from the differential equations Lorentz employed. Their use of equations for media was minimal and not a centrally important consideration as was the case for Lorentz. In fact, no exact solutions for media were possibly to find by Minkowski. He needed to do some averaging of certain parameters while Lorentz's solutions were exact.
It's the operations around the transformation that are most important and those operations are not the same between the 2 theories, at least they were performed in very different ways and are not subject to the same limitations.
