- #71
Histspec
- 132
- 55
GrayGhost said:If I may ask you, and even considering Lorentz's modifications, do you assume that the transformations "mean the same thing" in SR and LET? Here's the reason I ask ...
As Samshorn (and Lorentz in the quoted passages) already explained -
Observationally: The same.
Metaphysically: Not the same.
(Of course, this applies to Poincaré's version, not to Lorentz's 1904-theory).
If 2 identical falling weights strike the 2 trays of a balanced scale "simultaneously", with trays-centerline colinear with propagational path, then they should not tilt. However, LET requires that synchronised clocks (per the balance) attached to the each scale pad are not simultaneous per the aether frame. Hence, the scale should tip per LET if the weights strike the pads when they display identical clock readouts.
Simply replace LET with SR, and "aether frame" with "non-co-moving frame". Then you will understand, that if your proposal is correct, not only LET, but also SR would be violated. Since this isn't the case, your thought experiment is wrong.
Regards,
