- #106
NanakiXIII
- 392
WannabeNewton said:This is true only if the map is an isometry by definition. I gave you an easy counter example in the above post. A diffeomorphism between riemannian manifolds is not in general an isometry!
Granted, this is what this construction does.
micromass said:Are you claiming that all diffeomorphisms are isomtries?? I think there are many counterexamples for this statement. Wbn gave one already.
TrickyDicky said:I believe Nanaki( and not only him, this thread seems to be going in circles because some distinctions are being overlooked) is falling into two of the mistakes I warned against in a previous post, conflating local diffeomorphisms with local isometries and also local diffeomorphisms with diffeomorphisms.
When you have a diffeomorphism that preserves the metric, you have an isometry, this has been sufficiently stressed by WN and micromass, the problem is that in GR, as commented already by haushofer, atyy and me, the diffeomorphisms alluded by the term "diffeomorphism invariance", have to do with "no prior geometry" and are related to gauge invariance so can't be promoted to isometries.
So if we want to talk about geometry we must restrict ourselves to the local geometry, that is local isometries, these are not bijective but are injective and preserve curvature which is important for a physics theory that identifies gravity with curvature.
Now local isometries are just local diffeomorphisms that pullback the metric tensor. Maybe some of the confusion of Nanaki comes from the fact that local diffeomorphisms induce by the inverse function theorem a linear isomorphism(thus this one is bijective) at each point of the manifold.
I really don't know what your definition of a diffeomorphism is then. Mine makes no mention of geometry at all. It's a pure mapping between manifolds. See e.g. Spivak. Isn't this the type of diffeomorphism GR is invariant under? If you go to Riemannian manifolds and you include your type of transformations, where you deviate from using the pullback metric, then obviously you're going to violate things.
