- #36
- 24,492
- 15,024
Well, so what?Demystifier said:As I said, by Neumarks's theorem, all measurements are projective measurements in a larger Hilbert space.
Sure, that's nothing new compared to the standard (minimal) interpretation. A particle cannot be precisely localized but the Heisenberg uncertainty relation always holds. You can of course always measure the position as accurately as you want, and if you do this accurately enough (i.e., with sufficient resolution) you get ##|\psi(x)|^2## as the position-probability distribution. What has this to do with the projection or collapse postulate?atyy said:I'm not sure about a real-world experiment, but the proposed formalism gives a sharp position measurement in the sense that if the wave function is ##\psi(x)##, the distribution of outcomes is ##|\psi(x)|^2##. However, it does not allow preparation of a particle with a definite position (since the state is not in the Hilbert space). So sharp position measurements are possible in some sense, but they do not prepare position eigenstates.
So one can say that the projection rule is universal, applicable to all types of measurements (not merely to some special idealized measurements), provided that one considers the whole closed system including the measuring apparatus.vanhees71 said:Well, so what?
Von Neumann projection/collapse postulate does not claim that. Instead, it claims that the state of the whole closed system (measured system + apparatus + environment + observer) gets projected into one term of the entangled superposition.vanhees71 said:Yes, but what has this to do with the projection or collapse postulate? It does not say that if I meausure a particles spin component to be "up" that I have necessarily prepared a particle with spin up, and that's what's claimed by the projection or collapse postulate.
Von Neumann was completely aware of that, so to avoid the contradiction he postulated two types of evolutions. One is valid when conscious observations are present, the other when conscious observations are not present.vanhees71 said:Ok, but that contradicts the formalism it claims to interpret.
Demystifier said:By SG apparatus I mean the magnet plus the detector.
Demystifier said:I assume that I can first measure the spin of atom in the z-direction, and later measure the spin of the same atom in the x-direction. Are you saying that it's impossible?
Yes, and I don't agree with this solipsistic interpretation. Concerning physics, never listen to mathematicians (and the other way: concerning mathematics better listen to the mathematicians ;-)).Demystifier said:Von Neumann was completely aware of that, so to avoid the contradiction he postulated two types of evolutions. One is valid when conscious observations are present, the other when conscious observations are not present.
In your interpretation there are no two types of evolutions, but it doesn't make your interpretation simpler because in your interpretation there are two types of something else. Your interpretation has two standards of relevance. Some quantities (the values of observables) are relevant only when they are measured, while other quantities (e.g. the state) are relevant at all times. But you do not follow this relevance rule strictly. For instance, the values of conserved observables are in your interpretation relevant even when they are not observed. But it's impossible to prove your interpretation inconsistent because you never state your standards of relevance explicitly.
vanhees71 said:I don't agree with this solipsistic interpretation.
That's all fine with me when you just stop after Eq. (2.92). The claim what the state after the measurement is, is dependent on the situation (the experiment) you describe. In general I don't think that you have a pure state after the measurement, because the measured system is entangled with the measurement device ("immediately after the measurement") and thus the system's state given by the partial trace (tracing out the system), and this leads to a mixed state for the system rather than a pure state after the measurement.kith said:Here is the full version of Nielsen & Chuang's postulate 3:
As far as I can see, this is the most general expression one can give for what happens to the quantum state when a measurement is performed (if one includes only the system of interest in the quantum description). If one tries to replace the Kraus operators [itex]M_m[/itex] by something more general one runs into problems with probabilities not summing to one or the like. So this should apply to all kinds of measurements.
Whether the [itex]M_m[/itex] are easy to determine for a real measurement device is of course a question worth asking. But it is independent of the question whether the full postulate 3 needs to be included in the set of postulates or whether the state-after-measurement rule (2.93) (which is a generalization of the projection postulate) can be omitted.
If you just consider the magnet and not detecting the particles you have a preparation procedure for spin-component eigenstates (component in direction of the homogeneous part of the magnetic field), described by a unitary time evolution. The preparation is due to the entanglement (nearly 100% if you have a good design of the magnet and the incoming beam) between the spin component and the position (or momentum) of the particle.PeterDonis said:It depends on what you mean by "measure the spin".
If you mean put a filter after the z-direction SG magnet, which only allows the "up" beam to pass, and then put that beam through an x-direction SG magnet and put a detector after it, then yes, the filter can be considered a filter measurement (or, equivalently, as the preparation of a z-spin up state).
If you mean just put two SG magnets in series (or three--your SG, SG1, SG2 scenario), with no filtering, then the first magnet is not a measurement, because there is no filter and no detector; if there were a detector after the first magnet, it would absorb the atom and make it unavailable for the other magnets.
That's precisely the question. Which additional postulates do you mean? Why precisely do you think that the minimal statistical interpretation is incomplete? You always claim Ballentine's textbook is fundamentally wrong, but there's no convincing argument for that claim. It's just an opinion.atyy said:I suspect that @vanhees71 refers to a closed system, because he believes that we can in principle include the observer and measurement apparatus in the quantum state, so that there is only unitary evolution. This is also my reading of what Ballentine means in his textbook, given his criticism of standard QM. I believe that postulating unitary evolution without state reduction is not correct unless one introduces additional postulates (eg. as attempted by many worlds, hidden variables, which also remain non-standard).
vanhees71 said:That's precisely the question. Which additional postulates do you mean? Why precisely do you think that the minimal statistical interpretation is incomplete? You always claim Ballentine's textbook is fundamentally wrong, but there's no convincing argument for that claim. It's just an opinion.
I think it's a philosophical standpoint rather than a valid critique of QT as a physical theory. You seem to consider QT as incomplete ...
vanhees71 said:Projective measurements are very rare and very hard to realize!
Is it possible to detect an atom without absorbing it?PeterDonis said:if there were a detector after the first magnet, it would absorb the atom and make it unavailable for the other magnets.
Von Neumann was much more than just a mathematician. He was the first who understood what physically happens with the state of the closed system during the measurement, using non-rigorous physical arguments. It's now called Von Neumann theory of measurement. He was also the first (or maybe the second, after Landau) who introduced the concept of density matrix in quantum physics, in a physical fashion.vanhees71 said:Concerning physics, never listen to mathematicians
vanhees71 said:Nowadays the measurement data are stored in some computer file and read by a "conscious observer" months after the data are taken. The measured system is long gone. For me von Neumann's interpretation is esoterics and has nothing to do with science.
In the book he explicitly makes a testable prediction that the quantum Zeno effect does not exist. Experiments prove him wrong.vanhees71 said:You always claim Ballentine's textbook is fundamentally wrong, but there's no convincing argument for that claim.
If so, then the state of the closed system (the measured system + the measurement device) is in the macroscopic superposition. It's a superposition of different possible measurement outcomes. Yet only one outcome actually realizes, we never observe superpositions of different possible outcomes. Do you agree that, when we learn what the actual outcome is, we can update our knowledge by using the state (2.93) in post #43?vanhees71 said:In general I don't think that you have a pure state after the measurement, because the measured system is entangled with the measurement device ("immediately after the measurement") and thus the system's state given by the partial trace (tracing out the system), and this leads to a mixed state for the system rather than a pure state after the measurement.
Yes, and the latter is his great achievement concerning quantum theory. His part on "interpretation" is not so brillant. That's known since Herman's work in the 30ies.Demystifier said:Von Neumann was much more than just a mathematician. He was the first who understood what physically happens with the state of the closed system during the measurement, using non-rigorous physical arguments. It's now called Von Neumann theory of measurement. He was also the first (or maybe the second, after Landau) who introduced the concept of density matrix in quantum physics, in a physical fashion.
Of course, as a mathematician he also contributed significantly to rigorous functional-analysis style formulation of quantum mechanics, but that's another story.
Of course, we update our knowledge, but whether after that the system is in the state (2.93) cannot be answered without knowing the specifical experiment. If a photon is absorbed by the measurement (2.93) is not the state of the em. field after the measurement but it's the vacuum state.Demystifier said:If so, then the state of the closed system (the measured system + the measurement device) is in the macroscopic superposition. It's a superposition of different possible measurement outcomes. Yet only one outcome actually realizes, we never observe superpositions of different possible outcomes. Do you agree that, when we learn what the actual outcome is, we can update our knowledge by using the state (2.93) in post #43?
But von Neumann claims the state collapse only occurs after a conscious being hat taken note of the measurement result. This doesn't make scientific sense! This has nothing to do with "classical common sense".Lord Jestocost said:Statements like “Nowadays the measurement data are stored in some computer file and read by a "conscious observer" months after the data are taken.“ exactly mirror the fundamental misunderstanding of the messages send by quantum mechanics. Such statements are nothing but "classical common sense" imaginations, but the mathematics of the purely quantum-mechanical von Neumann measurement chain speaks something else.
That's true. Where is this statement in his book? One has to see the context.Demystifier said:In the book he explicitly makes a testable prediction that the quantum Zeno effect does not exist. Experiments prove him wrong.
The vacuum state is a state of EM field. Therefore (2.93) is correct even in this case. Indeed, the theory of measurement around (2.93) is the general theory of measurement. As far as we know, all measurements (not just projective ones) satisfy those principles.vanhees71 said:Of course, we update our knowledge, but whether after that the system is in the state (2.93) cannot be answered without knowing the specifical experiment. If a photon is absorbed by the measurement (2.93) is not the state of the em. field after the measurement but it's the vacuum state.
I already quoted his exact statement several times to you before. I'll not do it again, but I'm sure you can find it in the book by yourself.vanhees71 said:That's true. Where is this statement in his book? One has to see the context.
Perhaps, but there is something contradicting Ballentine.vanhees71 said:The quantum Zeno effect is simply due to the interaction with some measurement device stabilizing the lifetime of an unstable "state". There's nothing contradicting quantum-mechanical dynamics.
No (2.93) claims there's still a single-photon state collapsed to the state according to the measurement outcome! I say that all you can say from the formalism are the probabilities (2.92) for the outcome of measurements not in which state the measured quantum system is after the measurement. For the letter you need the details about the measurement apparatus and the interactions between the apparatus and the measured system.Demystifier said:The vacuum state is a state of EM field. Therefore (2.93) is correct even in this case. Indeed, the theory of measurement around (2.93) is the general theory of measurement. As far as we know, all measurements (not just projective ones) satisfy those principles.
Sorry but you are wrong, in a way that has nothing to do with interpretations and philosophy. You must have misunderstood something purely physical about POVM measurements.vanhees71 said:No (2.93) claims there's still a single-photon state collapsed to the state according to the measurement outcome!
The strategies that try to resolve the problem of introducing a "cut", by moving the cut around - or typically move it out of FAPP reach and think its solved by making bigger and bigger hilbertspaces. It somehow IMO misses the troublesome point and is like cheating. Unfortunately as long as we stick to particle physics (ie looking and small subsystems from distance) this seems to pass and seems like the least problematic way to interpret things as is.Demystifier said:Von Neumann was completely aware of that, so to avoid the contradiction he postulated two types of evolutions. One is valid when conscious observations are present, the other when conscious observations are not present.
vanhees71 said:But von Neumann claims the state collapse only occurs after a conscious being hat taken note of the measurement result.
Demystifier said:Is it possible to detect an atom without absorbing it?
