I Difference Between Lorentz Transformation & Special Relativity
BadgerBadger92
TL;DR Summary
https://m.youtube.com/watch?v
What exactly is the difference between special relativity and the Lorentz transformation? Reading about them they seem to be really similar.
Sorry for the extra question. Just have a lot of questions lately and I know some people around here are annoyed with that.
Special relativity is a physical theory. The Lorentz transform is a mathematical operation. Special relativity uses the Lorentz transform to make predictions about physical experiments.
Likes Wes Tausend, vanhees71, malawi_glenn and 2 others
Special relativity is a set of postulates regarding speed of light and inertial reference frames which forms an entire theory.
The Lorentz-transformation is a mathematical operation used to find the quantities measured in one inertial reference frame expressed as quantities measured in another inertial reference frame.
It's like asking what the difference between feynman diagrams and quantum field theory is.
Likes vanhees71 and topsquark
The Lorentz transforms are one way of defining Minkowski spacetime. Special Relativity is the physics of being in a Minkowski spacetime. Naturally, the Lorentz transforms turn up a lot.
It's a bit like the difference between Euclidean (and spherical) geometry and cartography. You can't do much cartography without an understanding of straight lines and angles, but cartography isn't just straight lines and angles.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
