I Do AEST (Absolute Euclidean Spacetime) models work?
name123
TL;DR Summary
Asking whether AEST (Absolute Euclidean Spacetime) models work, in the sense of giving the correct predictions?
I was reading a paper by J.M.C Montanus which was published in <low quality journal reference removed> in which he claims under AEST the new gravitational dynamics and electrodynamics are reformulated in close correspondence with classical physics, and subsequently leads to the correct predictions for the deflection of light and the precession of perihelia while being based on a flat spacetime. My question is, does the AEST approach work, while preserving proper time momentum, and flat Euclidean spacetime (even with gravity), or are there problems with it?
[As a side issue, the idea behind AEST seems linked to the ideas in Lewis Carroll Epstein's "myth" (apparently published in the book "Relativity Visualized" in 1981) in which everything moves at the speed of light. I have attached a picture from David Eckstein's explanation of the book, showing how the time dilation, length contraction, and relativity of simultaneousness.]
Didn't see file attached, so re-attaching
The Hadronic Journal is not very reputable certainly. It doesn’t even have an entry in the Clarivate Master Journal List, nor is it found at Eigenfactor. So for a “groundbreaking” paper to be found in such a journal is a bad sign.
On a technical perspective, the problem with space-propertime is defining what a point is in that concept. A point in spacetime is something that happens at the same place and time. So a collision is two objects whose worldlines intersect, at that point they are at the same place at they same time and they therefore collide at the intersection. With space-propertime there is no physical meaning of the points. Objects with intersecting worldlines don’t collide and objects that do collide don’t necessarily have intersecting worldlines.
The community doesn’t find such a notion useful, so it is banished to such journals.
Likes dextercioby and topsquark
What exactly is the paper?
It doesn’t matter, the journal doesn’t meet our standards so we won’t link to it here
The street address is some guy's apartment. Not a good sign.
Likes dextercioby, topsquark and Dale
He also has a paper in the Foundations of Physics Journal which seems to me to be in the Clarivate Master Journal List
Proper-Time Formulation of Relativistic Dynamics (Found. Phys. 31, Issue 9, Sep 2001, Pages 1357 - 1400)
There was also <another bad reference>
Also not sure what you mean by space-propertime having no physical meaning. In the Epstein explanation I mentioned by David Eckstein (David Eckstein Relativity search should find it), in the Epstein section (4.2 or C2) it seems to have an example where "A and B met at O and at that point both set their clocks to zero", and it shows how to use the diagram to predict time dilation, length contraction etc. It also seems to go onto indicate what is meant by propertime in C3 'Clocks that got synchronized at the meeting in O will any time later be located on a half circle centered in O. I would suggest the name synchrone for such a half circle. Both events, "Black reaching the space-time-position A" and "Red reaching the space-time-position B" are simultaneous for Black and Red, however both are telling us that the reading of the other's clock lies behind'
https://link.springer.com/content/pdf/10.1023/A:1012274211780.pdf
<bad reference removed>
Why are you interested in this? You would spend your time better if you studied relativity.
Likes Vanadium 50 and PeroK
Thanks for the link.
Personally I am interested more from a philosophical point of view. As I understand it, in the early 20th century it was thought by those such as the Vienna Circle that science had shown Kant's a priori idea of Euclidean geometry as the geometry of physical space to be proven wrong. Also Einstein in his book "Relativity the Special and General Theory", had seemed to think that there could be no definition of simultaneity that could be measured.
If that early 20th century thinking (by the Vienna Circle and Einstein) has later been shown to be wrong, then I'd be interested to knowing.
It hasn't.
Likes vanhees71 and topsquark
This is a better reference, let’s stick with this. This journal is a second or third tier physics journal, with a journal Eigenfactor ranked 45 out of 79. So it is acceptable to discuss here, but it should be remembered that this sort of journal is one that people publish in after being rejected by the first or second tier journals.
Unfortunately, it is behind a paywall and there does not seem to be a free version in my usual sources. So I am unable to judge that specific article. If it continues with the space proper-time concept then it is subject to the criticism I mentioned above.
Likes vanhees71
martinbn said:
It hasn't.
Why has AEST not offered a viable model compatible with the idea of Euclidean geometry being the geometry of physical space?
There is the other paper which I mentioned, by the same author, which can be freely read...
I mean that a single point in space-propertime is not a single well defined concept. This is in distinction to spacetime where a point in spacetime is clear and well defined. To me, building up a concept where the primitive element of that space is poorly defined can only lead to a poorly defined concept.
And which also does not meet our usual quality standards.
The issue is that there is no invariant definition of simultaneity. Einstein, in fact, established the Einstein clock synchronization convention (for defining and measuring simultaneity in a given inertial reference frame). Ironically, we are often faced with the argument on here that this is the only valid simultaneity convention.
Likes vanhees71
But with AEST I was thinking the simultaneity definition would be if they were simultaneous in proper time. Not to do with clocks (because of time dilation). But that both the clock values, and the proper time value could be worked out.
But I went on to give you an example. And mentioned that in the Epstein explanation by David Eckstein (David Eckstein Relativity search should find it), in the Epstein section (4.2 or C2) it seems to have an example where "A and B met at O and at that point both set their clocks to zero", and it shows how to use the diagram to predict time dilation, length contraction etc. It also seems to go onto indicate what is meant by propertime in C3 'Clocks that got synchronized at the meeting in O will any time later be located on a half circle centered in O. I would suggest the name synchrone for such a half circle. Both events, "Black reaching the space-time-position A" and "Red reaching the space-time-position B" are simultaneous for Black and Red, however both are telling us that the reading of the other's clock lies behind'
It seems to me that the point in spacetime where A and B are located on the half circle is well defined, and that what each state their location is, and what their clock reads, and what the other's location is and what the other's clock reads can be given, and agrees with TR's predictions.
Yes, I understand. There would be a single, absolute measure of simultaneity of any two events. Given what we know from SR then mathematically something has got to give. So, I'm not surprised by Dale's point:
This is the mathematical trick that circumvents the relativity of simultaneity. There are always mathematical tricks that can undermine any definitive statement. If you look at SR, there is an assumption that if particle A collides with particle B, then that is a single event. This essentially forces simultaneity every time they collide. Whereas, their clocks readings may show different elapsed proper times between collisions.
If you relax that assumption and allow the collision of particles A and B to be two non-simultanenous events, then you undermine the assumptions (essentially by redefining simultaneity).
In short, by changing the definition of simultaneity, you remove one of the assumptions that led to Einstein's conclusion.
Likes topsquark
name123 said:
TL;DR Summary: Asking whether AEST (Absolute Euclidean Spacetime) models work, in the sense of giving the correct predictions?
This is a clue that there's something wrong. The advance of the perihelion of Mercury, and the bending of starlight that grazes the sun were considered verification of Einstein's theory, but that was over 100 years ago. It's ancient history. Since then there has been a plethora of observations and experiments that confirm Einstein's theory much more convincingly. Any new theory of gravity would have to explain those observations and experimental results, too.
I encourage you to do a google search of Clifford M. Will and look at the publications and videos. Einstein's theory is not consistent with Euclidean geometry.
And by the way, the spacetime of special relativity is flat, but is non-Euclidean.
Likes topsquark
PeroK said:
Yes, I understand. There would be a single, absolute measure of simultaneity of any two events. Given what we know from SR then mathematically something has got to give. So, I'm not surprised by Dale's point:This is the mathematical trick that circumvents the relativity of simultaneity. There are always mathematical tricks that can undermine any definitive statement. If you look at SR, there is an assumption that if particle A collides with particle B, then that is a single event. This essentially forces simultaneity every time they collide. Whereas, their clocks readings may show different elapsed proper times between collisions.
In short, by changing the definition of simultaneneity, you remove one of the assumptions that led to Einstein's conclusion.
But as I understand it (and my understanding is admittedly sketchy), with AEST if particle A collides with particle B then that would be a single event which would be simultaneous for both A and B in proper time also. And clocks could be set to 0, and later when at a given point considered simultaneous in proper time, the clock values of A and B could be given from each perspective, and what those values would be would agree with SR.
Could you possibly point out some finding that you or Clifford M. Will think AEST is not compatible with?
Or are you claiming that AEST is not consistent with Euclidean geometry?
And with AEST the spacetime with gravity is also flat I think.
Flat Space Gravitation (Found. Phys. 35, Issue 9, Sep 2005, Pages 1543 - 1562)
(again by J.M.C Montanus)
If proper time is to mean anything then each particle keeps proper time and events are simultaneous if they have the same proper time. The problem with that is that A and B can collide twice, once when both clock's read zero. Same space-propertime event. Then, the next time, their clocks may read different proper times. Therefore, the second collision is two space-propertime events (one for A and one for B). And so A colliding with B (from A's perspective) is a different event from A colliding with B from B's perspective.
If not, then what is "proper time"?
Likes PeterDonis, Dale, martinbn and 1 other person
Sorry my mistake, I used the term proper time to mean absolute time.
So let me re-write. As I understand it, theories like AEST allow a definition of simultaneity in absolute time. But if A and B collide then they are obviously simultaneous in absolute time. If A and B collide again, again that would be a simultaneous event in absolute time, even though in the proper time of A it can be different to the proper time of B. But AEST can give the proper time of A and B, and explain why the events are simultaneous in absolute time. Also if A and B don't collide again, AEST can still state at which points A and B are simultaneous in absolute time.
If you were to search for Euclidean Relativity, I am sure you could find a site which links papers, which would outline what is being stated. It isn't just the idea that any frame of reference could be thought of as being absolute time. As I understand it, it is that all things are being thought to move at the speed of light. Nothing moves faster, nothing moves slower, but things do move in different directions in a flat Euclidean geometry.
Just to be clear, we're talking about the kind of ##x,\tau## diagram where the Euclidean length of the line is ##\Delta t##?
Of course you can get all the regular SR results out of it - it's just that instead of basing everything on ##\Delta \tau^2=\Delta t^2-\Delta x^2## it bases everything on ##\Delta\tau^2+\Delta x^2=\Delta t^2##, so it's just an alternative interpretation. I think it's a much inferior one, since you can't interpret the diagram as a map of spacetime because a single event can appear at multiple locations. That means that it's really hard to do any actual physics in this interpretation, and I can't see any upsides. It might be a useful representation in specific circumstances, but I can't see how it could be generally useful.
Likes robphy
Radar ranging of Venus.
Why what does AEST predict?
I don't think it can predict anything. As far as I can see, to be able to reinterpret the metric in this Euclidean fashion requires a hypersurface orthogonal time coordinate with a constant ##tt## metric component and a Euclidean metric on the spacelike planes, which you don't have in this case. (That is, it only works in flat spacetime because it's a mathematical trick that relies on the properties of particular types of global coordinate schemes that only fit flat spacetime.)
That is a misunderstanding, and is exactly the problem with space proper time. When A and B collide they do not necessarily have the same proper time. For example, in the twins scenario, when they reunite. So the reunion event, where the twins meet, is two different points in space-propertime.
Frankly, the “benefit” one gets by using a Euclidean metric is far outweighed by the disadvantage of not being able to tell when things collide.
Also, as far as I can tell there is no causal structure to space-propertime
Likes robphy, PeroK and Ibix
I don't know. I was just pointing out that the bending of starlight and the advance of the perihelion of Mercury were touted as great confirmations of general relativity, and that since that time many many more experiments have been done with far far greater precision. That means they are primarily of historical significance.
So a paper written in the 21st century claiming to explain those two observations from over 100 years ago, and ignoring all the far more precise observations and experiments that have been done in the last 100 years, is highly suspect.
Likes PeroK
Yes, which is why I stated that you had a misunderstanding. Your example is wrong. Space-propertime doesn’t work the way you claim it does.
Yes, you can pick one event, say the departure, to coincide in space-propertime. But then the reunion will be two separate points. That is the problem.
Likes PeterDonis and PeroK
  • #31
Just to illustrate @Dale's point, consider a kind of repeated twin paradox. We have triplets, one who stays at home (purple), one who travels at 0.6c (red) and one who travels at 0.8c (blue). At time zero the travellers set off and return simultaneously at some later time, shake hands, turn around and repeat their trips. Below is a regular Minkowski diagram (left) and an Epstein diagram (right)
Note how you can't see from the right hand diagram that the travellers meet at home. And if you want to do something like add radar pulses to illustrate the Doppler analysis of the twin paradox, you can't do it. Light like lines satisfy ##x=t+\mathrm{const}## so ought to be drawn horizontally, but then how do you draw a radar pulse reflecting off something and returning? That's what I meant about not really being able to do actual physics in this scheme.
Likes PeterDonis, Dale and PeroK
  • #32
View attachment 317608View attachment 317609
Like I said, something's got to give! You want Euclidean spacetime? The simple, logical physical model has got to go.
Likes Ibix
  • #33
Ibix said:
Light like lines satisfy x=t+const so ought to be drawn horizontally, but then how do you draw a radar pulse reflecting off something and returning? That's what I meant about not really being able to do actual physics in this scheme
Similarly, causes can come after effects in a space-propertime diagram. That makes writing laws of physics almost impossible in terms of space-propertime.
  • #34
name123 said:
And I thought the point was that the length of the lines would be equal, and that would tell you that those events would be simultaneous in absolute time
As I said, you misunderstood the diagrams.
  • #35
name123 said:
If you look at the 4.7 under the Epstein section in the Epstein explanation by David Eckstein, then he does an Epstein diagram for the twin paradox. And I thought the point was that the length of the lines would be equal, and that would tell you that those events would be simultaneous in absolute time (whether they met up, or whether the traveling twin had carried on and never turned back).
The lengths of the lines are equal. That doesn't say anything about absolute time (there's no such thing), but tells you that they are simultaneous in coordinate time. But I challenge you to recognise that the lengths of the lines are equal without getting a ruler (and a realistic acceleration will make a curve and the diagram will be unusable). And I repeat - how are you going to draw radar pulses on this diagram? It's more of a hindrance than help, IMO.
Likes Dale
  • #36
name123 said:
Well I've attached a picture. It did seem pretty clear.
And I've also attached a figure showing multiple objects, two of which have negative proper times. Montanus writes: "If one likes, the reversed proper-time can be conceived as if the hands of the 'internal clock' of particle G are rotating counterclockwise. According to the AEST theory a backwards running proper-time means that the particle behaves in an opposite way. Alternatively, if particle B and particle G have opposite properties, then particle G can be regarded as an antiparticle."
And regarding the diagram he also states: "The parameter axis ct is drawn perpendicular to the x1, x4 -plane. After a simultaneous start in the origin, the simultaneous positions of the objects constitute a circle, whose radius increases as much as the time parameter. The result is a cone in a tree dimensional diagram."
It's bad enough discussing these ideas, but discussing them with someone who doesn't even understand them, but simply has a philosophical ax to grind with modern physics seems like a total waste of time.
Likes Dale, Vanadium 50 and martinbn
  • #37
Were you of the mind that the length of the lines wouldn't be the same, or that them being the same doesn't indicate that those events would be simultaneous in the absolute spacetime of AEST? Or was it perhaps me using the phrase "simultaneous in absolute time"?
  • #38
Can one draw
light signals or
a light cone
or a light clock
in a space-propertime diagram?
If not, then your diagram is missing significant elements of a position vs time graph, and thus does not provide a complete map of spacetime (as a Minkowski diagram does).
  • #39
name123 said:
there is (as I understand it) a preferred frame of reference where all things move through absolute spacetime at the speed of light
The object referred to here is not a valid frame of reference, since it does not uniquely map events to coordinates.
Also, the statement that all things move through absolute spacetime at the speed of light does not, ironically, work for light itself. This viewpoint completely ignores the fundamental difference between timelike and lightlike objects and tries to treat them the same. That doesn't work.
@name123, do you want a simple answer to the title question of this thread? The simple answer is no.
If you want more than that, then I think @PeroK's comment in post #38 is highly apposite: you need to first understand the viewpoint you are asking about. Then you will understand why it does not work.
Likes Dale and PeroK
  • #40
name123 said:
The postulate is that in the absence of gravitation all objects move with a four-dimensional Euclidean velocity equal to the speed of light in a vacuum.
You can of course play around with the math to define a "four-dimensional Euclidean velocity" that works this way. But you have to do it differently for timelike and lightlike objects.
For timelike objects, just write (I'll use units in which ##c = 1## to avoid cluttering up the math):
d \tau^2 = dt^2 - dx^2
And then divide through by ##d \tau^2## and take the square root:
1 = \sqrt{ \left( \frac{dt}{d\tau} \right)^2 - \left( \frac{dx}{d\tau} \right)^2 }
The ##1## on the left is the "four-dimensional Euclidean velocity" (which would be ##c## in conventional units).
But of course you can't do this for light, because ##d\tau^2 = 0## for light and you can't divide by zero. So you have to do some different mathematical trick to define a different "four-dimensional Euclidean velocity" for light. The most common such trick is to simply define the ordinary 3-velocity of light in any inertial frame (which frame doesn't matter since it's the same in all) as the "four-dimensional Euclidean velocity".
name123 said:
I again will attach the three diagrams, and mention that A and E can be considered photons.
The diagrams, as far as I can tell, are just showing the math referred to above in different ways.
name123 said:
For the AEST not to work, there would presumably have to be a result that TR can provide that it either doesn't agree with, or cannot provide. Would you agree?
No. As far as I can tell, AEST is just rewriting the math of standard SR, so it can't possibly make different predictions from standard SR. But that also means it can't possibly justify different physical claims from standard SR. But it makes different physical claims from standard SR (and also claims to include gravitation, which standard SR does not). That is the part that doesn't work.
Likes PeroK
  • #41
name123 said:
And I've also attached a figure showing multiple objects, two of which have negative proper times. Montanus writes: …
Which source is this? You are persistently citing unacceptable sources. Continuing to try to sneak them in will close this thread. I have temporarily deleted all of your recent posts with these unidentified references until you can clarify this. Once you have clarified the sources then I can undelete the posts
  • #42
So regardless of whether a person writes papers for journals which you count as acceptable, and thus is a presumably trusted author, you seem to be saying that nothing they have written other than what was in the papers in those journals can be quoted. So no quoting from books, or letters or anything like that, even if the author has written papers for journals. Have I understood you correctly?
The author I was quoting, has written the following papers on this topic, in the following journals that are listed in Clarivate Master
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 4, nr 3, 1991)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 5, nr 4, 1992)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 6 nr 4, 1993)
https://www.researchgate.net/publication/243586166_General_Relativity_in_an_Absolute_Euclidean_Space-Time (Physics Essays, vol 8, nr 4, 1995)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 10, nr 1, 1997)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 10 nr 4, 1997)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 11, nr 2, 1998)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 11, nr 3, 1998)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 11 nr 4, 1998)
https://www.researchgate.net/profile/J_Montanus/publications (Physics Essays, vol 12 nr 2, 1999)
It isn't the only topic he writes on.
I had assumed the rationale behind having certain restrictions on articles was to weed out work from authors that hasn't been suitably peer reviewed. But in his case, as I think is obviously clear, what he is writing on the topic has been peer reviewed in journals this site counts as reputable.
And I am assuming that by mentioning trying to sneak them in, you are saying that even if I paraphrase what he wrote on the topic in an openly free article, or drew the same diagrams myself, that wouldn't be acceptable to you and you would use that as a justification for closing the thread. Have I understood you correctly?
  • Skeptical
Likes weirdoguy
  • #43
It isn't just re-writing the math of standard SR because as you can see from the list of papers above one is called "General relativity in an absolute Euclidean space-time". And it uses flat Euclidean geometry even in situations with gravitation, and has the concept of absolute time.
I can't currently say much more because I what I have read about it came from sources that weren't accepted journals and Dale seems to be threatening to close the thread if I mention what they stated, even though he seems to accept the author of one paper I was using (which had I thought useful diagrams) has written on the topic for suitable journals.
  • #44
Why don't you try philosophy forums.
Likes dextercioby
  • #45
Because it is a question about physics. And the person I was quoting was a physicist that has at least 12 papers on the topic published in physics journals that are on Clarivate. What I am surprised at is that the other physicists on here seem to dismiss such work almost out of hand. What I don't understand is how you think he managed to get 12 papers on the topic published in such journals over a 14 year period. The impression I get is that if he came on here, there are many that think they could easily explain to him how silly what he was stating is. But I think the easier thing for me to do is just buy one of his papers and then quote from that, as I assume Dale is just trying to maintain standards on the site, and while I might differ with him in what I think is reasonable, ultimately it is his call, and I respect that.
  • #46
Not true, you've been given a lot of arguments why discussed approach is dismissed. Do you even understand them?
It's really not that hard, besides I see mainly one journal, Physics Essays. How high is it ranked?
Likes PeterDonis and Dale
  • #47
Yes. Authors can write good papers in reputable journals on some topics and bad papers on different topics. The latter is of course not acceptable, why is that strange?
Likes PeterDonis
  • #48
That isn't strange. But neither is that particularly relevant. The issue here is that the author in question wrote 12 papers on a certain topic in reputable journals that appeared on Clarivate. I was quoting from a paper on the *same* topic, by the same author, that appeared in a journal that wasn't on Clarivate, but which had an editorial staff of 21 people from reputable institutions from numerous countries. But the latter is freely available. And I was hoping that given that he is a reputable source, I would have been allowed to have quoted from it even if it had appeared on http://www.arxiv.org/ (and wasn't peer reviewed), due to him having published 12 papers on that topic in reputable journals.
  • #49
Likes PeterDonis, Vanadium 50 and Motore
  • #50
Would you care to mention the one you thought was most convincing?
