- #71
PeterDonis
Mentor
- 46,698
- 23,239
In standard relativity, the concept of "proper time" is not even applicable to photons. Lightlike objects are fundamentally different physically from timelike objects. The concept of "proper time" is only applicable to timelike objects.name123 said:So photons don't move through proper time in TR?
It is coordinate time in whatever inertial frame the diagram is being drawn.name123 said:I thought Montanus was pointing out that in the Minkowski Diagram (Fig 4 attachment #55) the time is actually the parameter time
No. Coordinate time is not the same as proper time in standard relativity.name123 said:in TR that is proper time I thought.
It appears that not only do you not understand AEST, you also don't understand standard relativity.
In any inertial frame, points on a photon's worldline map one-to-one with values of coordinate time. But, as above, coordinate time is not the same as proper time, and the concept of "proper time" is not even applicable to photons.name123 said:And I thought the photons did move in that time in TR.
That's true, but it's beside the point. If two worldlines in spacetime meet at a single point, that means those two objects physically met each other. But if two "worldlines" in space-propertime meet at a single point, that tells you nothing physically at all. That's the objection @Dale was making. You have not answered it.name123 said:I was under the impression that the different points in spacetime represent things that happened at different time (measured by clocks), or different places (physically measured with rulers).
The same coordinate time in any inertial frame. Or, more important, the same point in spacetime.name123 said:when the twins meet back up it is at the same parameter time.
No, but it is an issue for space-propertime, since it means a single physical event--the two twins meeting up again--is not represented by a single point in space-propertime. This is one illustration of the fact, already mentioned, that points in space-propertime have no physical meaning, unlike points in spacetime.name123 said:What the difference in proper time in Fig 3 type diagram represents is that the proper time of one twin is different to the proper time of the other. That their proper times are different isn't a causality issue.
No, you haven't. You have answered nothing whatever. See above.name123 said:Seems strange you would say that when I answered each thing you wrote.
