- #106
PeterDonis
Mentor
- 47,270
- 23,587
On reading this over again, it occurs to me that we might be talking past each other because we are using the phrase "time reversal" to mean different things.stevendaryl said:The time-reversal of someone falling into a black hole and yelling "Help, I'm falling into a black hole!" is not someone rising from a white hole yelling "Wow! A white hole, and I'm rising out of it!". The time reversal of the first scenario is someone yelling "Help, I'm falling into a black hole!" (speaking backwards).
In the quote above, you are using "time reversal" to mean reversing the sign of the time coordinate. (You also showed this explicitly in an earlier post but the penny didn't drop for me then, unfortunately.) You were correct earlier when you said this cannot change the actual physical situation, since of course no coordinate transformation can do that.
However, throughout this discussion, I have been using "time reversal" to mean reversing the sign of proper time along the congruence of worldlines describing observers comoving with the matter. This is a coordinate-free operation that does change the actual physical situation (for the reasons I have given in previous posts), but of course it is not the same as a coordinate transformation and it can be described without any coordinate change at all.
It does happen that the effect of both of the above operations on the relative signs of the time coordinate and proper time along the congruence of worldlines is the same (both operations flip that relative sign), but they have that effect for different reasons. That means we shouldn't be using the same term for both operations. Unfortunately, I don't have a good alternate term for either one.
