Do you use oil or butter when frying eggs?
  • Thread starter Thread starter flyingpig
    Oil
The discussion revolves around the choice of cooking fats for frying eggs, specifically comparing butter and sunflower oil. Butter is favored for its flavor and ability to prevent sticking, while sunflower oil is also used by some participants. The conversation highlights that the choice often comes down to personal preference, with some advocating for bacon fat for added taste. Participants discuss the importance of using the right cooking technique, emphasizing the need for proper pan temperature and the right type of pan, such as cast iron, to avoid sticking and achieve the desired egg texture. Garlic's role in stir-frying is briefly mentioned, but the focus remains on egg preparation. The thread also touches on the use of olive oil, with mixed opinions on its suitability for frying eggs. Overall, the consensus leans towards butter for flavor and effectiveness in cooking eggs, while acknowledging the versatility of other oils.
  • #31
Plus, if you want to use olive oil for cooking, don't bother using the real extra-virgin cold-pressed stuff. Use the stuff expressed under heat. It is clearer and has a higher smoke-point. The cold-pressed stuff is great for drizzling on bread or making vinaigrette dressings - not for cooking.
  • #32
I use olive oil.
On less positive note: every time I try to make fried eggs, 75% of my attempts ending up with omelette, really sad...=(
  • #33
flyingpig said:
Good another woman agrees with me. Now I know I am eating right.
I you my female opinion to negate this. Butter... mmmm... bacon fat... mmmmmmmmm!
You might be eating healthy, but you aren't eating right.
  • #34
You da gurl!
  • #35
turbo said:
You da gurl!
doh... "I you my..."
Too late at night here (and after 6 hours grading some tests I gave... and still only ~25% done... ~220 students, and a problems-based test). Typos abound... Especially when using a beer to wind down.
Or maybe just thinking of butter and bacon fat... and how could someone NOT use butter or bacon fat?
  • #36
estro said:
I use olive oil.
Not good. I initially typed "not food", but maybe that's just Freud. You need a nice cast-iron pan, and you need to season it properly before use. Never wash it in soap and water, just scour it out with sea salt to clean it, oil it with some salt pork or bacon and heat it. The pan will soon acquire a finish that is practically non-stick.
When you want fried eggs, heat the pan until a drop of water flicked into the pan hops around, pops, and disappears in a poof of steam. You can then add a little butter, and when that is thoroughly heated, crack in an egg or two. Better yet, instead of using butter, you could fry up some finely chopped onions and potatoes with little pieces of bacon or salt pork. Scoop those out with a spatula when they are browned and crack in a couple of eggs right away. Hopefully, you have also made some toast, so you have something handy to sop up those over-easy yolks with.
Inadvertent "omelets" or scrambled eggs are a sign that you have an improper cooking surface or are over-handling your eggs or both. You should be able to get your eggs cooked and flipped without distorting or ripping the margins of the whites.
A little cooking tip: If you have a good thin metal spatula, and you have used it to flip your potatoes and onions while browning them in the pork fat, it will be nice and lubricated, and will slide under those over-easy eggs really easily without distorting them. A clean, dry spatula will not do that as well.
  • #37
In Bangladesh , you can get only soya bean oil to cook . I use it. Though I know no Soya bean is in oil :(
  • #38
Chi Meson said:
Olive oil is not for frying!
D'oh. I meant for making omelettes, not fried eggs. I use butter + sesame oil for fried eggs.
  • #39
Since we're on technique, don't used hard, chilled butter. Leave eggs and butter out overnight (in cat-proof container!) for morning eggs. Follow heating advice as above, put the butter in, and add the eggs the moment the butter stops bubbling (that's when the water has been boiled away). If you put in chilled butter, the butter might begin to burn before it has all melted and bubbled out. Add the egg to the middle of the puddle of butter. Don't touch it for half a minute. If scrambled/omelet, break any big egg bubbles that form and let the fluid fill the holes. When top is nearly firm, flip without a spatula.
Julia Child said:
When flipping, you must believe in the courage of your convictions!
  • · Replies 19 ·
  • · Replies 37 ·
13K
