Does angular acceleration not always come with torque?
Torque does not always accompany angular acceleration, particularly when the moment of inertia is not constant. The relationship between torque and angular acceleration is simplified in the equation τ = Iα, which holds true only when the moment of inertia remains constant. In scenarios where the moment of inertia changes, angular acceleration can occur without any applied torque, as demonstrated by a particle moving in a straight line at constant velocity. The discussion highlights that angular momentum conservation allows for angular acceleration even when no external torque is acting on the system. Understanding these nuances clarifies the complexities of rotational dynamics beyond the basic torque formulas.
carrotstien
I always thought that
torque = I*d²θ/dt²
so that, if there is any d²θ/dt² on an object with a moment of inertia (both with respect to the same point)..then there must be a torque applied.
However, I've found a case where this isn't true. So, I'm assuming there is more to it then that simple formula.
I found, on wiki
"When the moment of inertia is constant, one can also relate the torque on an object and its angular acceleration in a similar equation:
τ = I α
So perhaps, when the moment of inertia isn't constant, then that formula has some stuff appended to it. (what?)
The situation i speak of:
A particle is traveling in a straight line not through the origin at a constant velocity.
It's (r) and (θ) are both functions of time. If you work out the time derivatives, you get a non-zero θ''. However, there are no forces, and no torques on the particle. (like a car just cruising past you).
Also, the origin isn't moving or accelerating, so that there doesn't seem to be some relativity issue (i am not talking about special or general)
Can anyone explain / tell me the full relation between torque and θ''...since
torque = I*θ'' seems to be a simplified case.
In analog with Newton's second law for translation, the full formula would be something like:
\vec{\tau}=\frac{d\vec{L}}{dt}
\vec{L} \equiv I \vec{\omega}}
So only when moment of inertia is constant does it reduce to the more familiar form.
An automobile supplies torque to its wheels at constant velocity to compensate for air drag. So when there is energy loss, torque is required to maintain a constant angular velocity.
Angular acceleration can occur without torque:
dL/dt = d(Iω)/dt = I dω/dt + ω dI/dt
If I dω/dt = - ω dI/dt , no torque is required for angular acceleration.
Bob S
If the angular inertia is changed via an internal force, then angular acceleration will occur while the angular inertia is changing because angular momentum is conserved. Note that internal work is peformed during such a change, and that angular kinetic energy will also change.
yea, thanks, Nabeshin and all...i get it
i just never knew that L was defined in terms of Iw the way you showed it.
Now everything makes sense again.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
