Does Current Depend on Wire Diameter?
  • Thread starter Thread starter Bogus_Roads
    Area Current
Current does depend on wire diameter, as a smaller diameter wire has a higher resistance, affecting the overall current flow. The analogy of water flow in a garden hose illustrates that reducing the hose diameter decreases water flow, similar to how a smaller wire restricts electron flow. The discussion highlights that while current can be the same in different wires under certain conditions, the resistance varies with cross-sectional area, impacting current calculations. The relationship between current, voltage, and resistance is crucial in understanding this concept. Therefore, wire diameter plays a significant role in determining the current in electrical circuits.
Bogus_Roads
Asking for drift speed, current in the second 2 mm diameter wire.
electron flow=qvA, I=V/R, R depends on A---why doesn't current then depend on A?
I can only solve it if the currents in both disks are the same, but doesn't current depend on A?
Think of the electrical current in the same way as water in a garden hose. If the hose gets smaller does the amount of water going through vary? What would happen if I made the hose get smaller?
So then you're saying it wouldn't be the same in the 1mm wire as in the 2 mm wire?
