Does the block move along the pink dotted lines
The discussion centers on the motion of a block projected from the bottom of a fixed sphere, specifically whether it follows the pink dotted lines in the provided diagram. The initial analysis indicates that the block's speed will decrease as it rises due to gravitational effects, necessitating a more comprehensive free body diagram (FBD) for various positions. Key questions include determining the block's speed as a function of the angle of deflection, the normal reaction force at maximum vertical velocity, and the angle at which the acceleration vector is horizontal. The participants emphasize the importance of mechanical energy conservation and proper FBDs to solve these problems accurately. Ultimately, the conversation highlights the complexities of analyzing motion in a circular path and the need for precise calculations to derive the correct relationships.
  • #31
kuruman said:
I'll try again, yes. But first you have to find the speed.
But we found speed to be ## V_0 = √(2gRcosΘ) ## . Isn't?
  • #32
We have the speed: ##\sqrt{2gR\cos \theta}##
We have the angle of the perpendicular: ##\theta##
  • #33
Is ## V\sin{\theta}## the vertical component?
Likes jbriggs444
  • #34
Yup. So now you have the hard part. Finding a maximum for an ugly looking formula. I do not see an easy approach short of trial and error. Finding the maximum by taking the derivative and solving for a zero does not look good. Maybe @kuruman has some algebra trick up his sleeve.
Likes Kaushik
  • #35
I was trying to differentiate it and solving it for zero.
Ok I'll wait for @kuruman to reply.
  • #36
I shall redeem myself with the help of Mathematica that verified the derivative.
$$\frac{d}{dx}(\sin x \sqrt{\cos x})=\cos^{3/2}x-\frac{\sin^2 x}{2\sqrt{\cos x}}$$
Let ##u=\cos x##. Then setting the derivative equal to zero gives
$$u^{3/2}-\frac{1-u^2 }{2u^{1/2}}=0~\rightarrow 2u^2-1+u^2=0$$
That's an easy one to solve.
Likes jbriggs444 and Kaushik
  • #37
After differentiating the square of ## V_0 ## , I got ## \theta = \tan^{-1}(\sqrt2)##
  • #38
So is this correct –> ## N = mg + \frac{2mg}{\sqrt3}##
  • #39
That's another way to do it. You can verify that ##\arctan(\sqrt{2})=\arccos(1/\sqrt{3})##. I did it with calculator but it should be doable algebraically.
Likes Kaushik
  • #40
No. What is the equation for ##N## you get from the FBD at any angle ##\theta##?
  • #41
The centripetal acceleration is ## \frac{2g}{\sqrt3}##, right?
Likes jbriggs444
  • #42
No. The centripetal acceleration is ##a_c=v^2/R##. Please write down the equation that you get from the FBD when you apply Newton's second law for any value of the angle ##\theta##. Once you have that, then you can substitute any specific ##\theta## value that you want.
  • #43
We know that, ## V_0 = \sqrt{2Rgcos(\theta)}##
As ##a_c=\frac{V_0^2}{R}##
##a_c = 2g\cos(\theta) = \frac{2g}{\sqrt3}##
  • #44
That is all true for the specific angle in part (ii) of the problem. However, your answer in post #38, ##N=mg+\frac{2g}{\sqrt{3}}## tells me that you think that you can write ##N=mg+ma_c##. That is not correct and that is the reason I asked you to derive the general expression for ##N## from the FBD.
Likes Kaushik
  • #45
kuruman said:
That is all true for the specific angle in part (ii) of thr problem. However, your answer in post #38, ##N=mg+\frac{2g}{\sqrt{3}}## tells me that you think that you can write ##N=mg+ma_c##. That is not correct and that is the reason I asked you to derive the general expression for ##N## from the FBD.
I am really sorry. I considered weight along N to be Mg. It is ##Mg\cos(\theta)##. Now I am getting ## N = \sqrt{3} mg ##.
  • #46
That is correct. How would you answer part (iii)? Another FBD is needed.
Likes Kaushik
  • #47
Kaushik said:
iii)The angle between the thread and the lowest vertical at the moment when the total acc. vector of the block is directed horizontally.
In this question, the resultant of ## a_{tangential} ## and ## a_{centripetal} ## should be horizontal right.
  • #48
I prefer to think of it a bit differently to help with drawing the appropriate FBD. If the net acceleration is horizontal, what other vector quantity must be horizontal?
Likes Kaushik
  • #49
## F_{net} ## (weight and normal) ?
  • #50
Absolutely. Now draw the FBD.
  • #51
I am getting ## N\cos(\theta) = mg ##, Am I correct? If yes, what should I do after this?
  • #52
That is the condition, yes. How would you find the angle at which this is the case? Hint: I asked you to do something in post #42.
Likes Kaushik
  • #53
## N\sin(\theta) ##'s component towards the centre is causing the centripetal acceleration.
So from the condition we got, ## N = mg/cos(\theta) ##.
Substituting the value of ## N ## in ## N\sin^2(\theta) = 2mg\cos(\theta) ##
We get, ##\theta = \tan^{-1}(\sqrt2) ##.
Is this correct?
  • #54
That is correct. Does the angle look familiar?
Likes Kaushik
  • #55
Yes.
So the angle at which the velocity's vertical component is maximum is same as the angle at which the ## F_{net} ## is Horizontal.
Thanks a lot for your help @kuruman @jbriggs444
  • #56
Kaushik said:
Yes.
In retrospect and with the benefit of 20/20 hindsight, do you see why it has to be this way?
Likes Kaushik
  • #57
The velocity's vertical component will be maximum when acceleration along the vertical is minimum. So when ## a ## along vertical is 0, the net acceleration is horizontal.
  • #58
Kaushik said:
So when a a along vertical is 0, the net acceleration is horizontal.
This just says that when one component of the acceleration is zero, there is only the other component left.
Here is what I had in mind. The vertical component of the velocity has a maximum when the vertical component of acceleration is zero. When the vertical component of the acceleration is zero, the vertical component of ##F_{net}## is zero. The vertical component of ##F_{net}## is zero when the vertical component of ##N## is equal to the weight. Therefore, when the vertical component of ##N## is equal to the weight, the vertical component of the velocity is maximum and vice-versa.
Thank you for an interesting post. I hadn't seen this variation before.
Likes Kaushik
  • · Replies 25 ·
  • · Replies 98 ·
