- #36
- 27,396
- 18,864
PeterDonis said:Yes, but that's not the question I asked. The question I asked was whether ##\lambda = 0.5## is less likely given the second case vs. the first.
How does "the second data set is less likely given the hypothesis that ##\lambda = 0.5##" get transformed to
"the hypothesis that ##\lambda = 0.5## is less likely given the second data set"? That is not a valid deductive syllogism; in fact it's a common error people make (assuming that if A then B is equivalent to if B then A).
I'm working to standard hypothesis testing. In particular, there is a single, unknown value ##\lambda##. It's not a random variable.
We can test ##\lambda = 0.5## (or any other value) against a random data set ##X## and compute ##p(X|\lambda)## for that data set.
The data in case #2 is less likely, given the hypothesis ##\lambda = 0.5##.
Eventually, with enough data, we would have to abandon the hypothesis ##\lambda = 0.5##. That is a thornier issue. In reality, it is more about an accumulation of data than one test.
Here the data in case #2 gives us less confidence in our hypothesis. That is the sense in which ##\lambda = 0.5## is "less likely".
