Drinking water and the release of gastric acid
In summary: I don't know how to say this...resting protein content of the burger. In summary, the stomach produces gastric acid and pepsinogen when a glass of water is ingested, but the presence of water doesn't activate the release of these digestive juices. If milk is ingested instead of water, then both gastric acid and pepsinogen will be released.
PainterGuy
940
70
Hi,
I think of a human body as an intelligent biological machine.
Could you please help me with the query below?
Question:
The stomach produces gastric acid and pepsinogen among other enzymes etc. When a glass of water is taken without any food, wow would the stomach react to water? Assume that the stomach was empty. Why wouldn't the presence of water in the stomach activate the release of gastric acid or pepsinogen? How would the stomach know that it doesn't need to release gastric acid or pepsinogen for water?
I think if it was milk instead of water, the stomach would release both gastric acid and pepsinogen.
Biology news on Phys.org
PainterGuy said:
Hi,
Question:
https://en.wikipedia.org/wiki/Gastrin
There is a psychological side to this too think Pavlov and his dogs.
Taste smell stimulate secretions
Likes PainterGuy
I think water will raise the pH slightly which discourages pepsinogen production.
Likes PainterGuy
No. On an empty stomach, water is pretty much absorbed quickly. Digestive cues (the release of stomach acid) do not occur when water alone passes through the stomach to the small intestine. Water into an empty stomach is a straight, quick (~5 minutes) shot out the duodenum - into the small intestine. No digestive juices produced.
See: https://pubmed.ncbi.nlm.nih.gov/21997675/
Likes PainterGuy, pinball1970 and russ_watters
Thank you!
But how would the stomach know that it doesn't need to release any gastric acid? Also what if one drinks milk instead of water? There are proteins in milk which need to be broken down.
The highly acidic environment in the stomach lumen degrades proteins (e.g., food). Peptide bonds, which comprise proteins, are labilized. The gastric chief cells of the stomach secrete enzymes for protein breakdown (inactive pepsinogen, and in infancy rennin). The low pH activates pepsinogen into the enzyme pepsin, which then aids digestion by breaking the amino acid bonds, a process called proteolysis.
Source: https://en.wikipedia.org/wiki/Gastric_acid
A simplified view: the "resting" pH of the stomach is sufficient to begin curdling milk. Curdles are solid enough to provide a sufficient physical cue to invoke addition of stomach enzymes.
FWIW - the stomach does not do all that much in the way of breakdown to the point where proteins are completely turned into amino acids. Or fats -> fatty acids. All that happens in the small + large intestine. Simple sugars like glucose and fructose are absorbed in your mouth, + stomach, + intestines. Starch -> glucose also happens largely in the small and large intestine.
Try this:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4956471/
FWIW: the fact that humans have been cooking food, a kind of predigestion, is a major evolutionary advantage. It reduces parasites in consumed food and breaks down complex food molecules to a more quickly digestible state. Liquids are no exception. So we get more nutritional "bang for a buck" by consuming cooked food...
Likes PainterGuy, russ_watters, berkeman and 1 other person
I really appreciate your help!
I'm sorry but I'm still trying to find the answer to the following. What factor(s) decide that how much gastric acid should be released and when it shouldn't be released at all?
As it has been said in the previous posts that for water gastric acid isn't released because water remains for short period of time in the stomach? Does the time factor also play a role?
A typical adult human stomach will secrete about 1.5 liters of gastric acid daily.
For example, when some cookies are consumed, the stomach is going to 'decide' how much gastric juice is needed or if needed at all? How does the stomach 'decide' it?
I'm sorry if you think that I'm going in circles.
Physical chunks of food. I don't think going into neurology will help much.
The stomach has a switch that says either:
"Churn, keep on processing"
"No churn, let it go into small intestine"
The switch works by sensing the resistance of the food to sloshing (churning)
Ex: water, koolaid, and de-pulped fruit juices all pass the slosh test quickly.
McDonald's burgers require extra liquid, enzymes, and time to break down the burger sufficiently to pass the slosh test.
Any liquid that thickens on entry fails the slosh test. Add a teaspoon of vinegar to milk, wait 30 seconds, emulate sloshing with a spoon.
This why - and it is important: The difference in energy used to process food is not trivial. So you win the evolutionary survival game with a more energy efficient system over somebody whose system wastes energy processing airballs because it cannot tell energy dense food from pure water.
Likes PainterGuy
Thanks a lot! It was really helpful.
I think asking about the the switch would be little too much. :)
Anyway, from this discussion, I think that drinking too much water and/or cold water is not a good idea. If you drink too much water, it unnecessarily overloads the stomach. If the water is too cold, it makes the food chunks stick together and the resistance to sloshing increases, and this is unnecessary overload.
Related to Drinking water and the release of gastric acid
1. How does drinking water affect the release of gastric acid?
Drinking water can help neutralize stomach acid and reduce the symptoms of acid reflux. It can also stimulate the production of bicarbonate, which helps buffer stomach acid and maintain a healthy pH level in the stomach.
2. Is it better to drink warm or cold water for reducing gastric acid?
There is no scientific evidence to suggest that one temperature of water is better than the other for reducing gastric acid. However, some people may find that warm water is more soothing and can help with digestion.
3. Can drinking too much water cause an increase in gastric acid?
Drinking excessive amounts of water can dilute stomach acid and reduce its effectiveness in breaking down food. This can lead to digestive issues and may cause an increase in gastric acid production. It is important to drink water in moderation and not in excess.
4. How long after drinking water does the stomach produce gastric acid?
The stomach constantly produces gastric acid, even when we are not eating or drinking. However, drinking water can stimulate the production of gastric acid and this process can begin within a few minutes of drinking.
5. Can drinking water on an empty stomach increase gastric acid production?
Drinking water on an empty stomach may stimulate the production of gastric acid, as it signals the stomach to prepare for food. However, this is a natural and necessary process for proper digestion. Drinking water in moderation should not cause any negative effects on gastric acid production.
  • Biology and Medical
13K
10K
  • General Discussion
10K
