Earth's Accel.: Is 10^(-22)m/s^2 Correct?
  • Thread starter Thread starter Oydpuuodouflj6r9
The discussion centers on calculating the acceleration of Earth when a 60-kg person is free-falling towards it, using the formula F=ma. The derived acceleration, a=10^(-22) m/s^2, raises questions about its validity due to its seemingly strange value. Participants suggest considering the gravitational attraction equation between two masses, especially if the person is falling close to Earth's surface. The assumption that gravitational acceleration (g) remains constant for this scenario is also noted. The conversation highlights the complexities of gravitational interactions in physics calculations.
Oydpuuodouflj6r9
A 60-kg person is free-falling from the sky to Earth. What is the acceleration of the Earth of the mass of the Earth is 6*10^24 kg?
F=ma
let a be the acceleration of Earth, m=60kg, M=6*10^24 kg, g=10 m/s^2
Ma=F=mg
=> 6*10^24*a=60*10
=> a=10^(-22) m/s^2
is this correct because the answer is a bit strange?
Oydpuuodouflj6r9 said:
Homework Statement:: A 60-kg person is free-falling from the sky to Earth. What is the acceleration of the Earth of the mass of the Earth is 6*10^24 kg?
Relevant Equations:: F=ma
Ma=F=mg
=> 6*10^24*a=60*10
=> a=10^(-22) m/s^2
Welcome to PF. There is another equation that may be more appropriate for this question. Do you know of an equation that gives the gravitational attraction between two masses separated by a distance r (to their centers of mass)?
EDIT -- Although as @PeroK is pointing out below, if the person is falling close to the surface of the Earth, the equation that you used may be valid. Does it say anything about how far away from the surface the person is?
Ma=F=mg
=> 6*10^24*a=60*10
=> a=10^(-22) m/s^2
What is strange about that?
I would assume that we can take ##g## to be approximately constant for this problem.
