- #71
JesseM
- 16
JesseM said:I don't see why it would--if the metric just tells you the proper time ticked by a clock moving along any given path through spacetime, this shouldn't change even if we discover a preferred frame (unless we discover a new type of 'clock' that does not exhibit the same type of time dilation as normal clocks, in which case I'm not sure what you'd have to do then--have two separate metrics for the different classes of clocks, maybe?)
Sure. But do you disagree with my speculation that this would require us to have separate metrics for the two types of clocks, rather than modifying the original metric?Aether said:If a Lorentz violation leads to a preferred frame and that leads to absolute simultaneity, then I suppose that a Lorentz violation leads to an absolute clock.
JesseM said:Even if you say it's not "just" a function, mathematically it would still be a function defining a notion of distance in spacetime, and I don't understand what it means to say this function would "represent something physical". Can you pin down what you mean by "represent"?
Are you sure about that? I thought the concept of gravitational potential didn't make sense in GR. But either way, what does this have to do with aether? If you're saying the "something physical" the metric represents is gravitational potential, then doesn't it already represent that even if there is no aether?Aether said:The components of the metric can be regarded as representing gravitational potentials.
JesseM said:That doesn't really answer my question of why you said "Acknowledged. Not only for speeds, but every possible empirical measurement", which seems to suggest the exact opposite (namely, that whatever is true about speeds is also true for every possible empirical measurement). But I suppose it's not really important, now that we're clear on the fact that you agree all measurements of speed are coordinate-dependent while other, more truly "physical" quantities are not.
That still doesn't help me make sense of your original comment that you were acknowledging something was true "not only for speeds, but for every possible empirical measurement". If you're now saying the thing you were acknowledging is that speed is a dimensionful quantity, does this sentence say that all empirical measurements are dimensionful quantities? That certainly isn't true--for instance, the ratio between the number of ticks on two clocks which take different paths through spacetime is an empirical quantity that's not dimensionful, and likewise the empirical determination of whether two events coincide at the same point in spacetime is not a dimensionful quantity (it's not a 'quantity' at all). edit: also, I just wanted to add that even dimensionful quantities need not be coordinate-dependent--if we ask how many seconds are ticked by a clock that takes a certain path through spacetime, different observers in different frames systems won't disagree on this, assuming they all define "1 second" in the same way (say, as 9,192,631,770 oscillations of a cesium atom). Do you understand the difference between saying a quantity is dependent on your choice of coordinate system and saying it is dimensionful? They are not the same thing at all.Aether said:I meant that speed is a dimensionful quantity, and no experiment can directly measure any dimensionful quantity.
JesseM said:Convinced of what? Of my points about observers in windowless boxes being able to construct devices whose measurements correspond to the coordinates of the Lorentz transform? The idea of constructing coordinate systems out of rulers and clocks synchronized using the Einstein synchronization procedure (which does not require any knowledge of the outside world) is the whole basis for the derivation of the Lorentz transformation, so it's pretty important that you understand it--if you're in doubt about this, please respond to my last comments in that post.
Fair enough. But again, this isn't an argument original to me, it's the standard way that I've always seen the Lorentz transform derived.Aether said:I haven't gone through everything carefully yet, so I'm not saying that it's unconvincing; I'm saying that I haven't completed a thorough review of it all yet.
Aether said:but I am now viewing the Lorentz transform as an analogy to the homogeneity and isotropy of the Universe; e.g., that there is one and only one local frame in which the universe looks homogeneous and isotropic.
JesseM said:Are you suggesting that the "homogeneity and isotropy of the universe" defines a preferred frame?Doesn't a "local frame" in GR by definition only deal with an arbitrarily small patch of spacetime, so a statement about what the universe as a whole looks like could only be made in a global coordinate system? Also, why would the Lorentz transform be an "analogy" for the idea of a global preferred frame? An analogy in what sense? And what does this have to do with the question of whether the Lorentz transform is the most "natural" one for us to use given what we know about the laws of physics?
When you say "rings a bell", does that mean it's just sort of a vague intuition that there's some analogy there but don't have a clear idea of what the analogy is? Because this explanation still doesn't give me any clear idea of what you meant when you said "I am now viewing the Lorentz transform as an analogy to the homogeneity and isotropy of the Universe".Aether said:I'm saying that what I read in MTW about what is special about comoving coordinates are that the universe looks the same from every perspective because there is no "handle" rings a bell here.
JesseM said:Again, the issue of absolute vs. relative simultaneity is fundamentally just a matter of what coordinate systems you use, even with the known laws nothing is stopping you from using the Mansouri-Sexl coordinate systems to describe the world...experimental results only come into play in deciding which set of coordinate systems is more of a "natural" choice, and in that sense the results seen in particle accelerators are relevant because they keep showing that all the fundamental laws have the property of Lorentz-symmetry rather than "LET transform symmetry" (or whatever you want to call it).
But the aether is not the same thing as absolute simultaneity, that's what I just said in the paragraph you were responding to! Simultaneity is purely a question of your choice of coordinate systems, and you are free to use any set of coordinate systems you want regardless of what the laws of physics are. Again, the laws of physics may make one choice of coordinate system more "natural" than another, but that doesn't mean you can't use unnatural coordinate systems. Even if there is no aether, you can still pick an arbitrary observer to be the "preferred" one and have all other observers synchronize their clocks so that their definition of simultaneity agrees with his; likewise, even if there is an aether you are still free to have each observer synchronize their clocks under the assumption that light moves at c in their rest frames, which will lead different observers to have different definitions of simultaneity.Aether said:If "the aether" is the same thing as "absolute simultaneity", then what you are describing is not "relativity without the aether" is it?
