Electric current? how many electrons?
The discussion revolves around calculating electric current and the number of electrons passing through a wire. The current is determined to be 4.1E-3 A using the formula I=Q/t. For the second part, there is confusion about how to calculate the number of electrons in one minute based on the current. The correct approach involves recognizing that current in amps represents coulombs per second, and the charge of one electron is 1.6E-19 coulombs. Ultimately, the calculation should focus on the total charge over one minute without multiplying by the charge of an electron.
snash1057
A net charge of 49 mC passes through the cross-sectional area of a wire in 12.0 s
(a) What is the current in the wire?
_4.1E-3_ A
(b) How many electrons pass the cross-sectional area in 1.0 min?
______electrons
I=Q/t
part A was very simple, 49E-3/12 = 4.1E-3 amps
however part b i do not understand.
1 electron = 1.6E-19 and 1 coulumb = 6.24E18
49E-3 x 6.24E18 = 3.06E17 x 60 = 1.8E19 incorrect
49E-3 x 1.6E-19 = 7.84E-21 x 60 = 4.7E-19 incorrect
You need to realize that 1amp means 1 coulomb per second.
Current is the rate of flow of electric charge
if i am sort of understanding what you are saying, you mean to use my answer for part a in order to get my answer for part b?
well i have tried something like that, but i still must be off track because i still got it wrong
4.1E-3 x 6.24E18 = 2.56E18 x 60 = 1.5E18 incorrect
You have the current to be 4.1 x 10^-3A which means 4.1 x 10^-3 coulombs per second.
The charge on 1 electron is 1.6 x 10^-19 coulombs so how many electrons per second.
Be careful the question asks for how many in 1MINUTE
if i have 4.1E-3 c/s then wouldn't i have to multiply that by the one electron?
4.1E-3 x 1.6E-19 = 6.56E-22
but like you said since it is one minute and there are 60 seconds in a minute i would multiply 6.56E-22 by 60 in order to get 3.9E-20
im sorry for all this, but I am just really confused haha :)
To find how many electrons you do not multiply !
  • · Replies 20 ·
