Electric displacement field density equation
  • Thread starter Thread starter lys04
The electric field, denoted as ##\vec{E}##, is the same in both equations and is produced by free charges in a vacuum, while ##\vec{D}## represents the electric displacement field density within a dielectric. A high relative permittivity, ##\epsilon_r##, indicates significant polarization in the material, resulting in a reduced electric field inside the dielectric compared to a vacuum. The electric displacement field density, defined as ##\vec{D} = \epsilon_0 \vec{E} + \vec{P}##, allows for the isolation of free charge effects, simplifying calculations involving dielectrics. The total charge density combines bound and free charges, and Gauss' law can be adapted to express the relationship between these quantities. Ultimately, ##\vec{D}## serves as a useful tool for managing polarization effects without altering the fundamental nature of the electric field, ##\vec{E}##.
lys04
I want some clarification of what each of the terms in these two equations mean
$$\vec{D}=\epsilon_0 \vec{E} + \vec{P}$$
$$\vec{D}=\epsilon_r \epsilon_0 \vec{E}$$
From my understanding,
The electric field, ##\vec{E}## in both of these equations are referring to the same electric field, the electric field produced by free charges in vacuum?
##\vec{D}## refers to the electric displacement field density INSIDE the dielectric and $$\epsilon_0 \vec{E}$$ is the electric displacement field density in vacuum?
A high relative permittivity, ##\epsilon_r## means that the material polarises a lot in response to an external electric field and therefore the electric field inside the dielectric should be less than that in a vacuum, given by ##\frac {1} {\epsilon_r} E##?
But what does the electric displacement field density represent and why is it greater in a dielectric than it is in a vacuum since ## \vec{D}= \epsilon _0 \epsilon _r \vec{E}## and ##\epsilon_r = \frac {\epsilon}{\epsilon_0}## which is always greater than 1, whereas its the opposite for the electric field?
Applying an electric field to a dielectric material induces a polarization in the material. You can imagine lots of little dipoles having formed in the dielectric in response to the applied field. The +ve and -ve "bound" charges separate from each other slightly, and the polarization is resulting dipole moment per unit volume. The polarization is related to the "bound" charge density by the relation ##\rho_{\mathrm{b}} = - \nabla \cdot \mathbf{P}## (see this diagram for an explanation).
The displacement field (##\mathbf{D} := \epsilon_0 \mathbf{E} + \mathbf{P}##) is defined in such a way that it lets us isolate the effect of "free" charges. In other words, by using ##\mathbf{D}##, we "don't have to worry" about what's going on with the complicated polarization effects inside the material. Express the total charge density as the sum of the "bound" and "free" charges:
##\rho = \rho_{\mathrm{b}} + \rho_{\mathrm{f}} = -\nabla \cdot \mathbf{P} + \rho_{\mathrm{f}}##
Gauss' law ##\nabla \cdot \mathbf{E} = \rho/\epsilon_0## in its original form refers to the total charge density ##\rho##. If you stick this into the equation above, you get
##\epsilon_0 \nabla \cdot \mathbf{E} = - \nabla \cdot \mathbf{P} + \rho_{\mathrm{f}}##
##\implies \nabla \cdot (\epsilon_0 \mathbf{E} + \mathbf{P}) = \rho_{\mathrm{f}}##
##\implies \nabla \cdot \mathbf{D} = \rho_{\mathrm{f}}##
You've "bundled" the effect of the polarization into a new quantity, ##\mathbf{D}##, and now you have a way to handle situations where you know only know about the free charge density (e.g. useful for capacitors containing insulating dielectrics, where you might only know about the "free" charge density on the metal plates). You can use the same mathematical techniques that you already learned for pure conductors.
The "true" electric field is still always ##\mathbf{E}##. It's probably best to think of ##\mathbf{D}## as a helpful book-keeping term which absorbs polarization effects. Note that ##\mathbf{D}## isn't a field strength (it has units of ##\mathrm{C} / \mathrm{m}^2##).
Likes DaveE and PeroK
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
