Electric Feld Intensity Question
The discussion focuses on calculating the electric field intensity vector at point P (5,6) due to an infinite line charge described by the equation 2x + 3y = 7 with a linear charge density of 3 µC/m. The user seeks clarification on whether to use the distances from the x-intercept and y-intercept as R and R' in the electric field equation. It is suggested to connect point P to the line orthogonally and denote this distance as r0, with the electric field direction being in the positive x and y directions. The magnitude of the electric field can be determined by integrating k*dq/r^2, where r is expressed in terms of r0 and the angle theta. The discussion emphasizes the importance of symmetry and proper integration limits in solving the problem.
ee3356
An electric charge is distributed along an infinite line (2x+3y=7) in xy-plane with density pl = 3uC/m. Find the Efield intensity vector at point P (5,6).
E = Integral of pl/ (4*pi*E) * (R - R')/ (R-R')^3
I just wanted to double check if all i need to do is find the distance of point P from the y-int and x-int and then just use them as R and R' in the above equation
?? Did you mean x-intercept & y-intercept? If so, i think the answer is no.
Anyway - connect P(5,6) to the line at the point where they meet orthogonally. Call this distance r0.
By symmetry, the direction of E is obviously in the direction of this normal in the +x, +y direction.
The magnitude you can get by integrating k*dq/r^2 where r = r0sec(theta), k = 9e9 in SI units and theta is the angle between r0 and an element of charge along the line dq = pl*r*d(theta). Integrate from 0 to pi/2 & double the result.
