Electric field inside a uniformly polarized cylinder
The discussion focuses on calculating the electric field inside a uniformly polarized cylinder using Gauss' law. The derived electric field is expressed as E = P/(2ε₀), where P is the polarization. A key point of contention arises regarding the direction of the dipole vector d, with confusion about whether it should be defined from the negative to the positive charge or vice versa. Clarifications indicate that the vectors s₊ and s₋ represent distances from different origins to a common point r, emphasizing the importance of correctly identifying these vectors in the context of the problem. The resolution highlights the necessity of accurate vector representation in understanding the electric field distribution.
Potatochip911
This is problem 4.13 from Griffiths. A long cylinder of radius a carries a uniform polarization P perpendicular to its axis. Find the electric field inside the cylinder.
##\int \vec{E}\cdot dA = q_{encl}/\varepsilon_0##
[/B]
We solve the problem by using a positive and negatively polarized cylinder:
Using Gauss' law we find
$$ \vec{E}(2\pi \vec{s} l) = \frac{\rho \pi \vec{s}^2 l}{\varepsilon_0} \\ \Rightarrow \vec{E} = \frac{\rho}{2\varepsilon_0}\vec{s}$$
then
$$\vec{E_+} = \frac{\rho}{2\varepsilon_0}\vec{s_+} \\ \vec{E_-} = -\frac{\rho}{2\varepsilon_0}\vec{s_-}$$
Summing together gives
$$\vec{E} = \frac{\rho}{2\varepsilon_0}\left(\vec{s_+} - \vec{s_-} \right)$$
and since for dipoles we define the vector ##\vec{d}## going from the negative to the positive charge ##\vec{d} = s_+ - s_-##
$$\vec{E} = \frac{\rho \vec{d}}{2\varepsilon_0} = \frac{\vec{P}}{2\varepsilon_0}$$
However, in the solutions manual they claim ##\vec{d}## is going from the negative to the positive axis and that ##\vec{s_+}-\vec{s_-} = -\vec{d}## which I am having a hard time believing as from a simple diagram this seems incorrect.
I can't draw a diagram, but I think I can describe the picture: Assume the + cylinder is translated to the right by a vector ## \vec{d} ##. (The cross-sectional view involves two circles of radius ## a ## in the x-y plane, with the + circle a distance ## d ## to the right of the - circle). Then, at a given location ## \vec{r} ## where the electric field is being determined, e.g. upward and to the right of the origin, ## \vec{s_-} ## will be the longer vector in reaching the location ## \vec{r} ##. We can write ## \vec{s_-}=\vec{s_+}+\vec{d} ##.
Likes Potatochip911
Am I drawing it incorrectly? I still don't find the same result as you.
Your drawing is incorrect. ## d ## is a shift of the origins of two circles, each of radius ## a ##, along the x-axis. A point ## \vec{r} ## is common to both of them. ## \vec{s}_+ ## is a vector from the rightmost origin to ## \vec{r} ##, and ##\vec{s}_- ## is a vector from the leftmost origin to ## \vec{r} ##.
Likes Potatochip911
