Electric potential of nested spherical shells
The discussion revolves around calculating the electric potential of nested spherical shells using Gauss's law. The initial calculations for the potential at different points reveal a misunderstanding regarding the integration limits and the direction of the electric field. Corrections highlight that the negative sign in the integrand was misplaced, affecting the expected sign of the potential difference. Two methods for finding the potential at a specific radius yield different results, with the second method being correct as it considers the influence of the surrounding shells. The conversation concludes with a suggestion to properly account for the electric field contributions from all relevant charges when integrating.
songoku
Two concentric spherical shells have equal but opposite charges. One spherical has radius ##a## and charge ##Q## while the other has radius ##b## and charge ##-Q## where ##b > a##. Find ##V(r)-V(\infty)## for the region:
(a) ##r>b##
(b) ##a<r<b##
(c) ##0<r<a##
##V=\frac{kQ}{r}##
##V_A - V_B=-\int^{a}_{b} \vec E. d\vec s##
##\int \vec E . d\vec A=\frac{q_{in}}{\epsilon_0}##
For (a), I got ##V(r)=0##
For (b), using Gauss law I get the electric field in the region to be ##\vec E=\frac{kQ}{r^2}\hat r##, then:
$$V(r)-V(b)=-\int^{r}_{b} \left(\frac{kQ}{r^2}\hat r\right) . (-dr ~\hat r)$$
$$V(r)-0=\int^{r}_{b} \frac{kQ}{r^2} dr$$
$$V(r)=kQ\left(\frac{1}{b}-\frac{1}{r}\right)$$
But if I imagine both charges to be point charges, then:
$$V(r)=V_{\text{by +Q}}+V_{\text{by -Q}}$$
$$=kQ\left(\frac{1}{r}-\frac{1}{b}\right)$$
Where is my mistake?
Thanks
In the integrand, you should not have the negative sign in ##(-dr ~\hat r)##. Instead, ##\vec{dr} = dr ~\hat r##. Note that ##dr## is a negative quantity since you are integrating from a larger value of ##r## to a smaller value of ##r##.
Considering the direction of the electric field between the shells, do you expect ##V(r) - V(b)## to be positive or negative for ##a < r < b##? Does your answer agree with this expectation?
Ah I see
The direction of electric field in this case is radially outward so I expect ##V(r)-V(b)## to be positive. My first answer does not fit, my second answer fits.
I have another question. How to find potential at ##r=a##? I did 2 attempts:
(1)
$$V(a)-V(\infty)=-\int^{a}_{\infty} \frac{kQ}{r^2}dr$$
$$V(a)-0=\frac{kQ}{a}$$
$$V(a)=\frac{kQ}{a}$$
(2)
$$V(a)-V(b)=-\int^{a}_{b} \frac{kQ}{r^2}dr$$
$$V(a)-0=kQ\left(\frac{1}{a}-\frac{1}{b}\right)$$
$$V(a)=kQ\left(\frac{1}{a}-\frac{1}{b}\right)$$
By considering both of them as point charges at the center, my answer matches the second one but I don't really understand why (1) is wrong.
Equation from (1) is like a situation where there is just one charge ##Q##. Since point ##a## is also inside another spherical shell so we can't consider the work done to move a charge from infinity to ##a## but need to consider the boundary of the larger shell?
Thanks
songoku said:
Ah I see
Yes.
(1)
Write $$V(a)-V(\infty)=-\int^{a}_{\infty} \vec E_{net} \cdot \vec{dr} = -\int^{b}_{\infty} \vec E_{net} \cdot \vec{dr} -\int^{a}_{b} \vec E_{net} \cdot \vec{dr}$$ Think about what to substitute for ##\vec E_{net}## in each integral on the far right.
Thank you very much TSny
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
