Electrical Power - Cost of kW*hr
An electric air conditioning unit consuming 15 amps at 134 volts operates for 506.4 hours over 21.1 days in July. The power consumption calculates to 2.01 kW, leading to a total energy usage of 1017.864 kW·hr. The local electricity rate is 9.9 cents per kW·hr, which translates to $0.099. The correct calculation for the monthly cost is $100.768, rounded to $100 when excluding cents. The key takeaway is ensuring the final answer is presented in dollars without cents for accuracy.
calvert11
An electric air conditioning unit draws 15 amps of direct current from a 134 V direct voltage source, and is used 24 hours a day during 21.1 days in July. How much will the electricity cost for the month if the local electrical rate is
9.9 /kW· hr?
Answer in units of dollars.
(Note: sigfigs do not matter)
P = I*\DeltaV
This seems like a straight forward question:
P = 15*134 = 2010 W = 2.01 kW
t = 21.1 days * 24 hours = 506.4 hours
P*t = 1017.864 kW*hr
Since units aren't given for 9.9, I tried for both dollars and cents:
1017.864* 9.9 = $10076.85
1017.864*.099 = $100.785
Both answers are wrong. I don't know where I'm making the mistake.
The 9.9 is c/kwh, other than that you are correct, except for the slight typo on the last answer
Looks like you might have made an arithmetic error when calculating in cents.
1017.864*0.099 = 100.768
Your last answer is correct. They want the answer of dolllars, with no cents. That's why they had such strange numbers (like 21.1 days).
Thank you so much. Removing cents gives the right answer.
