Electrons @ battery negative terminal
The negative terminal of a battery has a surplus of electrons, giving it a negative charge. When a person touches the terminal, only a small amount of charge flows into the body until both reach the same electrical potential, stopping further flow. To discharge the battery, a complete circuit must be created by connecting both terminals, allowing a significant current to flow. Understanding the concepts of potential and capacitance is crucial for grasping how current flows in circuits. Overall, the flow of electrons is limited when not in a complete circuit.
wphays
Does the negative terminal of a battery have a negative charge due to having a surplus of electrons? If so, then why do the surplus electrons from the negative terminal of the battery not discharge to the human body or Earth (which have a neutral charge) when touched?...thereby causing the battery to lose charge.Thanks in advance for answers. I'm obviously new to physics.
They do. But only a very small amount of charge moves into the body before it reaches the same potential as the battery terminal and then the flow stops. It's like trying to pour water into a stopped-up drainpipe - only so much will go down the drain before the flow stops.
If we create a circuit by touching a conductor to both terminals of the battery, we will get a current flow that will discharge the battery fairly quickly.
If you are not familiar with the concepts of potential and capacitance, you'll want to learn about them. They are far more useful for understanding current flows than thinking in terms of electrons moving around.
Likes cianfa72, vanhees71 and wphays
Thank you
Likes davenn
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
