- #71
vanesch
Staff Emeritus
- 20
kleinwolf said:It's just because we don't understand QM.
I'd rather say: because the way you want do modify QM doesn't work :-)
But QM is omnipotent for everyone, just put : [tex]\chi=-\frac{\pi}{4}\Rightarrow p(diff)=1[/tex]
Yeah, that's the projection as is proposed in standard QM :-) So then it works...
But you claim that one should have a kind of "equal distribution" or so of outcomes (which clearly is NOT standard QM). And then you get silly results such as that the sum of the probabilities of all possibilities is not equal to 1.
In the other calculation, the sum add up to 1 in every case...
So what does it mean that the prob of the possible outcomes don't add up to 1 in everycase for the other calculation ?
It means that you have been cheating :-) You have in fact used normal quantum mechanics, except for the fact that you have been rotating the |-+> and the |+-> vectors in the "different" eigenspace. When you then calculate the total length (squared) of the original vector, projected on each of those and add it together, you obtain of course the correct QM prediction. Indeed, total length is invariant under a rotation of the basis (in the "different" eigenspace). But that's not what you were proposing in the first place. What you proposed was that the probability of having the "different" result should be the projection on ONE SINGLE arbitrary direction in the "different" eigenspace, not the sum of all the possibilities (which corresponds to finding the total length of the projection, as prescribed by standard QM). And then you're back to your first formula, where the sum of probabilities of all the possible outcomes is not equal to 1. THAT was the technique you used for the EPR stuff. You didn't sum over the different projections (because then you'd have found the same predictions as standard QM: you'd just have been rotating the basis vectors in the eigenspace to calculate the total projection length, something you are of course allowed to do).
cheers,
Patrick.
