Exploring the Benefits and Uses of SVG in Web Design
  • Thread starter dduardo
  • Tags
    Poll Web
In summary: I was playing around with computers before windows, mostly playing Jeopardy and writing English papers (that printed on a dot matrix printer). Oh, wait, and there was the Commodore 64, and programming in BASIC to make Mr. Bo Jangles (the stick figure that danced). :biggrin: But, yeah, I think "working" with computers began with Windows 3.11 for me.
What Browser Are You Using?
  • Internet Explorer
    Votes: 19 32.2%
  • Mozilla Firefox
    Votes: 34 57.6%
  • Safari
    Votes: 1 1.7%
  • Opera
    Votes: 4 6.8%
  • Other
    Votes: 1 1.7%
  • Total voters
    59
  • #106
hitssquad said:
Does it automatically re-order your window stack according to most-recently visited windows? IE does.
That would be total chaos if the tabs started rearanging themselves. I expect a pariticular page to be in a particular tab which is in a particular position on the screen.
  • #107
Conclusion: everyone has their own preferance. I back hitsquad, I'm a keyboard user and like to alt+tab through last active windows.
  • #108
Somehow, I see IE7 still not supporting alpha-transparency in PNGs and properly functioning SVG/CSS/DOM implementations. :rolleyes: Back to dumbing down web design to stay compatible with IE.
  • #109
I like that. It has a nice ring to it:
"Hitssquad: Master of Total Chaos."
http://gizmos-world.de/gizmo/Micha2.jpg
  • #110
Well, you could install the lastTab extension to give you the last active tab switching ability:
http://timothyhumphrey.name/firefox/
Instead of alt+tab its ctrl+tab
Monique, you might appreciate this extension:
http://biobar.mozdev.org/
  • #111
*Kia* said:
I have IE, Firefox, Netscape and Opera installed (to test my webpages).
IE has more functions, better usability, and many of my special effects and scripts are not understood by browsers such as firefox, meaning extra coding so these browsers do not misinterpret them.
This is the same way I feel about IE. I code elegant standard ECMAscript and DOM scripting, and IE either goes belly-up by not supporting some standard object, or interprets some command in an utterly non-standard death-defying way, so that I end up having to trudge through MSDN's DHTML library to find IE's utterly proprietary object/implementation in their proprietary "Jscript" format and try to fork the code by detecting supported objects (as browser detection is unreliable). In many cases, IE sees errors in lines it shouldn't even be reading by standard protocol, so you eventually end up having to lobotomize the best parts of your code to get a functioning cross-browser script. Even if you don't have to do this, you still end up with a longer script whose only excuse is support for IE.
  • #112
No Hitsquad it does not rearange the tabs. However, you can set it up so that when you are cylcing through tabs that you go in the order of last visited, and vice-versa.
edit... Wow was I slow, dduardo beat me to it.
  • #113
Dduardo, Mattmns:
Yes. That's what I meant. Re-order the visited-window stack yet not necessarily re-order the spatial arrangement of the tabs.
So, the answer to the question is "Yes. You can do it with a certain plug-in."
  • #114
*Kia* said:
Why?
When other browsers catch up and look and feel less chunky and childlike then maybe...
1) You obviously have never used firefox's DOM Inspector, Javascript Console, Web Developer Extension, and the HTML Editor (Based on Tidy) extension. They are indispensable tools for creating websites.
2) I've had to redesign web interfaces to avoid, as hypermorphism so elequently said: lobotomizing my code, just because IE is so crippled.
  • #115
So how many extensions do you have to download and install in FF in order for the fancy websites to work? The standard browser does not look spectacular to me.
Thanks for the Biobar, I actually had already found it myself :biggrin: there's also a BioFox sidebar.
So, how do I get FF to ask me what I want to do with a file I want to download (open, save, save and open folder, save and launch). Do I need to extension OpenDownload or is it already built in?
  • #116
tools-> options -> downloads
Or wait til you download that file and it will ask you.
  • #117
I don't need any extensions to view fancy websites. I only add extensions to enhance the user interface or allow me to manipulate webpages as I see fit. IE is not nearly as developer friendly as Firefox.
That's already built in. I also don't see IE with a nice download manager.
  • #118
Actually I find it annoying. First I have to browse through all my directories to save into the right folder (it doesn't remember the last locations and I don't want to save in a single place). Then when it has saved it, I have to go to Windows Explorer and find the file again to launch or unpack it :bugeye:
  • #119
1) Firefox remembers where I last put my files. Maybe it's a windows thing. Someone else would have to confirm this.
2) If you elected to just download the file, once the file is finished downloading there will be a link to open the file in the download manager.
  • #120
Nope, not even with the opendownload extension. I get a little popup window in the bottom right that the download has finished, the downloads window is empty and I'm off to find the file.
  • #121
  • #122
Non-standard does not correspond to fancy. Besides, if I encounter such a site, I just use IEView to open it in IE. No need to download tons of extensions to support outdated design. ActiveX isn't exactly something I'd introduce to my Firefox either. :-p
Firefox by default asks you whether you want to Save a file to [default folder] or Open with ["Browse..." or default program]. To change the Save a file to... to a dialogue, you can go to Tools>Options>Downloads>Ask me where to save every file. "Save and Launch" is not an option I've seen before, but using Firefox's download manager window will allow you to open the saved file with one additional click.
  • #123
mattmns said:
Uninstall that extension. I am on windows (xp) right now and I see an "Open" link next to the file I downloaded.
Here is the screenshot.
http://img260.imageshack.us/img260/8878/downloadopen5wu.th.png
Press ctrl+j to open the download manager. (or Tools -> Downloads).
That looks really nice, but it is not what I get. Without the extension I get this:
http://img6.imageshack.us/img6/4583/downloads2st.jpg
  • #124
You probably changed the setting at Tools->Options->Privacy->Download-manager-history
to "Remove files from the Download Manager: Upon successful download".
The standard settings is:
"Remove files from the Download Manager: Manually"
and the standard behaviour is that the links to the donwloaded files are only removed when you press "Clean Up".
  • #125
You are right, shame on me :smile:
  • #126
faust9 said:
Then try coding to web standards and cross browser problems will be minimized to the point of almost non-existant. IE(Internet Explorer) is a bug ridden virus waiting to happen. And tabbed browsing is infinetly more productive than non-tabbed. Imagine a page with multiple links---say a uC site with 18 versions of the same chip. Hold the apple key(I'm a mac user so you can take the MS-specific non-standard HTML and stick it where the sun doesn't shine) and click through all of the variations. Hold down apple+option and arrow through each of the open tabs---easy and quicker than opening links in different windows(organization wise) and much much quicker than using forward and backward history.
Now, please tell me(us) how firefox is behind IE? Well FF is well behind the virus curve but other than that how is it inferior? Tell me how Camino is less 'clunky' than IE on windows... You can't.
Quite simply I don't like it, they are all chunky and childlike with bold colours big buttons and I'm sorry but tabbed browsing is not nice.
Oh and my coding... is of web standards hence the extra coding for those browsers that misinterpret basic scripting (which IE does not misinterpret), oh Yeah and I verify with W3C, so if your browser can't support basic web standard coding - not my problem
  • #127
hitssquad said:
Using a non-tabbed browser doesn't mean you have to use only the forward backward history. You can do what you described without tabs. To open links in new windows on PC running IE, click while holding the shift key down.
Hold about - mine opens links in new windows anyway - it's a user preference
  • #128
mattmns said:
Well you are one of the few I would say. Personally I do not even like touching my keyboard while browsing. And if I were to use the taskbar with IE, I would have to click twice just to get to a new page. Personally I use rocker mouse gestures on firefox as this allows me to quickly scroll through tabs, and if I am lazy I just move the mouse and click the tab I want.
You need a PROPER mouse.
I only single click (again user prefs), I do not have to move my mouse to the back or forward buttons (because they are on my mouse), links open in new windows and it is only a single click to open any window of choosing
  • #129
Why people want to use Javascript is beyond me.
most browsers DON'T support it and the end user can turn it off.
You have to have extra coding to support those browsers so that the code dengenerates "nicely".
Sure javascript can do some niecy nicey special effects but why bother when most users can't benefit?
If you want your users to see something it should all be done server side.
I don't use a HTML editor or any thing like frontpage or dreamweaver.
I code from the ground up.
  • #130
No, you don't, you can get it to do it there and then.
Oh and in Firefox - the lack of option to OPEN ugh - the only thing you can do is save to disk - very often I don't want to save to disk.
Default locations can be set via user prefs.
  • #131
Greg Bernhardt said:
... Personally I've never ever encountered any SVG. ... Again, 99% of people will never run into xforms outside Office, it is along way from being used on websites.
These aren't really arguments for or against relatively new technologies. Why would anyone ever need a light bulb with no infrastructure to support it ? :wink:
  • #132
Javascript is vital in AJAX applications. Have you ever used google maps? Perhaps you have a gmail account? If you go to big ecommerce site you'll see javascript being used. Go to amazon and look at the source. It's pretty ubiquitous.
When I design websites I do my mockups in SVG using Inkscape. I can stretch, rotate or maniplute whatever aspects of the layout without affecting gradients, rounded corners, etc. After mockup I take the svg and export to png for slicing in The Gimp. Once I have sliced all the images I write the appropriate css/html to represent the layout based on the mockups.
I would love to go from mockups in SVG straight to final layout in SVG.
