Falling stick problem (no friction): What is the kinetic energy?
The discussion centers on calculating the kinetic energy of a falling stick without friction. It highlights that the kinetic energy should be the sum of rotational kinetic energy about the center of mass and translational kinetic energy of the center of mass. The absence of friction means there is no horizontal motion, simplifying the analysis. Participants emphasize the need for a clear problem statement to facilitate effective assistance. Overall, the kinetic energy expression involves both rotational and translational components under ideal conditions.
phos19
Since there is no friction : $$ m \ddot{x} = 0 $$ (no x motion).For the kinetic energy , I've tried: $$ K = 1/2 I_{cm} \dot{\alpha}^2 + 1/2 m v^2_cm = 1/2 I_{cm} \dot{\alpha}^2 + 1/2 m \dot{z}^2$$ . Giving me a weird expression , shouldn't the kinetic energy just be half the the moment of inertia about the contact point times $$\dot{\alpha}^2$$?
K.E would be sum of rotational and translational kinetic energy. Gravity is a conservative force, and if there's no air resistance and assuming that no energy dissipation happens due to heat and sound etc, then K.E of falling stick = Rotational K.E about it's Center of mass + Translational K.E of the center of mass.
If you are seeking help, please help us help you and provide a statement of the problem or ask a specific question. Most of us lack even the most basic mind reading skills.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
